Home » Modeling » UML2 » Re: Programmatically moving Packages within an UML model
Re: Programmatically moving Packages within an UML model [message #477400] |
Mon, 19 May 2008 13:17 |
Ed Merks Messages: 33142 Registered: July 2009 |
Joakim,
It sounds like a question best asked on the UML2 newsgroup, which I've
added to the "to" list of the reply. Likely showing your stack trace
will be helpful for folks trying to understand what you've done.
Joakim Back wrote:
> Hello,
> I am working with a transformation aiming at adapting RSM models, to
> be compatible with tools previously used with Rose models.
> In the ModelRule, there is a desire to programatically move packages
> and content into a central Component. This has been possible with
> various content by creating clone packages, and moving content into
> the clones.
> An issue has arisen though with a Package that contains an Association
> to a Class in a sibling Package. The grand parent can be moved without
> issue to his clone, but when trying to move the content (say Packages
> A and B, where the Association is within A to a class in B) a
> ConcurrentModificationException arises.
> When moving the content through refactoring in Eclipse, there is no
> issue.
> Does anyone have clues to how to circumvent the problem, or since I am
> new to both the code and EMF in general, a different approach altogether?
> Best regards,
> Joakim
Ed Merks
Re: Programmatically moving Packages within an UML model [message #477403 is a reply to message #477400] |
Mon, 19 May 2008 22:39 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Joakim,
How are you finding the element to move? Are you doing during a
traversal of the model element tree?
+1 show us your stack trace...
Rafael
Ed Merks wrote:
> Joakim,
> Joakim Back wrote:
>> Hello,
>> the clones.
>> issue.
>> Best regards,
>> Joakim
Re: Programmatically moving Packages within an UML model [message #477404 is a reply to message #477403] |
Tue, 20 May 2008 07:20 |
Originally posted by: joakim.back.jayway.se
--------------070109060301020507010303
By reading the trace I gather the createTarget method (which contains
all the logic) is called within an iteration by IBM xtools, which is
obviously hazardous.
The moving is done by setNestingPackage.
A rephrase of the question is, is moving objects by nesting package a
