Home » Newcomers » Newcomers » eclipse hung on restart after plugin install, various errors in .metadata/.log
eclipse hung on restart after plugin install, various errors in .metadata/.log [message #490227] |
Wed, 07 October 2009 23:44 |
David M. Karr Messages: 802 Registered: July 2009 |
Using Eclipse 3.5.1.
I've been working fine for quite a while, occasionally installing new plugins.
I had recently installed eUML2 (free edition), and it appeared to be ok.
I just reinstalled PMD (I had it installed at one time, then uninstalled it), and when I restarted, the main window was displayed, but then the watch cursor appeared and never went away. I brought up task manager, and Eclipse wasn't spinning, so it's hung somehow. I'm completely dead until I resolve this. Restarting Eclipse doesn't help.
The following is an excerpt from my .metadata/.log file. I don't know which of these errors is relevant to this.
!ENTRY org.eclipse.osgi 2 0 2009-10-07 16:26:36.228
!MESSAGE While loading class "org.maven.ide.eclipse.project.MavenProjectManager", thread " Thread[org.eclipse.jdt.internal.ui.text.JavaReconciler,1,mai n] " timed out waiting (5000ms) for thread "Thread[main,6,main]" to finish starting bundle "org.maven.ide.eclipse_0.9.8.200905041413 [895]". To avoid deadlock, thread " Thread[org.eclipse.jdt.internal.ui.text.JavaReconciler,1,mai n] " is proceeding but "org.maven.ide.eclipse.project.MavenProjectManager" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle " reference:file:plugins/org.maven.ide.eclipse_0.9.8.200905041 413.jar " by thread "main".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1073)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:278)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
[deleted]
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 57 more
Root exception:
[deleted]
!ENTRY org.eclipse.osgi 4 0 2009-10-07 16:26:36.244
!MESSAGE An error occurred while automatically activating bundle org.maven.ide.eclipse.jdt (901).
!STACK 0
org.osgi.framework.BundleException: Exception in org.maven.ide.eclipse.jdt.MavenJdtPlugin.start() of bundle org.maven.ide.eclipse.jdt.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
[deleted]
at org.maven.ide.eclipse.jdt.MavenJdtPlugin.start(MavenJdtPlugi n.java:80)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
... 39 more
Root exception:
[deleted]
!ENTRY org.eclipse.jdt.core 4 2 2009-10-07 16:26:36.244
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jdt.core".
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.maven.ide.eclipse.jdt was unable to load class org.maven.ide.eclipse.jdt.internal.JDTCompilationParticipant .
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
[deleted]
Caused by: org.osgi.framework.BundleException: Exception in org.maven.ide.eclipse.jdt.MavenJdtPlugin.start() of bundle org.maven.ide.eclipse.jdt.
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 34 more
... 39 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-10-07 16:26:36.244
!MESSAGE Plug-in org.maven.ide.eclipse.jdt was unable to load class org.maven.ide.eclipse.jdt.internal.JDTCompilationParticipant .
