Update menu item disabled in Outgoing mode [message #513843] |
Thu, 11 February 2010 08:45  |
Hi!
In Team Sync view, if a file is in conflict (red arrow), then in the "Outgoing Mode", the files context menu has the "Update" item disabled.
Which is wrong, since "Update" is enabled (and works as expected) on the same file if I go to the "Incoming Mode" or "Incoming/Outgoing Mode".
Using:
Eclipse Java EE 3.5.1
Subversive SVN Connectors 2.2.1.I20091215-1700 org.polarion.eclipse.team.svn.connector.feature.group
Subversive SVN Team Provider (Incubation) 0.7.8.I20091207-1900 org.eclipse.team.svn.feature.group
SVNKit 1.3.2 Implementation (Optional) 2.2.1.I20091215-1700 org.polarion.eclipse.team.svn.connector.svnkit16.feature.gro up
David
Re: Update menu item disabled in Outgoing mode [message #514415 is a reply to message #513843] |
Mon, 15 February 2010 04:25  |
Hello David,
"Outgoing Mode" is designed specifically to show/work with only outgoing
changes which assumes than Update action isn't applicable here, even despite
that file can have incoming and outgoing changes at the same time. If you
need to call Update action then switch to Incoming or Incoming/Outgoing
modes. If you have any issues here please report corresponding tasks to
Eclipse Team as this is their component.
> Hi!
> Using:
> David
FUDForum. Page generated in 0.04422 seconds
