Home » Eclipse Projects » Eclipse Platform » Same Plugin with multiple versions
Same Plugin with multiple versions [message #507918] Fri, 15 January 2010 03:15 Go to next message
I am using eclipse 3.4
Is it possible to have same plugin with multiple versions? If so which version would be loaded ?
I have plugins with multiple versions, and it seems to be loading the older versions. Is there any way to force it to use the latest version of a plugin?
Would the behavior change if a plugin contributes an extension or defines a extension point.
thanks
- Ani
Re: Same Plugin with multiple versions [message #508012 is a reply to message #507918] Fri, 15 January 2010 04:58 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Whether there can be more than one version of a plugin active at a time
depends on the MANIFEST.MF entry
Bundle-SymbolicName: yada;singleton:=true
If it sees the singleton=true then only the latest version will be active.
If this is not set, then it depends on the plugin.xml. If a plugin.xml
contributes no extensions then there can be multiple copies active.
Which one chosen depends on the criteria of the plugin that depends on
it. If the dependent plugin says it requires the older one then it will
use the older one.
If the plugin.xml has extensions or extension points defined then it
must be a singleton.
> of a plugin?
> thanks
> - Ani
Rich Kulp
Re: Same Plugin with multiple versions [message #508078 is a reply to message #508012] Fri, 15 January 2010 13:58 Go to previous messageGo to next message
HI Rich
Thanks for your reply
In my case I have the singleton=true; but still I do not see the latest plugin getting loaded. It always loads the old plugin.
Is there any way I can debug why this is happening? Any help is appreciated.
Would this have anything to do with the feature.xml, which specifies a particular version number for a plugin?
thanks
- Ani
Re: Same Plugin with multiple versions [message #508341 is a reply to message #508078] Mon, 18 January 2010 08:43 Go to previous messageGo to next message
How did the higher version plugin get in your install? In 3.4 you can
no longer just drop a plugin in the eclipse/plugins folder, that doesn't
work any more. There is the dropins[1] folder, but that might not work
for a plugin that's actually part of one of your features.
http://wiki.eclipse.org/Equinox_p2_Getting_Started#Dropins
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Same Plugin with multiple versions [message #508416 is a reply to message #508341] Mon, 18 January 2010 12:10 Go to previous messageGo to next message
HI
I did put the plugins in the Dropins folder , but it is not getting picked up. Do I need to also need to update the feature.xml with the new plugin version number, and add it to the dropins folder?
thanks
Re: Same Plugin with multiple versions [message #508429 is a reply to message #508416] Mon, 18 January 2010 13:10 Go to previous message
> HI
That's where I'm less sure. For a while, a plugin in the dropins folder
could not override a fundamental part of the product (and if your
original is included in a feature, that's part of its baseline).
A possibility is to provide a feature patch on your feature, that points
to the higher version of the plugin ... that might even install through
dropins.
Paul Webster
Previous Topic:markerTypeCategory custom icon?
Next Topic:Click on marker in Problems View jumps to different marker
Current Time: Wed Jul 02 17:21:05 EDT 2025
Powered by FUDForum. Page generated in 0.25367 seconds
