Home » Archived » Visual Editor (VE) » VE 1.4 and Eclipse 3.6(Can't install VE 1.4 on Eclipse 3.6)
VE 1.4 and Eclipse 3.6 [message #542857] Sat, 26 June 2010 20:23 Go to next message
Chris Missing name is currently offline Chris Missing nameFriend
Hi!
I have some problems installing VE 1.4 on a fresh Eclipse 3.6 IDE for Java EE Developers installation, because i get some dependency errors (see below). There are some infos in different threads and in this bugreport:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=301766
for VE 1.4 and Eclipse 3.5. I have tried to installed only the VE SDK but still get the dependency error. Are there any chances to install VE 1.4 on Eclipse 3.6 or do we need a new VE version?
Thanks in advance for a reply.
Chris
Dependency error:
Cannot complete the install because of a conflicting dependency.
Software being installed: Visual Editor SDK 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO (org.eclipse.ve.sdk.feature.group 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
Software currently installed: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
Only one of the following can be installed at once:
International Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu 4.2.1.v20100412)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
Cannot satisfy dependency:
From: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
To: org.eclipse.epp.package.jee.feature.feature.group [1.3.0.20100617-0521]
From: Java EE IDE Feature 1.3.0.20100617-0521 (org.eclipse.epp.package.jee.feature.feature.group 1.3.0.20100617-0521)
To: org.eclipse.platform.feature.group [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
From: Eclipse Platform 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY (org.eclipse.platform.feature.group 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
To: org.eclipse.rcp.feature.group [3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS]
From: Eclipse RCP 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS (org.eclipse.rcp.feature.group 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS)
To: com.ibm.icu [4.2.1.v20100412]
From: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
To: org.eclipse.ve.java.core [1.3.0,2.0.0)
From: Visual Editor Java Core 1.4.0.v20090826-1446 (org.eclipse.ve.java.core 1.4.0.v20090826-1446)
To: bundle com.ibm.icu [3.4.4.1,4.1.0)
From: Visual Editor SDK 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO (org.eclipse.ve.sdk.feature.group 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
To: org.eclipse.ve.feature.group [1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk]
icon4.gif  Re: VE 1.4 and Eclipse 3.6 [message #543625 is a reply to message #542857] Wed, 30 June 2010 06:03 Go to previous messageGo to next message
bigboban  is currently offline bigboban Friend
I have same problem. On Eclipse 3.5 no problem, on 3.6 same error as Chris. Sad
I use this online install site:
http://download.eclipse.org/tools/ve/updates/1.4/
Re: VE 1.4 and Eclipse 3.6 [message #543696 is a reply to message #543625] Wed, 30 June 2010 10:52 Go to previous messageGo to next message
Patrik Suzzi is currently offline Patrik SuzziFriend
Troubles installing VE 1.4 ( Visual Editor ) on Eclipse 3.6 Helios
I've used this update site:
and I tried to install Visual Editor on different Eclipse distros:
- Eclipse RCP and RAP
- Eclipse Modeling (with incubating components)
- Eclipse Reporting.
In any case i get this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd)
Missing requirement: Java EMF Model Utilities 2.0.200.R3_1_maintenance (org.eclipse.jem.util 2.0.200.R3_1_maintenance) requires 'bundle com.ibm.icu [3.8.1.1,4.1.0)' but it could not be found
From: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd)
To: org.eclipse.jem.util [2.0.200.R3_1_maintenance]
Anyone can help me ?
Re: VE 1.4 and Eclipse 3.6 [message #544020 is a reply to message #542857] Thu, 01 July 2010 11:46 Go to previous messageGo to next message
Hi, same problem here. Eclipse Helios for Java Dev.
Software being installed: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
Missing requirement: Visual Editor Common Data Editor 1.4.0.v20090826-1446 (org.eclipse.ve.cde 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
To: org.eclipse.ve.cde [1.3.0,2.0.0)
My Plugins:
Mobile Tools
PDT
Pydev
Android Plugin for Eclipse.
A quick update by the plugin dev would be great.
Thanks!
Pascal
[Updated on: Thu, 01 July 2010 11:46] by Moderator
Report message to a moderator
Re: VE 1.4 and Eclipse 3.6 [message #544203 is a reply to message #542857] Fri, 02 July 2010 01:40 Go to previous messageGo to next message
Nialsh is currently offline NialshFriend
I'm having the same issue using Helios EE. Build id: 20100617-1415
Missing requirement: Visual Editor Java Core 1.4.0.v20090826-1446 (org.eclipse.ve.java.core 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
To: org.eclipse.ve.java.core [1.4.0.v20090826-1446]
I really don't want to write this GUI by hand. Please help!
