[ATL] Re: refining mode, 2 source models one is refined and the other is auxiliary [message #545065 is a reply to message #543255] |
Tue, 06 July 2010 10:21  |
--------------080709090107050605090707
Content-Type: text/plain; charset=UTF-8; format=flowed
You can use the following syntax:
create OUT: UML refining IN1: UML , IN2: UML;
IN1 will be refined into OUT (inout model), and IN2 will be used as an
auxilary model (readonly).
William
Le 28/06/2010 22:08, wafaa a écrit :
> hi all
> is it possible to have 2 source models in the refining mode, one is
> refined and the other is used to get elements if necessary and the
> result is single target model
> like below
> create OUT: UML from IN1: UML , IN2: UML;
> where IN1 is being refined in where new elements are added to produce
> OUT. but in2 is only used to get information
Content-Type: text/x-vcard; charset=utf-8;
name="william_piers.vcf"
Content-Disposition: attachment;
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------080709090107050605090707--
FUDForum. Page generated in 0.08285 seconds