valid approach, if done outside of an iteration?
Joakim
Rafael Chaves wrote:
> Joakim,
> Rafael
> Ed Merks wrote:
>> Joakim,
>> Joakim Back wrote:
>>> Hello,
>>> the clones.
>>> Association to a Class in a sibling Package. The grand parent can be
>>> moved without issue to his clone, but when trying to move the content
>>> (say Packages A and B, where the Association is within A to a class
>>> in B) a ConcurrentModificationException arises.
>>> issue.
>>> am new to both the code and EMF in general, a different approach
>>> altogether?
>>> Best regards,
>>> Joakim
name="trace.txt"
Content-Disposition: inline;
filename="trace.txt"
IUVOVFJZIGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlIDQgMTIgMjAw OC0wNS0xOSAw
OTozMzozOS41OTgNCiFNRVNTQUdFIElSSkgwMDEyRSBUcmFuc2Zvcm1hdGlv biAiRml4IFJv
c2UgSW1wb3J0IiBhYm9ydGVkIGR1cmluZyBpdHMgZXhlY3V0aW9uOyBkZXNj cmlwdG9yIGlk
PSJjb20uZW1wbG95ZXIuY29kZXRyYW5zbGF0b3IudHJhbnNmb3Jtcy5GaXhS b3NlSW1wb3J0
VHJhbnNmb3JtLnJvb3QiDQohU1RBQ0sgMA0KamF2YS51dGlsLkNvbmN1cnJl bnRNb2RpZmlj
YXRpb25FeGNlcHRpb24NCiAgICBhdCBvcmcuZWNsaXBzZS5lbWYuY29tbW9u LnV0aWwuQmFz
aWNFTGlzdCRFSXRlcmF0b3IuY2hlY2tNb2RDb3VudChCYXNpY0VMaXN0Lmph dmE6MTMyNykN
CiAgICBhdCBvcmcuZWNsaXBzZS5lbWYuY29tbW9uLnV0aWwuQmFzaWNFTGlz dCRFSXRlcmF0
b3IubmV4dChCYXNpY0VMaXN0LmphdmE6MTI4MSkNCiAgICBhdCBvcmcuZWNs aXBzZS51bWwy
LmNvbW1vbi51dGlsLkRlcml2ZWRFT2JqZWN0RUxpc3QkRGVyaXZlZExpc3RJ dGVyYXRvci5z
Y2FuTmV4dChEZXJpdmVkRU9iamVjdEVMaXN0LmphdmE6NjMpDQogICAgYXQg b3JnLmVjbGlw
c2UudW1sMi5jb21tb24udXRpbC5EZXJpdmVkRU9iamVjdEVMaXN0JERlcml2 ZWRMaXN0SXRl
cmF0b3IucHJlcGFyZU5leHQoRGVyaXZlZEVPYmplY3RFTGlzdC5qYXZhOjg5 KQ0KICAgIGF0
IG9yZy5lY2xpcHNlLnVtbDIuY29tbW9uLnV0aWwuRGVyaXZlZEVPYmplY3RF TGlzdCREZXJp
dmVkTGlzdEl0ZXJhdG9yLmhhc05leHQoRGVyaXZlZEVPYmplY3RFTGlzdC5q YXZhOjE0NCkN
CiAgICBhdCBvcmcuZWNsaXBzZS51bWwyLmNvbW1vbi51dGlsLkRlcml2ZWRF T2JqZWN0RUxp
c3QkRGVyaXZlZExpc3RJdGVyYXRvci5uZXh0KERlcml2ZWRFT2JqZWN0RUxp c3QuamF2YTox
NTMpDQogICAgYXQgY29tLmVtcGxveWVyLmNvZGV0cmFuc2xhdG9yLnJ1bGVz LlNldHVwSW1w
b3J0ZWRNb2RlbFJ1bGUubW92ZUNoaWxkcmVuKFNldHVwSW1wb3J0ZWRNb2Rl bFJ1bGUuamF2
YToyNTApDQogICAgYXQgY29tLmVtcGxveWVyLmNvZGV0cmFuc2xhdG9yLnJ1 bGVzLlNldHVw
SW1wb3J0ZWRNb2RlbFJ1bGUuY3JlYXRlVGFyZ2V0KFNldHVwSW1wb3J0ZWRN b2RlbFJ1bGUu
amF2YToyMjMpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNv cmUuQWJzdHJh