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.maven.ide.eclipse.jdt (901).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
[deleted]
... 34 more
... 39 more
!STACK 0
[deleted]
... 34 more
... 39 more
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-07 16:26:39.104
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-07 16:26:39.104
!MESSAGE Conflict for 'AUTOGEN:::com.soyatec.uml.std.ui.check.diagram/com.soyatec. uml.std.ui.actions.check.diagram':
HandlerActivation(commandId=AUTOGEN:::com.soyatec.uml.std.ui .check.diagram/com.soyatec.uml.std.ui.actions.check.diagram,
handler=ActionDelegateHandlerProxy(null,com.soyatec.uml.std. external.UMLCheckDiagramAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1879b),sourcePriority=16384)
!ENTRY org.maven.ide.eclipse 4 0 2009-10-07 16:26:42.791
!MESSAGE Unable to update index for http://repo1.maven.org/maven2/
!STACK 1
org.eclipse.core.runtime.CoreException: Error updating index
at org.maven.ide.eclipse.internal.index.NexusIndexManager.fetch AndUpdateIndex(NexusIndexManager.java:547)
at org.maven.ide.eclipse.index.IndexManager$UpdateCommand.run(I ndexManager.java:427)
at org.maven.ide.eclipse.index.IndexManager$IndexUpdaterJob.run (IndexManager.java:561)
Caused by: java.io.IOException: Not in GZIP format
at java.util.zip.GZIPInputStream.readHeader(GZIPInputStream.jav a:137)
at java.util.zip.GZIPInputStream.<init>(GZIPInputStream.java:58)
at org.sonatype.nexus.index.updater.IndexDataReader.<init>(IndexDataReader.java:40)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.unpackI ndexData(DefaultIndexUpdater.java:511)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.loadInd exDirectory(DefaultIndexUpdater.java:219)
at org.sonatype.nexus.index.updater.DefaultIndexUpdater.fetchAn dUpdateIndex(DefaultIndexUpdater.java:134)
at org.maven.ide.eclipse.internal.index.NexusIndexManager.fetch AndUpdateIndex(NexusIndexManager.java:533)
... 3 more
!SUBENTRY 1 org.maven.ide.eclipse 4 -1 2009-10-07 16:26:42.791
!MESSAGE Error updating index
!STACK 0
!ENTRY org.eclipse.equinox.p2.updatesite 4 0 2009-10-07 16:27:08.121
!MESSAGE Error reading feature file:/C:/frameworks/eUML2FreeEdition/features/com.soyatec.eu ml2.doc_3.4.0.20090716.jar.
[Updated on: Wed, 07 October 2009 23:45] Report message to a moderator
Re: eclipse hung on restart after plugin install, various errors in .metadata/.log [message #490231 is a reply to message #490227] |
Thu, 08 October 2009 00:19 |
I was able to set the "-data" command line argument to make it open a different workspace at startup (strange, I always thought that argument was "-workspace"). With that, I was able to get it to start up, and I was able to uninstall several suspect plugins, like eUML2, maven, and PMD. After then switching back to the regular workspace, it still hangs at startup.
Now the contents of my .log file is completely inoccuous, even though it's still hanging.
Any suggestions before I spend the next couple of hours manually reconstructing my workspace?
!SESSION 2009-10-07 17:12:30.875 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_16
Framework arguments: --launcher.XXMaxPermSize 512M --launcher.XXMaxPermSize 512m -product org.eclipse.epp.package.jee.product -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 --launcher.XXMaxPermSize 512M --launcher.XXMaxPermSize 512m -product org.eclipse.epp.package.jee.product -showlocation -data C:\Documents and Settings\dk068x\workspace2
!ENTRY org.eclipse.ui 2 0 2009-10-07 17:12:33.609
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2009-10-07 17:12:33.609
!MESSAGE Commands should really have a category: plug-in='com.mulgasoft.emacsplus', id='com.mulgasoft.emacsplus.backwardKillLine', categoryId='Uncategorized'
!MESSAGE Commands should really have a category: plug-in='com.mulgasoft.emacsplus', id='com.mulgasoft.emacsplus.killLine', categoryId='Uncategorized'
!MESSAGE Commands should really have a category: plug-in='com.mulgasoft.emacsplus', id='com.mulgasoft.emacsplus.backwardDeleteLine', categoryId='Uncategorized'
!ENTRY org.eclipse.core.net 1 0 2009-10-07 17:12:40.265
!MESSAGE System property http.proxyHost is not set but should be ...
!MESSAGE System property http.proxyPort is not set but should be ...
!MESSAGE System property https.proxyHost is not set but should be ...
!MESSAGE System property https.proxyPort is not set but should be ...
Re: eclipse hung on restart after plugin install, various errors in .metadata/.log [message #490240 is a reply to message #490231] |
Thu, 08 October 2009 01:37 |
Walter Harley Messages: 847 Registered: July 2009 |
> at startup.
> it's still hanging.
As Dani said in a post two days ago with approximately the same subject line...
"Create a VM dump (see:
http://wiki.eclipse.org/index.php/How_to_report_a_deadlock) and post it here
and/or file a bug report and attach it there."
