Home » Language IDEs » C / C++ IDE (CDT) » Building 64-Bit Windows Apps(Is is possible to build 64-bit Windows apps)
Building 64-Bit Windows Apps [message #502140] Sun, 06 December 2009 10:06 Go to next message
I need to build some simple 64-bit Windows apps on Windows 7 x86_64. Is this possible to do without having to build a compiler? I already have Eclipse running, but MinGW apparently does not yet officially support 64-bit compilation, and Eclipse tells me that Cygwin is not supported. Can someone please give me the steps needed to install whatever I need to build a 64-bit app, if it is possible?
Thank You
Larry
Re: Building 64-Bit Windows Apps [message #502174 is a reply to message #502140] Sun, 06 December 2009 17:26 Go to previous messageGo to next message
You can use MinGW-w64 and a recent CDT 6.1/7.0 nightly build here. You don't need to build MinGW-w64 youself, you can get it from the automated builds folder.
Re: Building 64-Bit Windows Apps [message #505091 is a reply to message #502174] Sat, 26 December 2009 13:57 Go to previous message
I was using CygWin for Win 7 64 bit and it works more or less ok, except some annoying warnings like "CygWin GCC is not supported" and no output within a console.
Does anyone have any idea if it is not really supported yet for win 7_64 and CygWin?
James
Previous Topic:Debugging: "Display as array" option unavailable.
Next Topic:C/C++ IDE / CDT developer
Current Time: Tue Aug 26 09:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.06187 seconds