Y3RSdWxlLmV4ZWN1dGUoQWJzdHJhY3RSdWxlLmphdmE6OTEpDQogICAgYXQg Y29tLmlibS54
dG9vbHMudHJhbnNmb3JtLmNvcmUuTW9kZWxSdWxlLmFjY2VzcyQwKE1vZGVs UnVsZS5qYXZh
OjEpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuTW9k ZWxSdWxlJDEu
cnVuKE1vZGVsUnVsZS5qYXZhOjU3KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xz LnRyYW5zZm9y
bS5jb3JlLmludGVybmFsLmVuZ2luZS5UcmFuc2Zvcm1SdW5IZWxwZXIkMy5y dW4oVHJhbnNm
b3JtUnVuSGVscGVyLmphdmE6MTcyKQ0KICAgIGF0IG9yZy5lY2xpcHNlLmdt Zi5ydW50aW1l
LmVtZi5jb3JlLmludGVybmFsLmRvbWFpbi5NU0xFZGl0aW5nRG9tYWluLnJ1 bkFzV3JpdGUo
TVNMRWRpdGluZ0RvbWFpbi5qYXZhOjExNzQpDQogICAgYXQgb3JnLmVjbGlw c2UuZ21mLnJ1
bnRpbWUuZW1mLmNvcmUuaW50ZXJuYWwuZG9tYWluLk1TTEVkaXRpbmdEb21h aW4ucnVuQXNX
cml0ZShNU0xFZGl0aW5nRG9tYWluLmphdmE6MTE0MikNCiAgICBhdCBvcmcu ZWNsaXBzZS5n
bWYucnVudGltZS5lbWYuY29yZS51dGlsLk9wZXJhdGlvblV0aWwucnVuQXNX cml0ZShPcGVy
YXRpb25VdGlsLmphdmE6MzQ3KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRy YW5zZm9ybS5j
b3JlLmludGVybmFsLmVuZ2luZS5UcmFuc2Zvcm1SdW5IZWxwZXIucnVuSW5X cml0ZUFjdGlv
bihUcmFuc2Zvcm1SdW5IZWxwZXIuamF2YToxNjgpDQogICAgYXQgY29tLmli bS54dG9vbHMu
dHJhbnNmb3JtLmNvcmUuTW9kZWxSdWxlLmV4ZWN1dGUoTW9kZWxSdWxlLmph dmE6NTQpDQog
ICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3Jt LmV4ZWN1dGUo
VHJhbnNmb3JtLmphdmE6MzEwKQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRy YW5zZm9ybS5j
b3JlLlRyYW5zZm9ybS5pbnRlcm5hbEV4ZWN1dGUoVHJhbnNmb3JtLmphdmE6 NjExKQ0KICAg
IGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLlRyYW5zZm9ybSQx LnJ1bihUcmFu
c2Zvcm0uamF2YToyMDQpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNm b3JtLmNvcmUu
aW50ZXJuYWwuZW5naW5lLlRyYW5zZm9ybVJ1bkhlbHBlci5ydW5Jbldvcmtz cGFjZVJ1bm5h
YmxlKFRyYW5zZm9ybVJ1bkhlbHBlci5qYXZhOjIxMikNCiAgICBhdCBjb20u aWJtLnh0b29s
cy50cmFuc2Zvcm0uY29yZS5UcmFuc2Zvcm0uZXhlY3V0ZShUcmFuc2Zvcm0u amF2YToyMDIp
DQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuVHJhbnNm b3JtLmV4ZWN1
dGUoVHJhbnNmb3JtLmphdmE6MzUyKQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xz LnRyYW5zZm9y
bS5jb3JlLlRyYW5zZm9ybS5pbnRlcm5hbEV4ZWN1dGUoVHJhbnNmb3JtLmph dmE6NjE1KQ0K
ICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLk1vZGVsVHJh bnNmb3JtLmFj
Y2VzcyQwKE1vZGVsVHJhbnNmb3JtLmphdmE6MSkNCiAgICBhdCBjb20uaWJt Lnh0b29scy50
cmFuc2Zvcm0uY29yZS5Nb2RlbFRyYW5zZm9ybSQxLnJ1bihNb2RlbFRyYW5z Zm9ybS5qYXZh
OjUyKQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLmlu dGVybmFsLmVu