Re: VE 1.4 and Eclipse 3.6 [message #544627 is a reply to message #544203] Mon, 05 July 2010 06:07 Go to previous messageGo to next message
Roland  is currently offline Roland Friend
Same problem here. Trying to install VE 1.4 in Eclipse 3.6 Helios Build id: 20100617-1415 (a fresh install of Eclipse IDE for Java Developers, not EE version).
Like others, I have followed the steps outlined in the VE Wiki to the letter, but have the same problem.
I have had similar problems with 3.5 Galileo. I was advised at the time to just install VE SDK and none of the other options, but that never worked for me either.
As mentioned in other posts / forums, there seems to be a dependency around Java EMF. What conflict actually exists? Did
EMF break backwards compatibility? Why does it seem that a specific EMF version is required rather than a more generic >= N ?
Re: VE 1.4 and Eclipse 3.6 [message #544673 is a reply to message #542857] Mon, 05 July 2010 08:40 Go to previous messageGo to next message
Ben H is currently offline Ben HFriend
i just downloaded the ve plug-in. copied it to my plugins-folder and then modified the MANIFEST.MF of each single plug-in, removing the version information of the required bundles.
Works fine for me now Smile
greetings,
Ben
[Updated on: Mon, 05 July 2010 08:41]
Re: VE 1.4 and Eclipse 3.6 [message #544903 is a reply to message #544673] Tue, 06 July 2010 00:43 Go to previous messageGo to next message
kit  is currently offline kit Friend
I tried to do what you outlined: I unzipped eclipse VE-Update-1.4.0, copied the contents on the plugin folder to eclipse Helios plugin. However, I only found the Manifest files you referred to in features folder of eclipse. The unzipped features folder from the VE download has 'jar' files. How did you handle this? Is there a way to 'unzip' or 'execute' the jar files to get to the Manifest?
Also, in eclipse, the plugin files have extensions ".jar", but the unzipped download files have ".jar.pack.gz" Is there a utility that will decompress these plugin's down to just ".jar"?
I'm new to eclipse and java, so I will appreciate any help anyone can provide. I have been trying to get the VE component installed all weekend.
[Updated on: Tue, 06 July 2010 01:37]
Re: VE 1.4 and Eclipse 3.6 [message #545016 is a reply to message #542857] Tue, 06 July 2010 11:55 Go to previous messageGo to next message
Hi kit,
.jar files are in fact just normal .zip files.
I am using Total Commander for example with a plug-in that handles .jar files as zip files. So i open it, edit the MANIFEST.MF in it and pack it back in.
hmm gz is a packing format that can be unpacked with a tool named gzip(gunzip), Total Commander can do that too. But what is about the .pack format i don't know. I just copied the jar files from my eclipse 3.5 installation to my 3.6. Eclipse 3.5 was able to install the ve via update site.
greetz,
Ben
[Updated on: Tue, 06 July 2010 12:01]
Re: VE 1.4 and Eclipse 3.6 [message #545497 is a reply to message #542857] Thu, 08 July 2010 04:13 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANGFriend
The build for Helios is ongoing. It will be available soon.
Best regards
Yves YANG
"Chris" wrote in message
news:i05njj$ho2$1@build.eclipse.org...
> Hi!
> Chris
> Dependency error:
> Quote:
>> Only one of the following can be installed at once: International
>> 4.2.1.v20100412)
[Updated on: Tue, 28 June 2011 14:22] by Moderator
Re: VE 1.4 and Eclipse 3.6 [message #545531 is a reply to message #545497] Thu, 08 July 2010 07:33 Go to previous messageGo to next message
Enrico R. is currently offline Enrico R.Friend
Member
Yeehaa,
I love you guys :D
Thanks alot :-)
Am 08.07.2010 06:13, schrieb Yves YANG:
> Best regards
> Yves YANG
Re: VE 1.4 and Eclipse 3.6 [message #547634 is a reply to message #545497] Mon, 19 July 2010 08:35 Go to previous messageGo to next message
Frank is currently offline FrankFriend
Same problem here.
It seems that no up-to-date release get out. How can I be notified if Helios compatible VE released?
