Home » Modeling » EMF » Error validating and converting Ecore model
Error validating and converting Ecore model [message #501084] |
Mon, 30 November 2009 22:52 |
Milan Milanovich Messages: 201 Registered: July 2009 |
I want to generate genmodel in Eclipse Modeling Galileo from my ecore file, created in some earlier version (Eclipse 3.2.1). I manually adapted this ecore to latest version used in Galileo. When I try to create new EMF Project, and select ecore model, I get multiple errors like this:
The namespace prefix 'null' is not well formed
The namespace URI 'null' is not well formed
However, when I check the file in text and Sample Ecore editor, it is O.K. There is no error. Also, when I right click that ecore file and choose Validate, it validates correctly.
I also tried this conversion with ecore model created in Ecore Tools shiped with Eclipse Galileo Modeling, however I get the same errors as above, with several more like these two:
There may not be two features named 'name'
The feature Feature of [email]org.eclipse.emf.ecore.impl.EClassImpl@....[/email] contains an unresolved proxy [email]org.eclipse.emf.ecore.impl.EclassImpl@...[/email]
What is the problem here?
Thanks in advance, Milan
[Updated on: Mon, 30 November 2009 23:47] Report message to a moderator
Re: Error validating and converting Ecore model [message #501165 is a reply to message #501084] |
Tue, 01 December 2009 11:34 |
Ed Merks Messages: 33142 Registered: July 2009 |
Milan,
Comments below.
Milan Milanovich wrote:
> like this:
So there is an EPackage without an nsPrefix and nsURI.
> What is the problem?
Perhaps one of the referenced models has this problem?
Ed Merks
Re: Error validating and converting Ecore model [message #501318 is a reply to message #501165] |
Tue, 01 December 2009 20:32 |
Dear Mr. Merks,
Ed Merks wrote on Tue, 01 December 2009 06:34 | Milan,
Comments below.
> like this:
Thank you on your answer.
I cheked all my (sub)packages and all of them have nsPrefix and nsURI.
Well, I don't have referenced models in this ecore metamodel. This is wierd, because I only used EcoreTools shipped with Eclipse Galileo to create the metamodel.
Thank you in advance, Milan
[Updated on: Fri, 18 December 2009 07:43] Report message to a moderator
Re: Error validating and converting Ecore model [message #501340 is a reply to message #501318] |
Tue, 01 December 2009 21:32 |
Milan,
Rapidshare is proving to be less that rapid, unless I fork over some
money, which I'm not feeling inclined to do. I'll try again later or
tomorrow.
> Dear Mr. Merks,
>> Milan,
>> Comments below.
>> > Hi,
>> ecore > file, created in some earlier version (Eclipse 3.2.1). I
>> manually > adapted this ecore to latest version used in Galileo. When
>> I try to > create new EMF Project, and select ecore model, I get
>> multiple errors > like this:
>> is > O.K. There is no error. Also, when I right click that ecore file
>> and > choose Validate, it validates correctly.
> Here is my metamodel file:
> http://rapidshare.com/files/314929834/BPMN2.ecore.html
> For some reason, I cannot attach file here, so I attached it to the
> rapidshare.
Ed Merks
Re: Error validating and converting Ecore model [message #501341 is a reply to message #501340] |
Tue, 01 December 2009 21:45 |
Milan,
I finally downloaded it. But I see all kinds of problems caused by
references such as rBPMN.ecore#//aoBPMN/AspectDot" which I can't
resolve. So clearly there are references to other models. But I don't
see the error about the nsURI/nsPrefix. I really need to see something
complete that reproduces the problem... Does the wizard let you
complete? Can you find the problems in the copied Ecore that's saved
after the wizard completes?
Ed Merks wrote:
> Milan,
> tomorrow.
>> Dear Mr. Merks,
>>> Milan,
>>> Comments below.
>>> > Hi,
>>> When I try to > create new EMF Project, and select ecore model, I
>>> get multiple errors > like this:
>>> file and > choose Validate, it validates correctly.
>> rapidshare.