Re: eclipse hung on restart after plugin install, various errors in .metadata/.log [message #490381 is a reply to message #490240] |
Thu, 08 October 2009 13:56 |
I'll create a case for this a little later this morning, but here is the thread dump after it hit the deadlock state (it's 50k, which is larger than the attachment limit).
d dump Java HotSpot(TM) Client VM (14.2-b01 mixed mode):
"pool-2-thread-4" prio=6 tid=0x58837800 nid=0x14dc waiting on condition [0x5b2cf000]
java.lang.Thread.State: TIMED_WAITING (parking)
at sun.misc.Unsafe.park(Native Method)
- parking to wait for <0x0c0aaf18> (a java.util.concurrent.SynchronousQueue$TransferStack)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport .java:198)
at java.util.concurrent.SynchronousQueue$TransferStack.awaitFul fill(SynchronousQueue.java:424)
at java.util.concurrent.SynchronousQueue$TransferStack.transfer (SynchronousQueue.java:323)
at java.util.concurrent.SynchronousQueue.poll(SynchronousQueue. java:874)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:945)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
Locked ownable synchronizers:
- None
"pool-2-thread-3" prio=6 tid=0x58817800 nid=0x2c20 waiting on condition [0x5b27f000]
- None
"JMX server connection timeout 58" daemon prio=6 tid=0x58361400 nid=0x1ac0 in Object.wait() [0x5b22f000]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
- waiting on <0x03620088> (a [I)
at com.sun.jmx.remote.internal.ServerCommunicatorAdmin$Timeout. run(ServerCommunicatorAdmin.java:150)
- locked <0x03620088> (a [I)
- None
"RMI Scheduler(0)" daemon prio=6 tid=0x582df800 nid=0x2c14 waiting on condition [0x5b1df000]
- parking to wait for <0x03620110> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.awaitNanos(AbstractQueuedSynchronizer.java:1963)
at java.util.concurrent.DelayQueue.take(DelayQueue.java:164)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:583)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:576)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:947)
- None
"RMI TCP Connection(1)-192.168.1.21" daemon prio=6 tid=0x583fd000 nid=0x1344 runnable [0x5b18f000]
java.lang.Thread.State: RUNNABLE
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:129)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:21 8)
at java.io.BufferedInputStream.read(BufferedInputStream.java:23 7)
- locked <0x036222c8> (a java.io.BufferedInputStream)
at java.io.FilterInputStream.read(FilterInputStream.java:66)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:517)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
- <0x0364fa68> (a java.util.concurrent.locks.ReentrantLock$NonfairSync)
"RMI TCP Accept-0" daemon prio=6 tid=0x5766ec00 nid=0x2674 runnable [0x59f7f000]
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:390)
- locked <0x03622568> (a java.net.SocksSocketImpl)
at java.net.ServerSocket.implAccept(ServerSocket.java:453)
at java.net.ServerSocket.accept(ServerSocket.java:421)
at sun.management.jmxremote.LocalRMIServerSocketFactory$1.accep t(LocalRMIServerSocketFactory.java:34)
at sun.rmi.transport.tcp.TCPTransport$AcceptLoop.executeAcceptL oop(TCPTransport.java:369)
at sun.rmi.transport.tcp.TCPTransport$AcceptLoop.run(TCPTranspo rt.java:341)
- None
"Worker-10" prio=6 tid=0x588c5400 nid=0x604 in Object.wait() [0x5adff000]
- waiting on <0x08639e30> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0x08639e30> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
- None
"Worker-9" prio=6 tid=0x5746a400 nid=0x20c8 in Object.wait() [0x5af3f000]
- None
"Worker-8" prio=6 tid=0x58601400 nid=0xe84 in Object.wait() [0x5ae9f000]
- None
"SVN Kit 1.2 Connector" prio=6 tid=0x57808400 nid=0x2fa8 in Object.wait() [0x5aeef000]
java.lang.Thread.State: WAITING (on object monitor)
- waiting on <0x0c0aaf00> (a java.util.ArrayList)
at java.lang.Object.wait(Object.java:485)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector$Progr essMonitorThread.run(SVNKitConnector.java:1629)
- locked <0x0c0aaf00> (a java.util.ArrayList)
- None
"Thread-17" daemon prio=6 tid=0x5856cc00 nid=0x1bac in Object.wait() [0x5ad4f000]