Re: VE 1.4 and Eclipse 3.6 [message #551693 is a reply to message #542857] Mon, 09 August 2010 08:18 Go to previous messageGo to next message
On this page
http://www.eclipse.org/projects/project-plan.php?projectid=t ools.ve
i see VE 1.5 was released on 06/28/2010.
Under "Release Deliverables" i see "..Project runtime binary features on eclipse.org update site (install via Eclipse update manager)..."
I think this is not true, because there is NO url with new VE 1.5.
So where can i download released VE 1.5??
Re: VE 1.4 and Eclipse 3.6 [message #553897 is a reply to message #545497] Thu, 19 August 2010 11:17 Go to previous messageGo to next message
Colargol is currently offline ColargolFriend
Yves YANG wrote on Thu, 08 July 2010 00:13
Best regards
Yves YANG
Hi Yves,
What's current state of the VE build for Helios? Smile
Thx
Colargol
Re: VE 1.4 and Eclipse 3.6 [message #553965 is a reply to message #545016] Thu, 19 August 2010 14:33 Go to previous messageGo to next message
hiro nakag is currently offline hiro nakagFriend
Hi!
Thanks for Ben, I was able to install VE1.4 on Helios.
And it seems to be working fine for me too.
If there is a person who want to try the plugins that I modified, please look at this page.
By the way,
".jar.pack.gz" can extract $JAVA_HOME/bin/unpack200 .
Thank you for your time.
Re: VE 1.4 and Eclipse 3.6 [message #554913 is a reply to message #542857] Tue, 24 August 2010 17:18 Go to previous messageGo to next message
Hiya nakag,
I downloaded, installed and (quickly) tried your setup... and it seems to work!!!
Thanks for the good work
- Colargol
icon14.gif  Re: VE 1.4 and Eclipse 3.6 [message #555074 is a reply to message #554913] Wed, 25 August 2010 11:50 Go to previous messageGo to next message
hermann krauÃ? is currently offline hermann krauÃ?Friend
thanks,
it seem to run on
Eclipse Java EE IDE for Web Developers.
Version: Helios Release
Herman
Re: VE 1.4 and Eclipse 3.6 [message #555601 is a reply to message #555074] Fri, 27 August 2010 09:51 Go to previous messageGo to next message
hi,
winxp is o.k.,
but there are problems on linux (sidux,debian 64 bit):
with openjdk, the controls are missplaced
with sun jdk, there is a runtime-error opening forms
but this problems are the same on eclipse 3.5.x since a few month ago
hermann
Re: VE 1.4 and Eclipse 3.6 [message #555732 is a reply to message #555601] Fri, 27 August 2010 23:48 Go to previous messageGo to next message
The environment i modified VE1.4 is winxp.
For other platform, you might have to modified VE1.4 for yourself, following procedures. (written in japanese is here.)
1. Install VE1.4 to eclipse galileo from updatesite.
2. Take VE1.4's features and plugins out of the installation features and plugins folder.
3. Extract plugin jar files.
4. Remove '; bundle-version = "[3.8.1.1, 4.1.0)"' from com.ibm.icu written in Require-Bundle of MANIFEST.MF.
5. Remove eclipse.inf, ECLIPSEF.RSA, ECLIPSEF.SF from META-INF folder.
6. Compress it again. (You can use jar command or zip archiver.)
7. Drop it on dropins folder.
You will have to modify the following files.
org.eclipse.jem.util_2.0.200.R3_1_maintenance.jar
org.eclipse.ve.cde_1.4.0.v20090826-1446.jar
org.eclipse.ve.java.core_1.4.0.v20090826-1446.jar
org.eclipse.ve.jfc_1.4.0.v20090826-1446.jar
org.eclipse.ve.propertysheet_1.4.0.v20090826-1446.jar
org.eclipse.ve.swt_1.4.0.v20090826-1446.jar
If you fail to install VE1.4 to galileo, i have no idea...
Thanks for reading my poor English.
Re: VE 1.4 and Eclipse 3.6 [message #557308 is a reply to message #553897] Mon, 06 September 2010 15:12 Go to previous messageGo to next message
We are working on building now. Hope it will be done soon.
best regards
Yves YANG
"Colargol" <colargol70@yahoo.com> wrote in message
news:i4j3t5$iq2$1@build.eclipse.org...