Ed Merks
Re: Error validating and converting Ecore model [message #501509 is a reply to message #501501] |
Wed, 02 December 2009 15:27 |
Milan,
What exactly is the problem you're hoping I'll help resolve? I just
keep seeing inconsistencies. E.g.,
$ grep StructureDefinition BPMN2.ecore rBPMN.ecore r2ml.ecore
rBPMN.ecore: <eClassifiers xsi:type="ecore:EClass"
name="R2MLMessageType"
eSuperTypes="BPMN2.ecore#//Common/StructureDefinition
BPMN2.ecore#//Common/ItemDefinition">
name="ParticipantReferenceSet"
r2ml.ecore#//Vocabulary/VocBasic/Class
BPMN2.ecore#//Process/Data/DataObject">
So there are references to StructureDefinition but not actual definition
of it. The Sample Ecore Editor can help you track down all these
problems and fix them...
> Dear Mr. Merks,
> Ed Merks wrote on Wed, 02 December 2009 08:53
>> Milan,
>> What about r2ml.ecore? That's needed too. Note that all the
>> subpackages in rBPMN2.ecore have no nsPrefix and no nsURI.
> Well, rBPMN includes r2ml and bpmn2, however I need now first to
> create genmodel for bpmn2 only, and later for rbpmn. When I try to
> create an ecore model for bpmn2 I get errors.
> I attached rBPMN.ecore again, with nsPrefix and nsURI:
> http://rapidshare.com/files/315269918/rBPMN.ecore
> and also r2ml.ecore: http://rapidshare.com/files/315272963/r2ml.ecore
> Thank you, Milan Milanovic
Ed Merks
Re: Error validating and converting Ecore model [message #501522 is a reply to message #501509] |
Wed, 02 December 2009 16:23 |
Dear Mr. Merks,
Ed Merks wrote on Wed, 02 December 2009 10:27 |
For now I'm trying to create genmodel for BPMN2.ecore. R2ML.ecore is O.K. rBPMN includes elements from both, but I will try to generate genmodel for it later, when I create BPMN2 genmodel.
I just
This is some problem with EcoreTools, as I had StructureDefinition class in my BPMN2 and I used it in rBPMN later. However, when I changed the name of that class to ItemDefinition, EcoreTools didn't change it in rBPMN (as noted above).
Now, what is the problem, when I try to open BPMN2.ecore Ecore Import of New EMF Project, in order to create genmodel, I get an Error message box with a list of errors below. However, the problem is that I have some errors, like:
The typed element must have a type, or
But from this I cannot see where is the problem in my ecore file, e.g. on which class?
Thank you, Milan
Re: Error validating and converting Ecore model [message #501528 is a reply to message #501522] |
Wed, 02 December 2009 16:33 |
Milan,
Open each ecore resource in the Sample Ecore Editor and validate it.
Opening the main one BMPN2.ecore and validating that should load the
other two when all the proxies are resolved during validation. Then you
can validate the others as well. You can choose to create markers for
these problems. Double clicking those markers will navigate to the
object with that problem so you can fix it.
> Dear Mr. Merks,
>> I just keep seeing inconsistencies. E.g.,
>> definition of it. The Sample Ecore Editor can help you track down
>> all these problems and fix them...
> on which class?
> Thank you, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #503505 is a reply to message #501084] |
Mon, 14 December 2009 09:37 |
Dear Mr. Merks,
thank you very much.
I have generated a model code, edit and editor from this rBPMN.ecore (which includes R2ML.ecore and BPMN2.ecore), however when I run this editor as a new Eclipse Application, and choose EMF Example Model Creation Wizards, I see in this list all my packages. When I select one and click next, it generates me an error window:
The selected wizard could not be started.
Plug-in "rBPMN_editor.editor" was unable to instantiate class "org.editor.rbpmn.presentation.RbpmnModelWizard".
Could not initialize class org.editor.rbpmn.RbpmnPackage
However, it does not write anything my log file. In addition, I d o not have any errors in my project.
Do you know what is the problem?
