Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Is this possible with EMFCompare?(EMF Compare)
Re: Is this possible with EMFCompare? [message #501530 is a reply to message #501524] |
Wed, 02 December 2009 16:38 |
--------------030609010308030706030502
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Randi,
comments inlined.
Randi wrote:
> Hello All,
> I want to compare 2 xmi files and make a delta(attributes added/deleted
> etc) of it.
> Is it possible to use EMF Compare for this in standalone?
EMF Compare is tested to be usable in standalone mode. Check out the
org.eclipse.emf.compare.example.standalone project from the CVS for an
example of how to do it.
> I checked the code from the CVS , but I only manage to get the match
> Model from it when I load 2 UML models? But I didn't manage to load only
> the 2 xmi's in it . I always get an exception.
Without the exception and its trace, can't say much. Though loading UML
models with xmi extension is somewhat of a bad idea; EMF detects the
file contains UML and does the necessary arrangements according to the
file extension. Not sure if this applies to standalone loading though.
> What is exactly needed to compare 2 xmi's via EMF Compare ? Do I need to
> give up also the UML's or is it enough to give only the xmi's ?
I do not understand this. What is your xmi file if it is not your UML model?
> Also in the standalone version there is some comment:
> // Register additionnal packages here. For UML2 for instance :
> But how can I do this for loading xmi , what is the code for this?
see
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
replacing the UML extension by "xmi"; not sure if this will work as
expected.
> Also can I serialize the Diffmodel for example with eg JAXB ?Or how can
> I do this . I want to make Java object eg DiffModel from this delta?
look at the standalone example. How you serialize the model is you call;
be it through the standard EMF "Resource#save()" or some other mean.
> Many thanks
> Randi
Laurent Goubet
Obeo
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030609010308030706030502--
Re: Is this possible with EMFCompare? [message #501535 is a reply to message #501530] |
Wed, 02 December 2009 16:59 |
Randi Messages: 31 Registered: November 2009 |
Member |
Hello Laurent ,
Thanks already for the answers.
Comments between the lines ==><==
Hi Randi,
comments inlined.
Randi wrote:
> Hello All,
> etc) of it.
==> I used the code from CVS in standalone version.But this was only to load models with the extensions*.uml. What I want to do is to load only 2 models with the extension*.xmi which I made with another Case Tool eg BOUML after exporting the UML model as an xmi.But I didn't succeed to load these xmi's.The code I used to load these xmi's is
//Code Start
// Create a resource set.
ResourceSet resourceSet = new ResourceSetImpl();
// Register the default resource factory -- only needed for stand-alone!
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
// Get the URI of the model file.
URI fileURI = URI.createFileURI(new File("T1.xmi")
.getAbsolutePath());
// Demand load the resource for this file.
Resource resource = resourceSet.getResource(fileURI, true);
// Print the contents of the resource to System.out.
try {
resource.save(System.out, Collections.EMPTY_MAP);
} catch (IOException e) {
//Code End
==> No I used only the xmi which I exported via another tool. So I made the model with a Case Tool ,after that I export it in xmi.
The exception I get is :
emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedEx ception: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (file:/E:/WorkspaceEclipse3.5/LoadXMI/T1.xmi, 3, 15)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at LoadXMI.main(LoadXMI.java:25)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (file:/E:/WorkspaceEclipse3.5/LoadXMI/T1.xmi, 3, 15)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1307)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 2 more
see
expected.
> Many thanks
> Randi
Laurent Goubet
Obeo
Re: Is this possible with EMFCompare? [message #501646 is a reply to message #501535] |
Thu, 03 December 2009 09:05 |
--------------060202000202080703070701
Hi Randi,
Comments inlined.
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent ,
> Hi Randi,
> comments inlined.
> Randi wrote:
>> Hello All,
>> added/deleted etc) of it.
most external tools have an export to "EMF" instead of "xmi". Then
again, most external tool's export fail in one way or another : bad xml,
missing references, illegal IDs ... Can you open your exported model
with the "UML editor" within eclipse ("open with => UML editor" right
click menu)? If yes, can you validate it (right click on the root =>
"validate"? If either of these is "no" then your external modeler fails
at exporting the model properly.
Rename your "*.xmi" model as "*.uml". This can help as it tells EMF your
model is UML, and allows it to set up all the necessary actions for
loading UML models.
> load these xmi's.The code I used to load these xmi's is //Code Start
> stand-alone!
> ryMap()
> try {
> //Code End
Please follow the instructions from
.. This wiki entry describes the _mandatory_ steps for loading UML in a
standalone application, and your code is nowhere near it.
>> only the 2 xmi's in it . I always get an exception.
> 3, 15)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 2 more
>> to give up also the UML's or is it enough to give only the xmi's ?
> model?
> see http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo
> ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F replacing
> the UML extension by "xmi"; not sure if this will work as expected.
>> can I do this . I want to make Java object eg DiffModel from this delta?
>> Many thanks
>> Randi
> Laurent Goubet
> Obeo
--------------060202000202080703070701--
Re: Is this possible with EMFCompare? [message #501658 is a reply to message #501646] |
Thu, 03 December 2009 09:58 |
Member |
Hello Laurent,
Thanks for the answers. I will put alos some comments inline --><--
Hi Randi,
Comments inlined.
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent ,
> Hi Randi,
> comments inlined.
> Randi wrote:
>> Hello All,
loading UML models.