>> Best regards
>> Yves YANG
> Hi Yves,
> What's current state of the VE build for Helios? :)
> Thx
> Colargol
Re: VE 1.4 and Eclipse 3.6 [message #558658 is a reply to message #557308] Mon, 13 September 2010 20:14 Go to previous messageGo to next message
Saeid Nourian is currently offline Saeid NourianFriend
Yves YANG wrote on Mon, 06 September 2010 11:12
When damn it? When?
nakag, I tried your download on Helion Build id: 20100617-1415 in Windows XP but I get this error:
  Missing requirement: Visual Editor Java Core 1.4.0.v20090826-1446 (org.eclipse.ve.java.core 1.4.0.v20090826-1446) requires 'bundle org.eclipse.emf.codegen [2.3.0,3.0.0)' but it could not be found
Any ideas how to fix it?
Re: VE 1.4 and Eclipse 3.6 [message #558692 is a reply to message #558658] Tue, 14 September 2010 04:15 Go to previous messageGo to next message
Hi, runiter.
Do you install EMF SDK from updatesite?
(EMF SDK is the Modeling category in updatesite.)
Required bundle "org.eclipse.emf.codegen" is a plugin included in EMF, and my plugins requre EMF and GEF SDK.
I think your eclipse is not installed EMF SDK completely.
Please check Installation Details.
[Updated on: Tue, 14 September 2010 10:07]
icon14.gif  Re: VE 1.4 and Eclipse 3.6 [message #558886 is a reply to message #558692] Tue, 14 September 2010 18:29 Go to previous messageGo to next message
Thanks alot nakag! Indeed after I installed EMF SDK the VE started working!! Beautiful!
Cheers
Re: VE 1.4 and Eclipse 3.6 [message #618411 is a reply to message #544673] Tue, 06 July 2010 00:43 Go to previous messageGo to next message
Re: VE 1.4 and Eclipse 3.6 [message #618414 is a reply to message #545497] Thu, 08 July 2010 07:33 Go to previous messageGo to next message
Member
Yeehaa,
I love you guys :D
Thanks alot :-)
> Best regards
> Yves YANG
Re: VE 1.4 and Eclipse 3.6 [message #618417 is a reply to message #545497] Mon, 19 July 2010 08:35 Go to previous messageGo to next message
Same problem here.
Re: VE 1.4 and Eclipse 3.6 [message #618425 is a reply to message #545497] Thu, 19 August 2010 11:17 Go to previous messageGo to next message
> Best regards
> Yves YANG
Hi Yves,
Thx
Colargol
Re: VE 1.4 and Eclipse 3.6 [message #618431 is a reply to message #618425] Mon, 06 September 2010 15:12 Go to previous messageGo to next message
best regards
Yves YANG
>> Best regards
>> Yves YANG
> Hi Yves,
> Thx
> Colargol
Re: VE 1.4 and Eclipse 3.6 [message #618433 is a reply to message #557308] Mon, 13 September 2010 20:14 Go to previous messageGo to next message
When damn it? When?
Re: VE 1.4 and Eclipse 3.6 [message #618434 is a reply to message #618433] Tue, 14 September 2010 04:15 Go to previous messageGo to next message
Hi, runiter.
Are you install EMF SDK from updatesite?
Required bundle "org.eclipse.emf.codegen" is a plugin included in EMF.
I think you are not install EMF SDK.
Re: VE 1.4 and Eclipse 3.6 [message #618435 is a reply to message #618434] Tue, 14 September 2010 18:29 Go to previous messageGo to next message
Cheers
Re: VE 1.4 and Eclipse 3.6 [message #629148 is a reply to message #618435] Mon, 27 September 2010 11:16 Go to previous messageGo to next message
markus is currently offline markusFriend
I managed to intall into eclipse Version: 3.7.0, Build id: I20100921-1024. But Visual Editor does not show up. Any expiriences on that?
Re: VE 1.4 and Eclipse 3.6 [message #629916 is a reply to message #542857] Wed, 29 September 2010 23:01 Go to previous messageGo to next message
mmc01  is currently offline mmc01 Friend
I cannot install VE1.4 in Eclipse 3.6. I downloaded eclipse Helios and unzip. Next, I install VE from URL.But I have some error. After that, I install EMF from Helios - http://download.eclipse.org/releases/helios ,But when I tried to install VE again. I have same error. When I can use VE1.5? It's too late.
