Re: [CDO] problems with cdo server of N200911221008 [message #501195 is a reply to message #501182] |
Tue, 01 December 2009 13:55 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Lothar,
this error is familiar to me, and from what I can barely recall, I'll
provide some guesses:
- You might get this exception when the client and server are not using
the same communication protocol. I practice this means that you are not
running the right client version for the cdo server on execution (or
viceversa). For instance, check that you are not trying to connect a CDO
3.0 client to a CDO 2.0 server, or viceversa, or even that you are
trying to connect a CDO 3.0 M1 client to a CDO 3.0 M2 servers. Things
like that might cause such problem.
- That you are using a URI that defines a repository that is no longer
defined. Please check your cdo-server.xml file.
Please note that the database schemas have changed slightly from CDO 2.0
to CDO 3.0, what implies that your data will no longer be valid. I would
suggest you to clean up the your database schema.
Please let me know it the above helps.
Víctor.
Lothar Werzinger escribió:
> I tried to migrate my test application to use the latest CDO build
> (N200911221008).
> However when I start the application it can no longer connect to the running
> cdo server (did work with CDO 2.0.0) and I get a
> org.eclipse.net4j.channel.ChannelException:
> org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration
> timeout after 10000 milliseconds
> I checked with netstat and I don't see the cdo server listening on the
> configured port 2036, so that would explain the exception. Did the cdo
> server change between 2.0 and 3.0 in a way that it no longer listens to the
> port configured in cdo-server.xml?
> The output of the cdo server looks as always but it does not listen:
> [INFO] CDO server starting
> [INFO] Detected crash
> [INFO] Repaired after crash: maxObjectID=1, maxMetaID=428
> [INFO] No user manager configured. Users will not be authenticated
> [INFO] CDO server started
> Lothar
Re: [CDO] problems with cdo server of N200911221008 [message #501216 is a reply to message #501195] |
Tue, 01 December 2009 14:40 |
Lothar Werzinger Messages: 153 Registered: July 2009 Location: Bay Area |
Víctor Roldán Betancort wrote:
Comments below:
> Lothar,
Why would Net4J/CDO not tell the client about a protocol mismatch and use a
timeout exception?
I start both server and client from the same target platform, so they should
use exactly the same plugins.
Not sure what you want to tell me. Would I not get an error message if
something is wrong with the cdo-server.xml file?
I did drop the schema and let the cdo server create a new (empty) one.
Unfortunately not. Is there anything I could debug to check why the server
does not listen on the configured TCP port? Where would I have to look for
that?
> Cheers,
> Víctor.
Thanks!
Lothar
Re: [CDO] problems with cdo server of N200911221008 [message #501227 is a reply to message #501216] |
Tue, 01 December 2009 15:22 |
Lothar,
please paste here your client connection code. I wonder if it could be
related with IFailOverStrategy. It's an old concept that came from 2.0
that is no longer used in 3.0, but's still there and not really well
tested. I recall that I had the same problem when using it while
migrating to latest versions.
Some comments below:
> Comments below:
>> Lothar,
> timeout exception?
If some part of the communication channel is waiting for some data that
never comes, it might be the case. As I said, just guessing, and trying
to discard the source of the problem.
I meant that checking that your custom cdo-server.xml configuration
didn't get lost and your were trying to connect to a repository that is
not defined there. However, I checked it out and it seems it now
provides a nice error message, so this is not the problem.
> that?
That could be another point. This was factored out in 3.0, into a new
plugin:
org.eclipse.emf.cdo.server.net4j
Have you checked that your server launch configuration has this plugin?
Víctor.
>> Cheers,
>> Víctor.
> Thanks!
> Lothar
Re: [CDO] problems with cdo server of N200911221008 [message #501395 is a reply to message #501252] |
Wed, 02 December 2009 07:35 |
Hi Guys,
Sorry that I drop in late. You're right, The usage of Net4j transport is
optional in CDO since 3.0. Hence "Select required plugins" does not add
it anymore.
Cheers
/Eike
>>> Then is probably related with missing org.eclipse.emf.cdo.server.net4j.
>>> (I just reproduced it here)
>> I guess that was the case.
>> Just being curious, why does the server not have a dependency to
>> org.eclipse.emf.cdo.server.net4j if it is required? If it had one
>> then it
>> would be automatically selected by the launch configuration editor.
> Well, the transport layer of the CDO-server is decoupled, so one could
> use something different to Net4j. For instance, the ECF project. As
> you might expect, this refactor also happened at the client side: you
> have org.eclipse.emf.cdo.net4j :D
> This way CDO is not tied to the Net4j framework. This was not the case
> in 2.0, and has been introduced in 3.0.
>>> Glad you solved it.
>> Me too :-)
>>> Cheers,
>>> Víctor.
>> Lothar
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.05023 seconds
