Re: rptdocument access is denied [message #484221 is a reply to message #484026] |
Fri, 04 September 2009 16:01 |
Brian,
Can you log a bugzilla entry for this? This may have been fixed in a
later version.
Jason
Brian Kallay wrote:
> The environment:
> -Windows XP 64
> -Orion 2.0.7
> -BIRT 2.1.1 + using the BIRT Viewer for report display
> The issue:
> BIRT reports work fine on this server for about a week (load varies
> throughout the day but during high volume times assume 1-2 report
> requests per minute) but at some point we get the following exception:
> AxisFault
> faultCode: ReportEngineService.runReport( )
> faultSubcode:
> faultString:
> D:\apps\BuildingCenter\BC412_45\buildingcenter\birtdesigns\s tandard\workorder\WorkOrder_Dispatch1251746342422PDGBMCDOJJL D.rptdocument.tmpfolder\.reader.count
> (Access is denied)
> faultActor:
> faultNode:
> faultDetail:
> {http://xml.apache.org/axis/}stackTrace:D:\apps\APP_SERVER_R OOT\birtdesigns\standard\workorder\OUR_REPORT1251746342422PD GBMCDOJJLD.rptdocument.tmpfolder\.reader.count
> (Access is denied)
> Upon investigating the directory where the temporary folders get created
> it is clear that at some point these are not getting removed. It
> appears that under normal execution these folders are created and
> deleted as the engine generates the rptdocument file. I have also
> noticed some .lck files on rptdocument files existing in this directory
> when the issue arises which i do not normally see. We use a millisecond
> timestamp + session id for unique naming of the rptdocument file.
> Any ideas on what might cause this scenario and how to resolve it?
> Upgrading from 2.1.1 for this server is not an option.
> thanks,
> Brian
FUDForum. Page generated in 0.02839 seconds