[Updated on: Mon, 14 December 2009 14:38] Report message to a moderator
Re: Error validating and converting Ecore model [message #503516 is a reply to message #503505] |
Mon, 14 December 2009 15:08 |
Milan,
I'd expect the full stack trace to appear in the log file. You're
looking in the right place? The Error Log view or
<workspace>/.metadata/.log?
> Dear Mr. Merks,
Ed Merks
Re: Error validating and converting Ecore model [message #503528 is a reply to message #503516] |
Mon, 14 December 2009 15:36 |
Dear Mr. Merks,
no there is nothing in my log file for runtime-EclipseApp. This is complete content of .log file:
!SESSION 2009-10-14 17:57:55.593 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.5.0_16
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sr_CS
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data E:\eclipse\workspace/../runtime-EclipseApplication -dev file:E:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.registry 2 0 2009-10-14 17:58:29.671
!MESSAGE The extensions and extension-points from the bundle "org.eclipse.gmf.runtime.common.ui.printing.win32" are ignored. The host bundle "org.eclipse.gmf.runtime.common.ui.printing" is not marked as singleton.
!ENTRY org.eclipse.osgi 2 0 2009-10-14 17:58:36.625
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-10-14 17:58:36.625
!MESSAGE Bundle Strelka_Self_1.0.0 [4] was not resolved.
!SUBENTRY 2 Strelka_Self 2 0 2009-10-14 17:58:36.625
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
!MESSAGE Bundle Strelka_Self.diagram_1.0.0.qualifier [5] was not resolved.
!SUBENTRY 2 Strelka_Self.diagram 2 0 2009-10-14 17:58:36.625
!MESSAGE Missing required bundle Strelka_Self_0.0.0.
!MESSAGE Missing required bundle Strelka_Self.edit_0.0.0.
!MESSAGE Bundle Strelka_Self.edit_1.0.0 [6] was not resolved.
!SUBENTRY 2 Strelka_Self.edit 2 0 2009-10-14 17:58:36.625
!MESSAGE Bundle org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090818-0225 [374] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.pluggable.core 2 0 2009-10-14 17:58:36.625
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.tool_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.dispatch_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.model_0.0.0.
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.apt.util_0.0.0.
!MESSAGE Bundle org.eclipse.jdt.compiler.apt_1.0.201.R35x_v20090825-1530 [376] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2009-10-14 17:58:36.625
!MESSAGE Bundle org.eclipse.jdt.compiler.tool_1.0.100.v_972_R35x [377] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2009-10-14 17:58:36.625
!ENTRY com.atlassian.connector.eclipse.directclickthrough.ui 4 0 2009-10-14 17:59:26.296
!MESSAGE Unable to run embedded web server, Direct Click Through will not be available
!STACK 0
java.net.BindException: Address already in use: JVM_Bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(Unknown Source)
at java.net.ServerSocket.bind(Unknown Source)
at java.net.ServerSocket.<init>(Unknown Source)
at org.mortbay.jetty.bio.SocketConnector.newServerSocket(SocketConnector.java:80)
at org.mortbay.jetty.bio.SocketConnector.open(SocketConnector.java:73)
at org.mortbay.jetty.AbstractConnector.doStart(AbstractConnector.java:283)
at org.mortbay.jetty.bio.SocketConnector.doStart(SocketConnector.java:147)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
at org.mortbay.jetty.Server.doStart(Server.java:233)
at com.atlassian.connector.eclipse.internal.directclickthrough.ui.DirectClickThroughUiPlugin$2.run(DirectClickThroughUiPlugin.java:88)
!SESSION 2009-12-14 15:27:22.578 -----------------------------------------------
java.version=1.6.0_16
!ENTRY org.eclipse.equinox.registry 2 0 2009-12-14 15:27:43.218
!ENTRY org.eclipse.emf.ecore 2 0 2009-12-14 15:27:52.578
!MESSAGE Both 'org.eclipse.emf.ecore' and 'rBPMN_editor' register a package for 'http://www.eclipse.org/emf/2002/Ecore'
Even if I click on the "Show Log Error", there is nothing written.