-->I renamed the eported xmi to uml, I can open them with UML Editor and the validation brings no errors. So this should be OK<--
> stand-alone!
> ryMap()
> try {
> //Code End
-->Maybe here is some misunderstanding. I want to load xmi's which are the result of an export from a uml model. I don't want to load the uml models themselve(I don't want to load *.uml but I want the load only the *.xmi)I can only reach those xmi's, because I have to pick up those from CVS, in the CVS there are no *.uml available
.So is is possible only to load those xmi's and then compare them or is this not possible?<--
> 3, 15)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 2 more
> model?
>> Many thanks
>> Randi
> Laurent Goubet
> Obeo
Re: Is this possible with EMFCompare? [message #501666 is a reply to message #501658] |
Thu, 03 December 2009 11:07 |
--------------030808040906000402040703
Randi,
Extension doesn't matter. what your "*.xmi" file contains is UML, that
is why renaming it to "*.uml" allows its loading from Eclipse as
expexted. That is also the reason why you must follow the instructions
of the UML2 wiki to load your file.
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
registers the XMIResourceFactory for all extensions, including your
"*.xmi" extension; and that is the contrary of what must be done. Your
line should look like
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xmi",
UMLResource.Factory.INSTANCE);
So as to register the xmi extension with the UMLResourceFactory for your
resource set. And that will not be enough for standalone loading of your
files; the remaining steps oultined in
must be done as well : registering the libraries, metamodels and
profiles pathmaps, registering the UMLPackage instance in the registry...
As first mentionned, EMF Compare can compare any model loadable through
EMF. Yet without those steps, you will not be able to load your models,
let alone compare them.
Laurent Goubet
Obeo
> Hello Laurent,
> Hi Randi,
> Comments inlined.
> Laurent Goubet
> Obeo
> Randi wrote:
>> Hello Laurent ,
>> Hi Randi,
>> comments inlined.
>> Randi wrote:
>>> Hello All,
>> succeed to
> loading UML models.
>> try {
>> //Code End
> ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F . This
>> UML models with xmi extension is somewhat of a bad idea; EMF detects
>> the file contains UML and does the necessary arrangements according to
>> the file extension. Not sure if this applies to standalone loading
>> though.
>> LHandler.java:1468)
>> Handler.java:1019)
>> Handler.java:87)
>> ndler.java:1001)
>> ndler.java:712)
>> ndler.java:169)
>> nknown Source)
>> java:181)
>> ourceImpl.java:180)
>> ceImpl.java:1494)
>> ceImpl.java:1282)
>> ... 2 more
>> model?
>> expected.
>> call; be it through the standard EMF "Resource#save()" or some other
>> mean.
>>> Many thanks
>>> Randi
>> Laurent Goubet
>> Obeo
--------------030808040906000402040703--
Re: Is this possible with EMFCompare? [message #621879 is a reply to message #501530] |
Member |
Hello Laurent ,
Hi Randi,
comments inlined.
Randi wrote:
> Hello All,
> etc) of it.
//Code Start
try {
//Code End
... 2 more
see
expected.
> Many thanks
> Randi
Laurent Goubet
Obeo
Re: Is this possible with EMFCompare? [message #621887 is a reply to message #621879] |
Hi Randi,
Comments inlined.
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent ,
> Hi Randi,
> comments inlined.
> Randi wrote:
>> Hello All,
loading UML models.
> stand-alone!
> ryMap()
> try {
> //Code End
> 3, 15)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 2 more
> model?
>> Many thanks
>> Randi
> Laurent Goubet
> Obeo
Re: Is this possible with EMFCompare? [message #621889 is a reply to message #501646] |
Member |
Hello Laurent,
Hi Randi,
Comments inlined.
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent ,
> Hi Randi,
> comments inlined.
> Randi wrote:
>> Hello All,
loading UML models.
> stand-alone!
> ryMap()
> try {
> //Code End
> 3, 15)
> LHandler.java:1468)
> Handler.java:1019)
> Handler.java:87)
> ndler.java:1001)
> ndler.java:712)
> ndler.java:169)
> nknown Source)
> java:181)
> ourceImpl.java:180)
> ceImpl.java:1494)
> ceImpl.java:1282)
> ... 2 more
> model?
>> Many thanks
>> Randi
> Laurent Goubet
> Obeo
Re: Is this possible with EMFCompare? [message #621891 is a reply to message #621889] |
Randi,
Laurent Goubet
Obeo
> Hello Laurent,
> Hi Randi,
> Comments inlined.
> Laurent Goubet
> Obeo
> Randi wrote:
>> Hello Laurent ,
>> Hi Randi,
>> comments inlined.
>> Randi wrote:
>>> Hello All,
>> succeed to
> loading UML models.
>> try {
>> //Code End
>> though.
>> LHandler.java:1468)
>> Handler.java:1019)
>> Handler.java:87)
>> ndler.java:1001)
>> ndler.java:712)
>> ndler.java:169)
>> nknown Source)
>> java:181)
>> ourceImpl.java:180)
>> ceImpl.java:1494)
>> ceImpl.java:1282)
>> ... 2 more
>> model?
>> expected.
>> mean.
>>> Many thanks
>>> Randi
>> Laurent Goubet
>> Obeo
Current Time: Sat Apr 27 03:19:57 GMT 2024
Powered by FUDForum. Page generated in 0.03693 seconds