- waiting on <0x0c0ab918> (a org.apache.commons.httpclient.util.IdleConnectionTimeoutThre ad)
at org.apache.commons.httpclient.util.IdleConnectionTimeoutThre ad.run(IdleConnectionTimeoutThread.java:108)
- locked <0x0c0ab918> (a org.apache.commons.httpclient.util.IdleConnectionTimeoutThre ad)
- None
"Provisioning Event Dispatcher" daemon prio=6 tid=0x58806400 nid=0x2274 in Object.wait() [0x5a6af000]
- waiting on <0x0c004eb0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:393)
- locked <0x0c004eb0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:333)
- None
"MultiThreadedHttpConnectionManager cleanup" daemon prio=6 tid=0x586a6400 nid=0x2f20 in Object.wait() [0x59edf000]
- waiting on <0x0bfdea60> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:118)
- locked <0x0bfdea60> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:134)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$ReferenceQueueThread.run(MultiThreadedHttpConnectionMan ager.java:1122)
- None
"Thread-13" prio=6 tid=0x58146400 nid=0x1268 waiting on condition [0x5a45f000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at oracle.eclipse.tools.weblogic.j2eelib.LibraryModuleRegistry$ LibraryArchiveChangeMonitor.run(LibraryModuleRegistry.java:4 69)
- None
"Thread-12" prio=6 tid=0x58759400 nid=0x17c0 in Object.wait() [0x5a40f000]
- waiting on <0x0b5998c0> (a java.util.LinkedList)
at oracle.eclipse.tools.weblogic.syslib.internal.SystemLibrarie sContainerImpl$ContainersRefresherThread.getProjectFromQueue (SystemLibrariesContainerImpl.java:432)
- locked <0x0b5998c0> (a java.util.LinkedList)
at oracle.eclipse.tools.weblogic.syslib.internal.SystemLibrarie sContainerImpl$ContainersRefresherThread.run(SystemLibraries ContainerImpl.java:457)
- None
"WebLogic Server Monitor [B2C@localhost:7001Version:10.0.1.0]" daemon prio=6 tid=0x5707c800 nid=0x1c28 runnable [0x5a06f000]
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
- locked <0x02e1d2e8> (a java.net.SocksSocketImpl)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at oracle.eclipse.tools.weblogic.server.internal.WeblogicServer Behaviour.validatePingable(WeblogicServerBehaviour.java:2512 )
at oracle.eclipse.tools.weblogic.server.internal.ServerWatcher. runOnce(ServerWatcher.java:558)
at oracle.eclipse.tools.weblogic.server.internal.ServerWatcher. run(ServerWatcher.java:482)
- None
"WebLogic Server Monitor [1031domain@localhost:8001Version:10.3.1.0]" daemon prio=6 tid=0x5828c000 nid=0xd64 runnable [0x5a01f000]
- locked <0x02e1f530> (a java.net.SocksSocketImpl)
- None
"Thread-8" prio=6 tid=0x58638000 nid=0x1dfc in Object.wait() [0x59f2f000]
- waiting on <0x0b3a8ea8> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:186)
- locked <0x0b3a8ea8> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4312)
at oracle.eclipse.tools.common.ui.util.SwtUtil.hasModalShell(Sw tUtil.java:206)
at oracle.eclipse.tools.common.ui.util.SwtUtil.waitOnModalShell s(SwtUtil.java:235)
at oracle.eclipse.tools.common.upgrade.internal.UpgradeFramewor kImpl$CheckerThread.run(UpgradeFrameworkImpl.java:789)
- None
"Worker-7" prio=6 tid=0x5748f800 nid=0x1d70 in Object.wait() [0x59e7f000]
- None
"Worker-6" prio=6 tid=0x583d8800 nid=0x15a0 in Object.wait() [0x59e2f000]
- None
"Worker-5" prio=6 tid=0x5783b000 nid=0x1a14 in Object.wait() [0x59ddf000]
- None
"Worker-4" prio=6 tid=0x5768a800 nid=0xbe4 in Object.wait() [0x59d8f000]
- waiting on <0x0c154e28> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.core.internal.jobs.Semaphore.acquire(Semaphore.j ava:38)
- locked <0x0c154e28> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.core.internal.jobs.OrderedLock.doAcquire(Ordered Lock.java:168)
at org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLo ck.java:105)
at org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLo ck.java:82)
at org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:118)
at org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1747)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1795)
at org.eclipse.team.svn.core.utility.ProgressMonitorUtility$1.r un(ProgressMonitorUtility.java:58)
