[ATL] Problem about a Rule with two Input Models and one output Model [message #538139] |
Sat, 05 June 2010 15:33 |
kikou Messages: 7 Registered: May 2010 |
Junior Member |
Hi !!
I'll try to be as clear as possible to explain my problem.
I'd like to do a transformation from two input models MIn1 and MIn2 to one output MOut,
I start my rule like the following way :
module FromInToOut;
create OUT : Out from IN : MIn1, IN1 : MIn2;
rule GeneralRule {
from
mapp :MIn2!Mapping,
bpd :MIn1!BPD
to
out : Out!OutputClass
do ......
but when I have the Output XMI file I find two tags of type "OutputClass" instead of one.
I realise that the cause of having two tags instead of having one is that I mentioned two Models in the "from" part (writen in red color) but I couldn't find an other solution because this rule have to take into consideration this two Input models MIn1 and MIn2.
So could someone give me a solution or tell me how to refer the "MIn2!Mapping" class without mention it within the "from" section.
I heard about the "Inter-model references" but I don't know how to use it and what is the syntax to use to refers a model using this method.
Thanks .
Best Regards.
Kikou
[Updated on: Sat, 05 June 2010 16:16] Report message to a moderator
FUDForum. Page generated in 0.03639 seconds