Z2luZS5UcmFuc2Zvcm1SdW5IZWxwZXIkMi5ydW4oVHJhbnNmb3JtUnVuSGVs cGVyLmphdmE6
MTI1KQ0KICAgIGF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3Jl LmludGVybmFs
LmRvbWFpbi5NU0xFZGl0aW5nRG9tYWluJDYucnVuKE1TTEVkaXRpbmdEb21h aW4uamF2YTox
MTEwKQ0KICAgIGF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3Jl LmludGVybmFs
LmRvbWFpbi5NU0xUcmFuc2FjdGlvbmFsRWRpdGluZ0RvbWFpbi5ydW5FeGNs dXNpdmUoTVNM
VHJhbnNhY3Rpb25hbEVkaXRpbmdEb21haW4uamF2YTozMzkpDQogICAgYXQg b3JnLmVjbGlw
c2UuZ21mLnJ1bnRpbWUuZW1mLmNvcmUuaW50ZXJuYWwuZG9tYWluLk1TTEVk aXRpbmdEb21h
aW4ucnVuRXhjbHVzaXZlKE1TTEVkaXRpbmdEb21haW4uamF2YToyMzY3KQ0K ICAgIGF0IG9y
Zy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3JlLmludGVybmFsLmRvbWFp bi5NU0xFZGl0
aW5nRG9tYWluLnJ1bkFzUmVhZChNU0xFZGl0aW5nRG9tYWluLmphdmE6MTEw NykNCiAgICBh
dCBvcmcuZWNsaXBzZS5nbWYucnVudGltZS5lbWYuY29yZS51dGlsLk9wZXJh dGlvblV0aWwu
cnVuQXNSZWFkKE9wZXJhdGlvblV0aWwuamF2YToyODcpDQogICAgYXQgY29t LmlibS54dG9v
bHMudHJhbnNmb3JtLmNvcmUuaW50ZXJuYWwuZW5naW5lLlRyYW5zZm9ybVJ1 bkhlbHBlci5y
dW5JblJlYWRBY3Rpb24oVHJhbnNmb3JtUnVuSGVscGVyLmphdmE6MTIxKQ0K ICAgIGF0IGNv
bS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLk1vZGVsVHJhbnNmb3JtLmlu dGVybmFsRXhl
Y3V0ZShNb2RlbFRyYW5zZm9ybS5qYXZhOjQ4KQ0KICAgIGF0IGNvbS5pYm0u eHRvb2xzLnRy
YW5zZm9ybS5jb3JlLlRyYW5zZm9ybSQxLnJ1bihUcmFuc2Zvcm0uamF2YToy MDQpDQogICAg
YXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuaW50ZXJuYWwuZW5n aW5lLlRyYW5z
Zm9ybVJ1bkhlbHBlci5ydW5JbldvcmtzcGFjZVJ1bm5hYmxlKFRyYW5zZm9y bVJ1bkhlbHBl
ci5qYXZhOjIxMikNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0u Y29yZS5UcmFu
c2Zvcm0uZXhlY3V0ZShUcmFuc2Zvcm0uamF2YToyMDIpDQogICAgYXQgY29t LmlibS54dG9v
bHMudW1sLnRyYW5zZm9ybS5jb3JlLlVNTEtpbmRUcmFuc2Zvcm0uZXhlY3V0 ZShVTUxLaW5k
VHJhbnNmb3JtLmphdmE6MTQ2KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRy YW5zZm9ybS5j
b3JlLlRyYW5zZm9ybS5leGVjdXRlKFRyYW5zZm9ybS5qYXZhOjI2NCkNCiAg ICBhdCBjb20u
aWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5UcmFuc2Zvcm0uaW50ZXJuYWxF eGVjdXRlKFRy
YW5zZm9ybS5qYXZhOjYxMykNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFu c2Zvcm0uY29y
ZS5UcmFuc2Zvcm0kMS5ydW4oVHJhbnNmb3JtLmphdmE6MjA0KQ0KICAgIGF0 IGNvbS5pYm0u
eHRvb2xzLnRyYW5zZm9ybS5jb3JlLmludGVybmFsLmVuZ2luZS5UcmFuc2Zv cm1SdW5IZWxw
ZXIucnVuSW5Xb3Jrc3BhY2VSdW5uYWJsZShUcmFuc2Zvcm1SdW5IZWxwZXIu amF2YToyMTIp