btw - I first noticed this when I tried to use model code and edit code in my GMF app. However, there I get this error when I tried to run GMF diagram:
org.osgi.framework.BundleException: Exception in org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.start() of bundle rBPMN_editor.diagram.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:326)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.createExecutableExtension(WorkbenchWizardElement.java:117)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.createWizard(WorkbenchWizardElement.java:261)
at org.eclipse.ui.internal.dialogs.NewWizardNewPage$5.createWizard(NewWizardNewPage.java:729)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(WorkbenchWizardNode.java:151)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(WorkbenchWizardNode.java:135)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizard(WorkbenchWizardNode.java:132)
at org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(WizardSelectionPage.java:104)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage.getNextPage(WorkbenchWizardSelectionPage.java:100)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:823)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.actions.NewExampleAction.run(NewExampleAction.java:123)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Caused by: java.lang.ExceptionInInitializerError
at org.editor.rbpmn.util.RbpmnSwitch.<init>(RbpmnSwitch.java:53)
at org.editor.rbpmn.util.RbpmnAdapterFactory$1.<init>(RbpmnAdapterFactory.java:80)
at org.editor.rbpmn.util.RbpmnAdapterFactory.<init>(RbpmnAdapterFactory.java:80)
at org.editor.rbpmn.provider.RbpmnItemProviderAdapterFactory.<init>(RbpmnItemProviderAdapterFactory.java:70)
at org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.fillItemProviderFactories(RBPMNDiagramEditorPlugin.java:122)
at org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.createAdapterFactory(RBPMNDiagramEditorPlugin.java:114)
at org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.start(RBPMNDiagramEditorPlugin.java:89)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 73 more
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: rbpmn.Common.CommonPackage
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:279)
at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:133)
at org.editor.rbpmn.impl.RbpmnPackageImpl.init(RbpmnPackageImpl.java:260)
at org.editor.rbpmn.RbpmnPackage.<clinit>(RbpmnPackage.java:62)
... 83 more
Caused by: java.lang.ClassNotFoundException: rbpmn.Common.CommonPackage
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:494)
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:272)
... 86 more
Root exception:
... 83 more
... 86 more
When I tracked down the problem it seem to me that the problem is actually with EMF. Then I tried to generate the simple
EMF editor, and the problem remained.
Best regards, Milan
Re: Error validating and converting Ecore model [message #503551 is a reply to message #503528] |
Mon, 14 December 2009 11:52 |
Milan,
You might try removing all the plugin.xmls and regenerating them.
Things like rbpmn.Common.CommonPackage look to be very odd. Is this
really the qualified name of the actual class?
> Dear Mr. Merks,
> file:E:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/Eclipse
> as singleton.
> JavaSE-1.6
> resolved.
> !MESSAGE Bundle
> org.eclipse.jdt.apt.pluggable.core_1.0.201.R35x_v20090818-02 25 [374]
> was not resolved.
> 17:58:36.625
> 17:58:36.625
> 17:58:36.625
> 17:58:36.625
> !MESSAGE Bundle
> resolved.
> was not resolved.
> JavaSE-1.6
> not be available
> !STACK 0
> at
> org.mortbay.jetty.bio.SocketConnector.newServerSocket(Socket Connector.java:80)
> at
> org.mortbay.jetty.bio.SocketConnector.open(SocketConnector.j ava:73)
> at
> org.mortbay.jetty.AbstractConnector.doStart(AbstractConnecto r.java:283)
> at
> org.mortbay.jetty.bio.SocketConnector.doStart(SocketConnecto r.java:147)
> at
> org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCy cle.java:50)
> at
> at
> com.atlassian.connector.eclipse.internal.directclickthrough. ui.DirectClickThroughUiPlugin$2.run(DirectClickThroughUiPlug in.java:88)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> as singleton.
