Home » Eclipse Projects » Web Tools incubator » javax.xml.rpc.JAXRPCException ????(Number of parameters passed in (0) doesn't match the number of IN/INOUT parameters (1) from the addParameter() calls)
javax.xml.rpc.JAXRPCException ???? [message #532196] Fri, 07 May 2010 13:45
asadfx  is currently offline asadfx Friend
I have deployed a simple web service using Apache Tomcat 6.0 and Axis 1.4 in Windows XP.
Now the server is very simple:
import java.io.*;
import java.util.*;
HelloWorld.java
This is our web service
public class HelloWorld
public String getHelloWorld(String id)
String retName="";
try
			File indexFile = new File("index.txt");
			retName=indexFile.getAbsolutePath()+id;
		catch(Exception e)
			e.printStackTrace();
	return retName;
Now if the client doesn't send any parameters then everything works well (I am using
Eclipse to run the client). But as sson as I try to send a parameter to the server, I
get the following error:
"javax.xml.rpc.JAXRPCException: Number of parameters passed in (0) doesn't match the
number of IN/INOUT parameters (1) from the addParameter() calls"
Why is this happening??? My client is also very simple:
package dummyC;
import java.util.*;
import org.apache.axis.client.Call;
import org.apache.axis.client.Service;
import org.apache.axis.encoding.XMLType;
import org.apache.axis.utils.Options;
import javax.xml.namespace.QName;
import javax.xml.rpc.ParameterMode;
import javax.xml.rpc.*;
public class DummyC {
	 * @param args
	public static void main(String[] args)
		try
		Service service = new Service();
		Call call = (Call)service.createCall();
		String endpoint ="http://localhost:8081/axis/HelloWorld.jws";
		call.setTargetEndpointAddress(new java.net.URL(endpoint));
		call.setOperationName(new QName("getHelloWorld"));
		call.addParameter("param1",XMLType.XSD_STRING, ParameterMode.IN);
		String output = (String)call.invoke(new Object[]{});
		System.out.println("Got result : " + output);
		catch(Exception e)
			System.out.print("sssss: "+e.toString());
Please guys, I need to solve this problem with in the next couple of days.
Bye.
Previous Topic:is the current version CXF Web Services included in eclipse 3.6 M7 WTP 3.2 ?
Next Topic:javax.xml.rpc.JAXRPCException ????
Current Time: Wed Sep 25 18:32:49 GMT 2024
Powered by FUDForum. Page generated in 0.03211 seconds