dGUoVHJhbnNmb3JtLmphdmE6MjAyKQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xz LnRyYW5zZm9y
bS5jb3JlLlRyYW5zZm9ybUNvbnRyb2xsZXIuZXhlY3V0ZUVsZW1lbnQoVHJh bnNmb3JtQ29u
dHJvbGxlci5qYXZhOjIxMykNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFu c2Zvcm0uY29y
ZS5UcmFuc2Zvcm1Db250cm9sbGVyLmRvRXhlY3V0ZShUcmFuc2Zvcm1Db250 cm9sbGVyLmph
dmE6MTk1KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3Jl LlRyYW5zZm9y
bUNvbnRyb2xsZXIuYWNjZXNzJDAoVHJhbnNmb3JtQ29udHJvbGxlci5qYXZh OjE5MSkNCiAg
ICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5UcmFuc2Zvcm1D b250cm9sbGVy
JDEucnVuKFRyYW5zZm9ybUNvbnRyb2xsZXIuamF2YToxNzEpDQogICAgYXQg Y29tLmlibS54
dG9vbHMudHJhbnNmb3JtLmNvcmUuaW50ZXJuYWwuZW5naW5lLlRyYW5zZm9y bVJ1bkhlbHBl
ciQxLnJ1bihUcmFuc2Zvcm1SdW5IZWxwZXIuamF2YTo4MCkNCiAgICBhdCBv cmcuZWNsaXBz
ZS5nbWYucnVudGltZS5lbWYuY29yZS5pbnRlcm5hbC5kb21haW4uTVNMRWRp dGluZ0RvbWFp
bi5ydW5JblVuZG9JbnRlcnZhbChNU0xFZGl0aW5nRG9tYWluLmphdmE6OTYw KQ0KICAgIGF0
IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3JlLmludGVybmFsLmRv bWFpbi5NU0xF
ZGl0aW5nRG9tYWluLnJ1bkluVW5kb0ludGVydmFsKE1TTEVkaXRpbmdEb21h aW4uamF2YTo5
NDEpDQogICAgYXQgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUuZW1mLmNvcmUu dXRpbC5PcGVy
YXRpb25VdGlsLnJ1bkluVW5kb0ludGVydmFsKE9wZXJhdGlvblV0aWwuamF2 YToxNDYpDQog
ICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuaW50ZXJuYWwu ZW5naW5lLlRy
YW5zZm9ybVJ1bkhlbHBlci5ydW5JblVuZG9JbnRlcnZhbChUcmFuc2Zvcm1S dW5IZWxwZXIu
amF2YTo3NikNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29y ZS5pbnRlcm5h
bC5lbmdpbmUuVHJhbnNmb3JtUnVuSGVscGVyJDQucnVuKFRyYW5zZm9ybVJ1 bkhlbHBlci5q
YXZhOjIyNykNCiAgICBhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJl c291cmNlcy5X
b3Jrc3BhY2UucnVuKFdvcmtzcGFjZS5qYXZhOjE3MzcpDQogICAgYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5pbnRlcm5hbC5yZXNvdXJjZXMuV29ya3NwYWNlLnJ1bihXb3Jrc3Bh Y2UuamF2YTox
NzE5KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLmlu dGVybmFsLmVu
Z2luZS5UcmFuc2Zvcm1SdW5IZWxwZXIucnVuSW5Xb3Jrc3BhY2VSdW5uYWJs ZShUcmFuc2Zv
cm1SdW5IZWxwZXIuamF2YToyMjQpDQogICAgYXQgY29tLmlibS54dG9vbHMu dHJhbnNmb3Jt
LmNvcmUuVHJhbnNmb3JtQ29udHJvbGxlci5leGVjdXRlKFRyYW5zZm9ybUNv bnRyb2xsZXIu
amF2YToxNjkpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNv cmUuVHJhbnNm
b3JtQ29udHJvbGxlci5leGVjdXRlKFRyYW5zZm9ybUNvbnRyb2xsZXIuamF2 YTo5NCkNCiAg
ICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0udWkuaW50ZXJuYWwuYWN0 aW9ucy5SdW5G