- None
"Worker-3" prio=6 tid=0x585f4800 nid=0x2230 in Object.wait() [0x5811f000]
- waiting on <0x0887b4d8> (a java.lang.Object)
at org.eclipse.core.internal.jobs.ThreadJob.joinRun(ThreadJob.j ava:187)
- locked <0x0887b4d8> (a java.lang.Object)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:87)
at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:232)
at oracle.eclipse.tools.webservices.ui.decorators.WebServiceDec orator.isWebService(WebServiceDecorator.java:39)
at oracle.eclipse.tools.webservices.ui.decorators.WebServiceDec orator.decorate(WebServiceDecorator.java:24)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:263)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:365)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:371)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:331)
- None
"Worker-2" prio=6 tid=0x57728800 nid=0x15a8 in Object.wait() [0x580cf000]
- waiting on <0x0b6b8c58> (a org.eclipse.core.internal.jobs.Semaphore)
- locked <0x0b6b8c58> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAll Containers(JavaModelManager.java:2554)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathC ontainer(JavaModelManager.java:1773)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore .java:2652)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2578)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2679)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1866)
at org.eclipse.jdt.internal.core.JavaProject.buildStructure(Jav aProject.java:424)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:258)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:515)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:252)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:238)
at org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaEl ement.java:193)
at org.eclipse.jdt.internal.core.JavaProject.getPackageFragment Roots(JavaProject.java:1761)
at org.eclipse.jst.j2ee.internal.project.J2EEProjectUtilities.g etSourceContainers(J2EEProjectUtilities.java:858)
at org.eclipse.jst.j2ee.internal.project.J2EEProjectUtilities.g etOutputContainers(J2EEProjectUtilities.java:895)
at org.eclipse.jst.j2ee.internal.project.J2EEProjectUtilities.g etAllOutputContainers(J2EEProjectUtilities.java:931)
at org.eclipse.jst.j2ee.internal.classpathdep.ClasspathDependen cyValidator$ClasspathDependencyValidatorData. <init>(ClasspathDependencyValidator.java:222)
at org.eclipse.jst.j2ee.classpathdep.ClasspathDependencyUtil.ge tComponentClasspathDependencies(ClasspathDependencyUtil.java :266)
at org.eclipse.jst.j2ee.classpathdep.ClasspathDependencyUtil.ge tComponentClasspathDependencies(ClasspathDependencyUtil.java :247)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponen t.getJavaClasspathReferences(J2EEModuleVirtualComponent.java :199)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponen t.getNonManifestReferences(J2EEModuleVirtualComponent.java:1 33)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponen t.getReferences(J2EEModuleVirtualComponent.java:100)
at org.eclipse.jst.j2ee.componentcore.J2EEModuleVirtualComponen t.getReferences(J2EEModuleVirtualComponent.java:96)
at org.eclipse.wst.common.componentcore.internal.builder.Depend encyGraphImpl$GraphUpdateJob$1.run(DependencyGraphImpl.java: 324)
at org.eclipse.wst.common.componentcore.internal.builder.Depend encyGraphImpl$GraphUpdateJob.run(DependencyGraphImpl.java:29 9)
- None
"Worker-1" prio=6 tid=0x56c25400 nid=0x344 in Object.wait() [0x5807e000]
- waiting on <0x0c005b68> (a org.eclipse.core.internal.jobs.Semaphore)
- locked <0x0c005b68> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.jst.common.jdt.internal.classpath.FlexibleProjec tContainer.computeClasspathEntries(FlexibleProjectContainer. java:181)
at org.eclipse.jst.common.jdt.internal.classpath.FlexibleProjec tContainer. <init>(FlexibleProjectContainer.java:122)
at org.eclipse.jst.j2ee.internal.web.classpath.WebAppLibrariesC ontainer. <init>(WebAppLibrariesContainer.java:48)
