quick fix added twice on save [message #532547] |
Mon, 10 May 2010 08:44  |
When saving a b3 file with an error for which there is a quick fix, I
get two quick fix proposals in the quickfix popup menu after saving the
file.
I am not using Xtext nature, and therefore use
public Class<? extends IXtextEditorCallback> bindIXtextEditorCallback()
{ return ValidatingEditorCallback.class; }
The validation is done like this:
@Check
public void checkRepository(Repository repoHandler) {
if(repoHandler.getRemote() == null) {
error("The repository must have an URI declared as 'remote = <URI>'",
repoHandler,
B3BuildPackage.REPOSITORY__HANDLER_TYPE,
ISSUE_REPOSITORY__NO_REMOTE);
And the fix like this:
private final static String ISSUE_REPOSITORY__NO_REMOTE_FIX =
"http://abc.org";
@Fix(BeeLangJavaValidator.ISSUE_REPOSITORY__NO_REMOTE)
public void insertRemoteURI(final Issue issue, IssueResolutionAcceptor
acceptor) {
acceptor.accept(
issue, "Insert remote URI", "remote = \"" +
ISSUE_REPOSITORY__NO_REMOTE_FIX + "\"", "",
new ISemanticModification() {
public void apply(EObject element, IModificationContext
context) throws Exception {
Repository repo = (Repository) element;
repo.setRemote(URI.create(ISSUE_REPOSITORY__NO_REMOTE_FIX));
Questions
Is the validation and fix done as they should?
Is there something else I need to do?
- henrik
Re: quick fix added twice on save [message #532651 is a reply to message #532547] |
Mon, 10 May 2010 12:38  |
Hi Henrik,
that's a regression.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=312297
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 10.05.10 14:44, schrieb Henrik Lindberg:
> file.
> @Check
> repoHandler,
> "http://abc.org";
> acceptor) {
> acceptor.accept(
> public void apply(EObject element, IModificationContext context) throws
> Exception {
> Questions
> Regards
> - henrik
FUDForum. Page generated in 0.14761 seconds
