Re: Subversive 0.7.9 Released [message #533440 is a reply to message #533429] |
Thu, 13 May 2010 22:05 |
Thu, 13 May 2010 16:46:25 -0400, /David M. Karr/:
> Oh. Duh. I suppose checking the checkbox for the certificate saying that
> I trust it would be useful. :)
> You'd think the process would be a little more intelligent, like telling
> me that I can't install the plugin if I don't check the checkbox.
I get this certificate dialog using the 3.5.2 JEE package and if I'm
not mistaken not only while installing Subversive but with other
official Galileo packages, also. I don't get this with a bare 3.5.2
Platform Runtime which have my necessary Galileo packages installed
on top.
Stanimir
Re: Subversive 0.7.9 Released [message #533557 is a reply to message #533318] |
Fri, 14 May 2010 14:34 |
David Balažic Messages: 130 Registered: July 2009 |
I updated and now every time I start Eclipse (JEE 3.5.2) I get the SVN Connectop eselection dialog, where I select SVNKit 1.3.0.
Then installation fails with the message:
Cannot complete the request. See the error log for details.
"SVNKit 1.3.0 Implementation (Optional)" will be ignored because a newer version is already installed.
"Subversive SVN Connectors" will be ignored because a newer version is already installed.
I can only cancel the wizard.
If I try to use SVN functionality, I get an error:
org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are available or install and select pure Java Subversion connector from the plug-in connectors update site.
If connectors already installed then you can change the selected one at: Window->Preferences->Team->SVN->SVN Connector.
at org.eclipse.team.svn.core.extension.factory.ISVNConnectorFac tory$1.newInstance(ISVNConnectorFactory.java:105)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.n ewProxyInstance(SVNRepositoryLocation.java:750)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.a cquireSVNProxy(SVNRepositoryLocation.java:542)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryContainer. getChildren(SVNRepositoryContainer.java:77)
I checked and I have SVNKit 1.3.2 installed and also
Subversive SVN Connectors 2.2.2.I20100512-1900 org.polarion.eclipse.team.svn.connector.feature.group
I will now uninstall them and try again.
[Updated on: Fri, 14 May 2010 14:37] Report message to a moderator
Re: Subversive 0.7.9 Released [message #533560 is a reply to message #533557] |
Fri, 14 May 2010 14:44 |
David Balažic wrote on Fri, 14 May 2010 16:34 |
That worked. I uninstalled those two, restarted Eclpse and again it showed the SVN connector dialog, I selected SVNKit 1.3.0* and it installed and works fine.
But!
If I click menu Help / Check for Updates, it finds and offers SVNKit 1.3.2 and Subversive SVN Connectors 2.2.2.I20100512-1900.
Is it safe to update?
This is all a bit confusing, I must admit.
* - (fixed typo: I installed SVNKit 1.3.0 , not 1.3.2. I fixed the text above)
[Updated on: Mon, 17 May 2010 08:26] Report message to a moderator
Re: Subversive 0.7.9 Released [message #535680 is a reply to message #535064] |
Tue, 25 May 2010 09:00 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello David,
> PS: Can you answer my question about the way you post here?
> (in regards to https://bugs.eclipse.org/bugs/show_bug.cgi?id=291441#c15 )
I already answered, anyway I'm using Mozilla Thunderbird, NNTP. Or
should I answer directly in bug?
> Igor Burilo wrote on Fri, 21 May 2010 09:50
>> Hello David,
>> When you have Subversive 0.7.9 installed then Connector Discovery
>> dialog has to propose to install SVN Kit 1.3.2 but not 1.3.0.
>> So, please check that you do have Subversive 0.7.9, and if not please,
>> update Subversive to 0.7.9 at first.
> I have 0.7.8.
> Strange,I was 100% I installed the latest version.
> Sorry for confusing information.
Igor Burilo
FUDForum. Page generated in 0.05014 seconds