at org.eclipse.jst.j2ee.internal.web.classpath.WebAppLibrariesC ontainerInitializer.initialize(WebAppLibrariesContainerIniti alizer.java:34)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeCon tainer(JavaModelManager.java:2608)
at org.eclipse.jdt.internal.core.JavaModelManager$11.run(JavaMo delManager.java:2514)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.jdt.core.JavaCore.initializeAfterLoad(JavaCore.j ava:3410)
at org.eclipse.jdt.internal.ui.InitializeAfterLoadJob$RealJob.r un(InitializeAfterLoadJob.java:35)
- None
"[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x582c2800 nid=0x27c0 in Object.wait() [0x5945f000]
- waiting on <0x0a18f0f8> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or.run(Executor.java:106)
- locked <0x0a18f0f8> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
- None
"JavaScript indexing" daemon prio=4 tid=0x585ef400 nid=0x1ed0 in Object.wait() [0x5940f000]
- waiting on <0x0a18f1e0> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
at org.eclipse.wst.jsdt.internal.core.search.processing.JobMana ger.run(JobManager.java:370)
- locked <0x0a18f1e0> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
- None
"org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon prio=2 tid=0x56c2ac00 nid=0x29e8 in Object.wait() [0x58faf000]
- waiting on <0x09c3b340> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
at org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:179)
- locked <0x09c3b340> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
- None
"Java indexing" daemon prio=4 tid=0x57662400 nid=0x2524 in Object.wait() [0x58f0f000]
- waiting on <0x09909f70> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:378)
- locked <0x09909f70> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
- None
"Bundle File Closer" daemon prio=6 tid=0x57655800 nid=0x2be0 in Object.wait() [0x5898f000]
- waiting on <0x0977a138> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x0977a138> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Worker-0" prio=6 tid=0x56c4a800 nid=0x1110 in Object.wait() [0x5802e000]
- waiting on <0x0c005d20> (a org.eclipse.core.internal.jobs.Semaphore)
- locked <0x0c005d20> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.core.internal.jobs.JobManager.join(JobManager.ja va:737)
at org.eclipse.core.internal.jobs.InternalJob.join(InternalJob. java:344)
at org.eclipse.core.runtime.jobs.Job.join(Job.java:384)
at org.eclipse.wst.common.componentcore.internal.builder.Depend encyGraphImpl.waitForAllUpdates(DependencyGraphImpl.java:471 )
at org.eclipse.wst.common.componentcore.internal.builder.Depend encyGraphImpl.getReferencingComponents(DependencyGraphImpl.j ava:76)
at org.eclipse.wst.common.componentcore.internal.builder.Depend encyGraph.getReferencingComponents(DependencyGraph.java:30)
at org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent.getReferencingComponents(VirtualComponent.java: 437)
at org.eclipse.jst.j2ee.internal.common.classpath.J2EEComponent ClasspathContainer.getBaseEARLibRefs(J2EEComponentClasspathC ontainer.java:315)
at org.eclipse.jst.j2ee.internal.common.classpath.J2EEComponent ClasspathContainer.update(J2EEComponentClasspathContainer.ja va:211)
at org.eclipse.jst.j2ee.internal.common.classpath.J2EEComponent ClasspathContainer.install(J2EEComponentClasspathContainer.j ava:351)
at org.eclipse.jst.j2ee.internal.common.classpath.J2EEComponent ClasspathInitializer.initialize(J2EEComponentClasspathInitia lizer.java:29)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAll Containers(JavaModelManager.java:2552)
at org.eclipse.jdt.internal.core.ClasspathChange.generateDelta( ClasspathChange.java:218)
at org.eclipse.jdt.internal.core.DeltaProcessor.resourceChanged (DeltaProcessor.java:1916)
at org.eclipse.jdt.internal.core.DeltaProcessingState.resourceC hanged(DeltaProcessingState.java:470)
at org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:313)
at org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:1022)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1809)
at org.eclipse.core.internal.events.NotificationManager$NotifyJ ob.run(NotificationManager.java:40)
- None
"[Timer] - Main Queue Handler" daemon prio=6 tid=0x574e8800 nid=0x2bf8 in Object.wait() [0x578ef000]
