Home » Modeling » UML2 » statically initialized resource set in "Introduction to UML2 Profiles"(Where is the initialization of RESOURCE_SET?)
statically initialized resource set in "Introduction to UML2 Profiles" [message #493134] Fri, 23 October 2009 06:46 Go to next message
I'm wondering how the RESOURCE_SET is statically initialized in this article:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
Can this be found somewhere? Particularly, I'd like to know how the UML2 metamodel is added to the resource set, so that
resource.getContents()
is nonempty when resource is initialized that way:
URI uri = URI.createURI(UMLResource.UML_METAMODEL_URI);
Resource resource = RESOURCE_SET.getResource(uri, true);
Thanks in advance,
Thomas
[Updated on: Fri, 23 October 2009 06:46] by Moderator
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #493361 is a reply to message #493134] Sun, 25 October 2009 04:15 Go to previous messageGo to next message
Noone knows? Then this is a bug in the article. I'm searching for some sources now, I found no hint in the documentation. It really makes my work stalling.
Please help!
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #494198 is a reply to message #493361] Thu, 29 October 2009 10:48 Go to previous messageGo to next message
Pathmaps are used to locate the metamodel (see registerPathmaps). The
metamodel will get automatically loaded when references to it are resolved.
protected static void registerPathmaps(URI uri) {
URIConverter.URI_MAP.put(URI.createURI(UMLResource.LIBRARIES _PATHMAP),
uri.appendSegment("libraries").appendSegment(""));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.METAMODEL S_PATHMAP),
uri.appendSegment("metamodels").appendSegment(""));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.PROFILES_ PATHMAP),
uri.appendSegment("profiles").appendSegment(""));
- James.
"Thomas Neustupny" <thn-d@gmx.de> wrote in message
news:hc11fs$ho5$1@build.eclipse.org...
> stalling.
> Please help!
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #494588 is a reply to message #494198] Sat, 31 October 2009 14:12 Go to previous messageGo to next message
Thank you very much, James! Your answer helped me to understand what's needed to get the metamodel.
I had to fix two things: I accidently didn't use the resource set where I already added the correct factories and URI mappings, and I didn't added org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar to the run configuration.
Now it works fine. Smile
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #628007 is a reply to message #493134] Sun, 25 October 2009 04:15 Go to previous messageGo to next message
Please help!
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #628013 is a reply to message #628007] Thu, 29 October 2009 10:50 Go to previous messageGo to next message
- James.
> stalling.
> Please help!
Re: statically initialized resource set in "Introduction to UML2 Profiles" [message #628024 is a reply to message #628013] Sat, 31 October 2009 14:12 Go to previous message
Now it works fine. :)
Previous Topic:(eObject instanceof Element) in destroy() method
Next Topic:UML2 genmodel properties for EClasses
Current Time: Wed Nov 05 09:40:52 EST 2025
Powered by FUDForum. Page generated in 0.07185 seconds
