Home » Newcomers » Newcomers » ecore2ecore mapping
ecore2ecore mapping [message #509705] |
Mon, 25 January 2010 03:32 |
smilee Messages: 6 Registered: January 2010 |
Junior Member |
Hell moderator,
I am having two ecore files and i want to do ecore2ecore transformation. May I know how to execute the file. Also, is there any necessary to write the java file..?
[Updated on: Mon, 25 January 2010 03:33] Report message to a moderator
Re: ecore2ecore mapping [message #511447 is a reply to message #510007] |
Mon, 01 February 2010 15:59 |
Junior Member |
Hi Ed,
I am trying to solve the example from previous posts. I'm providing the link here: http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9636.html
public static void saveResourceWithMapping() throws IOException{
// Create package registry
EPackage.Registry ePackageRegistry = new EPackageRegistryImpl(EPackage.Registry.INSTANCE);
EPackage sourcePackage = (EPackage)EPackage.Registry.INSTANCE.getEPackage("http://Met1");
EPackage targetPackage = (EPackage)EPackage.Registry.INSTANCE.getEPackage("http://Met2");
// Map between source namespace and target model location with the target package
//ePackageRegistry.put(sourcePackage.getNsURI(), targetPackage);
ePackageRegistry.put("platform:/resource/Met1/model/Met2.ecore ", targetPackage);
//han
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put
("*", //<--- your file extension
new XMIResourceFactoryImpl() //<--- the class to resource factory
public Resource createResource(URI uri)
XMIResource xmiResource = new XMIResourceImpl(uri);
return xmiResource;
// Create new resource set
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.setPackageRegistry(ePackageRegistry);
// Create the input model resource
XMLResource resource = (XMLResource)resourceSet.createResource(URI.createURI("platform:/resource/Met1/src/Mod1.met1 "));
//File
// Create the input mapping resource
//Resource mappingResource = resourceSet.getResource(URI.createURI("platform:/resource/Met1/model/Met1_2_Met2.ecore2xml "), true);
Resource mappingResource = null;
File f = new File("resource/Met1/model/Met1_2_Met2.ecore2xml");
System.out.println(f.exists());
if(f.exists()) {
System.out.println(f.getAbsolutePath());
URI uri;
uri = URI.createFileURI(f.getAbsolutePath());
System.out.println(uri);
mappingResource = resourceSet.getResource(URI.createFileURI(f.getAbsolutePath( )), true);
Resource ecoreResource = resourceSet.getResource(URI.createURI("platform:/resource/Met1/model/Met2.ecore "), true);
// Create new mapping registry
Ecore2XMLRegistry ecore2xmlRegistry = new Ecore2XMLRegistryImpl(Ecore2XMLRegistry.INSTANCE);
// Get the mapping information from the input mapping resource
XMLMap myXMLMapping = (XMLMap)EcoreUtil.getObjectByType(mappingResource.getContent s(), Ecore2XMLPackage.eINSTANCE.getXMLMap());
// Map between source namespace and the input mapping information
ecore2xmlRegistry.put(sourcePackage.getNsURI(), myXMLMapping);
// Create new mapping ExtendedMetaData information
ExtendedMetaData extendedMetaData = new Ecore2XMLExtendedMetaData(ePackageRegistry, ecore2xmlRegistry);
// Map save/load option of an XMLResource with the ExtendedMetaData information
Map myMap = new HashMap();
myMap.put(XMLResource.OPTION_RECORD_UNKNOWN_FEATURE, Boolean.TRUE);
myMap.put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
// Load and save with the mapping
resource.load(myMap);
resource.setURI(URI.createURI("platform:/resource/Met1/src/Mod1.met2 "));
resource.save(null);
if(f.exists()) {
URI uri;
try {
M2MConverter.saveResourceWithMapping();
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
We are not getting any output for this and some exceptions are coming. Could you explain me why this happens, also, if possible, can you provide an example for ecore2ecore transformation so that we can understand easily.
Re: ecore2ecore mapping [message #511489 is a reply to message #511447] |
Mon, 01 February 2010 12:38 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------040807050108090201020105
Content-Type: text/plain; charset=UTF-8; format=flowed
You could have a look at the EMF recipes:
5.1 Recipe: Data Migration
<http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration>
smilee wrote:
> Hi Ed,
> the link here:
> the target package
> ", targetPackage);
> //han
> ).put
> factory
> return xmiResource;
I wonder why you had to replace the registry with your own?
> //File
> "), true);
Direct file system access?
> if(f.exists()) {
> URI uri;
> mappingResource =
> "), true);
> ExtendedMetaData information Map myMap = new HashMap();
> Boolean.TRUE);
> extendedMetaData);
> public static void main(String[] args) {
> if(f.exists()) {
> URI uri;
> try {
> understand easily.
It's not as if I can run your example so best to use the debugger rather
than me for your answers.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
You could have a look at the EMF recipes:<br>
<blockquote><a
href="http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration"><span
class="tocnumber">5.1</span> <span class="toctext">Recipe: Data
Migration</span></a><br>
</blockquote>
<br>
smilee wrote:
<blockquote cite="mid:hk6tob$han$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
<br>
link here:
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9636.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 9636.html</a>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
(EPackage)EPackage.Registry.INSTANCE.getEPackage(<a class="moz-txt-link-rfc2396E" href="http://Met1">"http://Met1"</a>);
<br>
(EPackage)EPackage.Registry.INSTANCE.getEPackage(<a class="moz-txt-link-rfc2396E" href="http://Met2">"http://Met2"</a>);
<br>
<br>
<br>
<br>
<br>
the target package
<br>
targetPackage);
<br>
", targetPackage);
<br>
<br>
<br>
//han
<br>
).put
<br>
<br>
resource factory
<br>
<br>
<br>
<br>
<br>
return xmiResource;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
I wonder why you had to replace the registry with your own?<br>
<blockquote cite="mid:hk6tob$han$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
//File
<br>
<br>
<br>
"), true);
<br>
<br>
<br>
<br>
</blockquote>
Direct file system access?<br>
<br>
if(f.exists()) {
<br>
<br>
URI uri;
<br>
<br>
<br>
mappingResource =
<br>
<br>
<br>
<br>
"), true);
<br>
<br>
<br>
<br>
<br>
<br>
Ecore2XMLPackage.eINSTANCE.getXMLMap()); <br>
information
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Boolean.TRUE);
<br>
extendedMetaData);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
File f = new
<br>
<br>
if(f.exists()) {
<br>
<br>
URI uri;
<br>
<br>
<br>
<br>
<br>
<br>
try {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
understand easily.
<br>
</blockquote>
rather than me for your answers.<br>
</body>
</html>
--------------040807050108090201020105--
Ed Merks
Current Time: Fri Apr 26 10:56:22 GMT 2024
Powered by FUDForum. Page generated in 0.07630 seconds