- waiting on <0x08697740> (a java.lang.Object)
at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.r un(TimerImpl.java:141)
- locked <0x08697740> (a java.lang.Object)
- None
"Framework Event Dispatcher" daemon prio=6 tid=0x5705e800 nid=0x1328 in Object.wait() [0x5742f000]
- waiting on <0x0862ed20> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x0862ed20> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Start Level Event Dispatcher" daemon prio=6 tid=0x5704a000 nid=0x2a04 in Object.wait() [0x5732f000]
- waiting on <0x08541428> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x08541428> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"State Data Manager" daemon prio=6 tid=0x57051800 nid=0x2b64 waiting on condition [0x572df000]
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:306)
- None
"Low Memory Detector" daemon prio=6 tid=0x56c21000 nid=0x2e7c runnable [0x00000000]
- None
"CompilerThread0" daemon prio=10 tid=0x56c1bc00 nid=0x1978 waiting on condition [0x00000000]
- None
"Attach Listener" daemon prio=10 tid=0x56c19400 nid=0x2bf0 waiting on condition [0x00000000]
- None
"Signal Dispatcher" daemon prio=10 tid=0x56c18000 nid=0x2a0 runnable [0x00000000]
- None
"Finalizer" daemon prio=8 tid=0x56c09000 nid=0x1f18 in Object.wait() [0x56d7f000]
- waiting on <0x0830ce20> (a java.lang.ref.ReferenceQueue$Lock)
- locked <0x0830ce20> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 59)
- None
"Reference Handler" daemon prio=10 tid=0x56c04400 nid=0x29cc in Object.wait() [0x56d2f000]
- waiting on <0x0830cea8> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 116)
- locked <0x0830cea8> (a java.lang.ref.Reference$Lock)
- None
"main" prio=6 tid=0x00396c00 nid=0x22f4 in Object.wait() [0x003fe000]
- waiting on <0x0b96f570> (a org.eclipse.core.internal.jobs.Semaphore)
- locked <0x0b96f570> (a org.eclipse.core.internal.jobs.Semaphore)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1899)
at org.springframework.ide.eclipse.core.java.JdtUtils.addClassP athUrls(JdtUtils.java:150)
at org.springframework.ide.eclipse.core.java.JdtUtils.getClassP athUrls(JdtUtils.java:417)
at org.springframework.ide.eclipse.core.java.JdtUtils.getClassL oader(JdtUtils.java:378)
at org.springframework.ide.eclipse.core.java.JdtUtils.getClassL oader(JdtUtils.java:362)
at org.springframework.ide.eclipse.core.io.EclipsePathMatchingR esourcePatternResolver. <init>(EclipsePathMatchingResourcePatternResolver.java:59)
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansConfig.readConfig(BeansConfig.java:265)
at org.springframework.ide.eclipse.beans.core.internal.model.Ab stractBeansConfig.getImports(AbstractBeansConfig.java:479)
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansProject.checkForImportedBeansConfig(BeansProject.java:425 )
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansProject.getConfigs(BeansProject.java:409)
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansProject.getConfig(BeansProject.java:387)
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansModel.getConfig(BeansModel.java:202)
at org.springframework.ide.eclipse.beans.core.internal.model.Be ansModel.getConfig(BeansModel.java:188)
at org.springframework.ide.eclipse.beans.ui.navigator.BeansNavi gatorLinkHelper.findSelection(BeansNavigatorLinkHelper.java: 82)
at org.eclipse.ui.navigator.LinkHelperService.getSelectionFor(L inkHelperService.java:126)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$3 .run(LinkEditorAction.java:99)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$2 .runInUIThread(LinkEditorAction.java:89)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
- locked <0x0b178d18> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
- None
"VM Thread" prio=10 tid=0x56c00400 nid=0x2b5c runnable
"VM Periodic Task Thread" prio=10 tid=0x56c23000 nid=0x2028 waiting on condition
JNI global references: 1493
[Updated on: Thu, 08 October 2009 13:57] Report message to a moderator
Current Time: Fri Apr 26 09:30:04 GMT 2024
Powered by FUDForum. Page generated in 0.09168 seconds