> run GMF diagram:
> org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.start () of
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExtension(WorkbenchWizardElement.java:117)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(WorkbenchWizardElement.java:261)
> at
> org.eclipse.ui.internal.dialogs.NewWizardNewPage$5.createWiz ard(NewWizardNewPage.java:729)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNode.java:151)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNode.java:135)
> at
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizardNode.java:132)
> at
> org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:104)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:100)
> at
> org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:823)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at
> org.eclipse.ui.actions.NewExampleAction.run(NewExampleAction .java:123)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at
> at
> at
> org.editor.rbpmn.provider.RbpmnItemProviderAdapterFactory.<init >(RbpmnItemProviderAdapterFactory.java:70)
> at
> org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.fillI temProviderFactories(RBPMNDiagramEditorPlugin.java:122)
> at
> org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.creat eAdapterFactory(RBPMNDiagramEditorPlugin.java:114)
> at
> org.editor.rbpmn.diagram.part.RBPMNDiagramEditorPlugin.start (RBPMNDiagramEditorPlugin.java:89)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
> ... 73 more
> at
> org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:279)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
> at
> org.editor.rbpmn.impl.RbpmnPackageImpl.init(RbpmnPackageImpl .java:260)
> ... 83 more
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:272)
> ... 86 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 83 more
> at
> at
> at
> at
> at
> at
> at
> at
> ... 86 more
> Best regards, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #504040 is a reply to message #503983] |
Wed, 16 December 2009 21:56 |
Dear Mr. Merks,
yes, that works now, thanks.
However, I have another problem with generating edit code. In my R2ML.ecore I have Primitivetypes package, which consists of some basic primitive DataTypes. And all works fine, however, when I generate GMF diagram code, in RBPMNDiagramEditorPlugin there is a missing reference to:
ca.athabascau.semtech.r2ml.primitivetypes.provider.Primitive typesItemProviderAdapterFactory;
It seems that this class is not generated at all in my edit code. Do you maybe know what is the problem here?
Here are my model files: http://rapidshare.com/files/321815479/model.zip
Best regards, Milan
Re: Error validating and converting Ecore model [message #504134 is a reply to message #504040] |
Thu, 17 December 2009 07:00 |
Milan,
Comments below.
> Dear Mr. Merks,
> to:
What's the value of the GenPackage's Prefix property? Does it contain a
space? That would be bad.
> Best regards, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #504163 is a reply to message #504146] |
Thu, 17 December 2009 14:10 |
Milan,
Comments below.
> Dear Mr. Merks,
> the value of GenModel prefix property is Primitivetypes in my
> genmodel, and there is no spaces.
Is the space in the other post, i.e.,
" ca.athabascau.semtech.r2ml.primitivetypes.provider.Primitive
typesItemProviderAdapterFactory", part of the problem or a copy and
paste glitch? This value comes from the value of the Prefix property
for that package the same way as XyzPackage, XyzFactory for the package.
> btw - my model code for this package is generated properly, however
> ItemProviderAdapterFactory in the edit is not.
That doesn't make so much sense. The space is coming from the Prefix
you've specified like this in GenPackageImpl.
public String getItemProviderAdapterFactoryClassName()
return getPrefixedName("ItemProviderAdapterFactory");
protected String getPrefixedName(String name)
if (getPrefix() != null)
return getPrefix() + name;
return name;
> I also see that one of my packages is genereated in model code like
> this: ca...r2ml.abstract_. It have a bottom line in the end of the
> package name, but I do not know why.
Because abstract is a keyword so using it as a package name would
produce a syntax error.
> However, there are no errors for this packge.
> Best regards, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #504185 is a reply to message #504163] |
Thu, 17 December 2009 15:42 |
Dear Mr. Merks,
Ed Merks wrote on Thu, 17 December 2009 09:10 |
> Dear Mr. Merks,
Yes, I know that. This is a copy-paste glitch. This is correct code:
import ca.athabascau.semtech.r2ml.primitivetypes.provider.PrimitivetypesItemProviderAdapterFactory;
and later in fillItemProviderFactories() method, I have the error on this lane too:
factories.add(new PrimitivetypesItemProviderAdapterFactory());
Ed Merks wrote on Thu, 17 December 2009 09:10 | > btw - my model code for this package is generated properly, however
return name;
Well, In my generated model code I have:
package ca.athabascau.semtech.r2ml.primitivetypes;
and
package ca.athabascau.semtech.r2ml.primitivetypes.impl;
However, when I generate the edit code, it doesn't generate:
ca.athabascau.semtech.r2ml.primitivetypes.provider package and its classes.