  Missing requirement: Visual Editor PropertySheet 1.4.0.v20090826-1446 (org.eclipse.ve.propertysheet 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
    To: org.eclipse.ve.propertysheet [1.4.0.v20090826-1446]
[Updated on: Thu, 30 September 2010 07:54]
Re: VE 1.4 and Eclipse 3.6 [message #631551 is a reply to message #542857] Thu, 07 October 2010 22:24 Go to previous messageGo to next message
Javier Gómez is currently offline Javier GómezFriend
I get this error when trying to install with the update manager in Helios:
Software being installed: Java EMF Model SDK 1.4.0.v20090826-1446-377-84M2IaeLhpiUslQArckxjIhH (org.eclipse.jem.sdk.feature.group 1.4.0.v20090826-1446-377-84M2IaeLhpiUslQArckxjIhH)
From: Java EMF Model SDK 1.4.0.v20090826-1446-377-84M2IaeLhpiUslQArckxjIhH (org.eclipse.jem.sdk.feature.group 1.4.0.v20090826-1446-377-84M2IaeLhpiUslQArckxjIhH)
To: org.eclipse.jem.feature.group [1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd]
Thanks for your help.
Re: VE 1.4 and Eclipse 3.6 [message #633062 is a reply to message #545497] Fri, 15 October 2010 08:37 Go to previous messageGo to next message
Chemi is currently offline ChemiFriend
Any update on this task?
Thanks in advance,
Chemi.
> Best regards
> Yves YANG
Re: VE 1.4 and Eclipse 3.6 [message #638197 is a reply to message #633062] Wed, 10 November 2010 12:20 Go to previous messageGo to next message
Santosh  is currently offline Santosh Friend
installing VE 1.4 on a fresh Eclipse 3.6 IDE I Helios in SUSE linux..... I used the following update link -> http://download.eclipse.org/tools/ve/updates/1.4/
I'm gettiing the following error message during installation:
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.jem,2.0.300.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem_2.0.300.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo,2.0.300.R3_1_maintenanc e.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo_2.0.300.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo.vm,2.0.200.R3_1_mainten ance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo.vm_2.0.200.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.beaninfo.vm.common,2.0.201.R3_1_ maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.beaninfo.vm.common_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.proxy,2.0.201.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.proxy_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.source,1.4.0.v20090826-1446-7H-F PbAcggQleH8hJifHfUd.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.source_1.4.0.v20090826-1446-7H-FPbAcggQleH8hJif HfUd.jar
Artifact not found: osgi.bundle,org.eclipse.jem.ui,2.0.100.R3_0_4.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.ui_2.0.100.R3_0_4.jar
Artifact not found: osgi.bundle,org.eclipse.jem.util,2.0.200.R3_1_maintenance.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.util_2.0.200.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.jem.workbench,2.0.201.R3_1_maintenan ce.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.jem.workbench_2.0.201.R3_1_maintenance.jar
Artifact not found: osgi.bundle,org.eclipse.ve,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.cde,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.cde_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.doc,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.doc_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.java.core,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.java.core_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.propertysheet,1.4.0.v20090826-144 6.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.propertysheet_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.sdk,1.4.0.v20090826-1446.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.sdk_1.4.0.v20090826-1446.jar
Artifact not found: osgi.bundle,org.eclipse.ve.source,1.4.0.v20090826-1446-777N- CcNBC0BwNk5HZZk.
http://download.eclipse.org/tools/ve/updates/1.4/plugins/org .eclipse.ve.source_1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk .jar
can any body help me
Re: VE 1.4 and Eclipse 3.6 [message #638452 is a reply to message #638197] Thu, 11 November 2010 11:06 Go to previous messageGo to next message
In this same discussion thread there is an explanation about how to
install it touching manually the files. it is not the direct and desired
way but.... it is what we have today.
Still waiting to a real installable version. :-(
Re: VE 1.4 and Eclipse 3.6 [message #652795 is a reply to message #638452] Sun, 06 February 2011 20:25 Go to previous message
Robert Lockwood is currently offline Robert LockwoodFriend
Member
OK, it's now the end of the first week in February, 2011. I'm new to Eclipse (I like it) and Java and have been using Helios. I just installed Indigo and decided to look for a visual editor but find that it apparently will not install on Indigo and there are problems with Helios - has any of this been resolved?
Previous Topic:VE 1.5 release review
Next Topic:Error trying to set new file into editor
Current Time: Sat Apr 27 02:49:18 GMT 2024
Powered by FUDForum. Page generated in 0.05721 seconds
