Home » Modeling » EMF » Need information to override the default validation function body
Need information to override the default validation function body [message #479006] Fri, 07 August 2009 19:25 Go to next message
I created an eCore and assigned annotation on the EClass to generate the
validation. (Example Class1 with Key=constrains, value=data)
The EMF generates the generic PackageValidator.java class and has a
method to validate the class for example:
validateClass1_data (Class1 class1, DiagnosticChain diagnostics,
Map<Object, Object> context);
Is there a way to supply a generic implementation for the body of this
method? and not get the default implementation that does nothing.
I tried to use the generation example and merge this class with a class
I created that only have the method I want to supply the body for, but
it overrides all the other methods and attributes and remove them.
Can you direct me to a way I can generate the body during the EMF Model
generation?
Thanks Yigal.
Re: Need information to override the default validation function body [message #479072 is a reply to message #479006] Sat, 08 August 2009 16:40 Go to previous messageGo to next message
--------------070908000603070301070306
Yigal,
Comments below.
> the validation. (Example Class1 with Key=constrains, value=data)
> method?
No.
No.
> class I created that only have the method I want to supply the body
> for, but it overrides all the other methods and attributes and remove
> them.
> Model generation?
There isn't currently a way to do that with a named constraint. You
must modify the generated validator class. There's work being done on
which might change the story:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
> Thanks Yigal.
<html>
<head>
<title></title>
</head>
Yigal,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite">I
&nbsp;validation. (Example Class1 with Key=constrains, value=data)
<br>
<br>
Map&lt;Object, Object&gt; context);
<br>
<br>
method?</blockquote>
No.<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite"> and
<br>
</blockquote>
No.<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite"><br>
<br>
<br>
generation?
<br>
</blockquote>
There isn't currently a way to do that with a named constraint.&nbsp; You
must modify the generated validator class.&nbsp; There's work being done on
which might change the story:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</a><br>
</blockquote>
Thanks Yigal.
<br>
</blockquote>
</body>
</html>
--------------070908000603070301070306--
Re: Need information to override the default validation function body [message #479122 is a reply to message #479072] Sun, 09 August 2009 11:30 Go to previous messageGo to next message
Hi Ed,
Thanks for the reply. I copied the ValidatorClass.javajet template and
add it to my simple plugin (I used the example to add validator
generation that comes with the product).
I modified the template with some changes and it built the java class.
When I run the EMF generation it does not pick the new Jet generation
from my plugin.
I changed in the genmodel the flag for dynamic generation to "true" and
put the my plugin templates directory, but that did not help either.
How can I override the ValidatorClass.java so I can get my code in?
Yigal
Ed Merks wrote:
> Yigal,
> Comments below.
>> method?
> No.
> No.
>> them.
>> Model generation?
>> Thanks Yigal.
Re: Need information to override the default validation function body [message #479123 is a reply to message #479122] Sun, 09 August 2009 11:47 Go to previous messageGo to next message
--------------090709090801040904060604
Yigal,
Did you do these steps?
http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F
> Hi Ed,
> and add it to my simple plugin (I used the example to add validator
> from my plugin.
> and put the my plugin templates directory, but that did not help either.
> Thanks
> Yigal
> Ed Merks wrote:
>> Yigal,
>> Comments below.
>>> this method?
>> No.
>> No.
>>> remove them.
>>> Model generation?
>> on which might change the story:
>>> Thanks Yigal.
<html>
<head>
</head>
Yigal,<br>
<br>
Did you do these steps?<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F"> http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F</a><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:h5mq3p$bui$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
Thanks for the reply.&nbsp; I copied the ValidatorClass.javajet template and
<br>
<br>
from my plugin.
<br>
<br>
<br>
<br>
<br>
Yigal
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Yigal,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">I created an eCore and assigned annotation
on the EClass to generate the&nbsp; validation. (Example Class1 with
<br>
<br>
<br>
<br>
method?
<br>
</blockquote>
No.
<br>
<blockquote type="cite">and not get the default implementation that
does nothing.
<br>
</blockquote>
No.
<br>
<blockquote type="cite"><br>
<br>
<br>
generation?
<br>
</blockquote>
<br>
<br>
&nbsp;&nbsp;&nbsp; <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</a>
<br>
<br>
Thanks Yigal.
<br>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090709090801040904060604--
Re: Need information to override the default validation function body [message #479632 is a reply to message #479123] Tue, 11 August 2009 15:00 Go to previous messageGo to next message
Hi Ed,
I followed the instruction on the page and I have 2 new issues.
1. The override template MUST be in the target project. I would like to
create a plugin that has the override templates and let the developer
point to the set of overrides to use.
2. My plugin that has the additional generation functionality (based on
the EMF example of generation validation) does not work any more because
the process tries to dynamically compile the templates but it can not find
them any where.
I stepped through the code and it uses URI in current project or the EMF
codegen plugin and my templates are in neither.
I think this is a bug, since the code should use the plugin ID to get the
bundle and find the file in the bundle and then the dynamic compile will
work.
Yigal
Re: Need information to override the default validation function body [message #479633 is a reply to message #479632] Tue, 11 August 2009 15:17 Go to previous messageGo to next message
Yigal,
Comments below.
> Hi Ed,
> to create a plugin that has the override templates and let the
> developer point to the set of overrides to use.
If the path contains a ":" it will be treated as a URI, so one could use
platform:/plugin/<plugin-id>/templates.... if the templates are in that
binary plugin. If I recall correctly, we even look for compiled
versions (.classes) of the templates in that case...
> on the EMF example of generation validation) does not work any more
> because the process tries to dynamically compile the templates but it
> can not find them any where.
> EMF codegen plugin and my templates are in neither.
Maybe you need to set the Template Plugin Variables for the dependencies
your templates drag in?
> the bundle and find the file in the bundle and then the dynamic
> compile will work.
I'm not sure what you're referring to here...
> Yigal
Re: Need information to override the default validation function body [message #480066 is a reply to message #479633] Thu, 13 August 2009 12:27 Go to previous messageGo to next message
Hi Ed,
Thanks for the information it was very helpful. I was able to override
the EMF templates and run my own templates.
I found out that the best configuration is to put the ENF override
templates in a separate directory then my templates.
I'm glade the newsgroup works so well to get answers, otherwise there no
other source.
In you answer you indicated that the dynamic architecture uses the
*.class. But while debugging the code I did not find any evidence for it
and the architecture recompiles the templates every time. It recompiles
my generation templates as well even if they are in a separate directory.
This is fine except it increases the generation time.
Yigal.
Re: Need information to override the default validation function body [message #480068 is a reply to message #480066] Thu, 13 August 2009 12:47 Go to previous message
Yigal,
Yes, I'm trying to remember where that stuff is...
In JETEmitter's EclipseHelper.initialize method there's logic for
else if (templateURI.isPlatformPlugin())
So if the template path is a URI of the form
platform:/plugin/<plugin-id>/ then it will use the templates target java
class/file name to look up the .class in that bundle. So if you compile
the templates in a project with a JET nature then you (your clients)
will be able to load those precompiled templates.
> Hi Ed,
> override the EMF templates and run my own templates.
> no other source.
> it and the architecture recompiles the templates every time. It
> recompiles my generation templates as well even if they are in a
> separate directory.
> Thanks
> Yigal.
Previous Topic:CDO and client/server approach
Next Topic:How to apply profile to activity diagram
Current Time: Sat Jul 26 02:28:08 EDT 2025
Powered by FUDForum. Page generated in 0.06051 seconds