Best regards, Milan Milanovic
Re: Error validating and converting Ecore model [message #504191 is a reply to message #504185] |
Thu, 17 December 2009 15:55 |
Milan,
Does it generate the *.edit project at all? Are there errors in the
log? Did you look closely at the values of the Edit category properties
for your model?
> Dear Mr. Merks,
>> > Dear Mr. Merks,
>> > the value of GenModel prefix property is Primitivetypes in my >
>> Is the space in the other post, i.e., "
> import
> this lane too:
>> return name;
> and
> classes.
Ed Merks
Re: Error validating and converting Ecore model [message #504198 is a reply to message #504191] |
Thu, 17 December 2009 16:22 |
Dear Mr. Merks,
Ed Merks wrote on Thu, 17 December 2009 10:55 |
log?
Yes, it does generate edit project correctly. And no, there are no errors in log.
for your model?
Do you mean in genmodel? If so, yes, I haven't changed anything, just generated genmodel from ecore, and then generated model and edit code.
Best regards, Milan
Re: Error validating and converting Ecore model [message #504210 is a reply to message #504198] |
Thu, 17 December 2009 16:58 |
Milan,
Is this just a problem of missing plugin dependencies to help resolve
the imports. Keep in mind that plugin.xml and MANIFEST.MF don't
regenerate once they exist so if you've changed dependencies over time,
you'll need to delete and regenerate them or update them by hand.
> Dear Mr. Merks,
>> log?
> errors in log.
>> for your model?
> Best regards, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #504213 is a reply to message #504210] |
Thu, 17 December 2009 17:14 |
Dear Mr. Merks,
no, it is not a problem. I just start from a clear project, and genmodel: http://rapidshare.com/files/321815479/model.zip. And yes, I delete plugin.xml and manifest.mf before I regenerate my model code.
I generate first, the model code and then the edit code. Later, I also generate diagram code for GMF.
However, ca.athabascau.semtech.r2ml.primitivetypes.provider package and its classes in edit code are missing.
[Updated on: Thu, 17 December 2009 17:15] Report message to a moderator
Re: Error validating and converting Ecore model [message #504216 is a reply to message #504213] |
Thu, 17 December 2009 12:34 |
Milan,
As usual, Rapidshare seems not so rapid; I might have time to look again
tomorrow.
By clear project you mean you've also deleted the underlying projects in
the file system, not just deleted the references to them from the workspace?
> Dear Mr. Merks,
> genmodel: http://rapidshare.com/files/321815479/model.zip And yes, I
Ed Merks
Re: Error validating and converting Ecore model [message #504323 is a reply to message #504232] |
Fri, 18 December 2009 05:32 |
Milan,
It works fine for me.
> Dear Mr. Merks,
> Ed Merks wrote on Thu, 17 December 2009 07:34
>> Milan,
>> again tomorrow.
>> in the file system, not just deleted the references to them from the
>> workspace?
> Yes, I deleted all generated model packages in the file system, as
> well as the edit project.
> Here is a static link to my project:
> http://milan.milanovic.org/model.zip
> Thank you, Milan
Ed Merks
Re: Error validating and converting Ecore model [message #504342 is a reply to message #504337] |
Fri, 18 December 2009 12:16 |
Milan,
Comments below.
> Dear Mr. Merks,
> I'm using Eclipse Modeling Galileo, and EMF which shipped with it,
> v2.5.0.
> So, EMF does not generate ItemProviderAdapterFactory for package which
> does not contain EClasses ? But it generated the model code?
Yes, because the model will have a generated factory for dealing with
the EDataTypes.
> This is O.K. to me, but I don't know why GMF generated
> RBPMNDiagramEditorPlugin say that there is a missing reference to:
> ...r2ml.primitivetypes.provider.Primitive
Me either, but that's not an EMF question. Likely they don't have the
same guard to check that the package has EClasses.
> Thanks, Milan
Ed Merks
Current Time: Fri Apr 26 10:16:38 GMT 2024
Powered by FUDForum. Page generated in 0.07760 seconds