b3J3YXJkQWN0aW9uJDEucnVuKFJ1bkZvcndhcmRBY3Rpb24uamF2YTo4MSkN CiAgICBhdCBv
cmcuZWNsaXBzZS5qZmFjZS5vcGVyYXRpb24uTW9kYWxDb250ZXh0JE1vZGFs Q29udGV4dFRo
cmVhZC5ydW4oTW9kYWxDb250ZXh0LmphdmE6MTEzKQ0KIVNVQkVOVFJZIDEg Y29tLmlibS54
dG9vbHMudHJhbnNmb3JtLmNvcmUgNCAxMiAyMDA4LTA1LTE5IDA5OjMzOjM5 LjU5OA0KIU1F
U1NBR0UgVHJhbnNmb3JtIGNvbnRleHQgc3RhY2sNCiFTVEFDSyAwDQpqYXZh LnV0aWwuQ29u
Y3VycmVudE1vZGlmaWNhdGlvbkV4Y2VwdGlvbg0KICAgIGF0IG9yZy5lY2xp cHNlLmVtZi5j
b21tb24udXRpbC5CYXNpY0VMaXN0JEVJdGVyYXRvci5jaGVja01vZENvdW50 KEJhc2ljRUxp
c3QuamF2YToxMzI3KQ0KICAgIGF0IG9yZy5lY2xpcHNlLmVtZi5jb21tb24u dXRpbC5CYXNp
Y0VMaXN0JEVJdGVyYXRvci5uZXh0KEJhc2ljRUxpc3QuamF2YToxMjgxKQ0K ICAgIGF0IG9y
Zy5lY2xpcHNlLnVtbDIuY29tbW9uLnV0aWwuRGVyaXZlZEVPYmplY3RFTGlz dCREZXJpdmVk
TGlzdEl0ZXJhdG9yLnNjYW5OZXh0KERlcml2ZWRFT2JqZWN0RUxpc3QuamF2 YTo2MykNCiAg
ICBhdCBvcmcuZWNsaXBzZS51bWwyLmNvbW1vbi51dGlsLkRlcml2ZWRFT2Jq ZWN0RUxpc3Qk
RGVyaXZlZExpc3RJdGVyYXRvci5wcmVwYXJlTmV4dChEZXJpdmVkRU9iamVj dEVMaXN0Lmph
dmE6ODkpDQogICAgYXQgb3JnLmVjbGlwc2UudW1sMi5jb21tb24udXRpbC5E ZXJpdmVkRU9i
amVjdEVMaXN0JERlcml2ZWRMaXN0SXRlcmF0b3IuaGFzTmV4dChEZXJpdmVk RU9iamVjdEVM
aXN0LmphdmE6MTQ0KQ0KICAgIGF0IG9yZy5lY2xpcHNlLnVtbDIuY29tbW9u LnV0aWwuRGVy
aXZlZEVPYmplY3RFTGlzdCREZXJpdmVkTGlzdEl0ZXJhdG9yLm5leHQoRGVy aXZlZEVPYmpl
Y3RFTGlzdC5qYXZhOjE1MykNCiAgICBhdCBjb20uZW1wbG95ZXIuY29kZXRy YW5zbGF0b3Iu
cnVsZXMuU2V0dXBJbXBvcnRlZE1vZGVsUnVsZS5tb3ZlQ2hpbGRyZW4oU2V0 dXBJbXBvcnRl
ZE1vZGVsUnVsZS5qYXZhOjI1MCkNCiAgICBhdCBjb20uZW1wbG95ZXIuY29k ZXRyYW5zbGF0
b3IucnVsZXMuU2V0dXBJbXBvcnRlZE1vZGVsUnVsZS5jcmVhdGVUYXJnZXQo U2V0dXBJbXBv
cnRlZE1vZGVsUnVsZS5qYXZhOjIyMykNCiAgICBhdCBjb20uaWJtLnh0b29s cy50cmFuc2Zv
cm0uY29yZS5BYnN0cmFjdFJ1bGUuZXhlY3V0ZShBYnN0cmFjdFJ1bGUuamF2 YTo5MSkNCiAg
ICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5Nb2RlbFJ1bGUu YWNjZXNzJDAo
TW9kZWxSdWxlLmphdmE6MSkNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFu c2Zvcm0uY29y
ZS5Nb2RlbFJ1bGUkMS5ydW4oTW9kZWxSdWxlLmphdmE6NTcpDQogICAgYXQg Y29tLmlibS54
ciQzLnJ1bihUcmFuc2Zvcm1SdW5IZWxwZXIuamF2YToxNzIpDQogICAgYXQg b3JnLmVjbGlw
aW4ucnVuQXNXcml0ZShNU0xFZGl0aW5nRG9tYWluLmphdmE6MTE3NCkNCiAg ICBhdCBvcmcu
ZWNsaXBzZS5nbWYucnVudGltZS5lbWYuY29yZS5pbnRlcm5hbC5kb21haW4u TVNMRWRpdGlu
Z0RvbWFpbi5ydW5Bc1dyaXRlKE1TTEVkaXRpbmdEb21haW4uamF2YToxMTQy KQ0KICAgIGF0
IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3JlLnV0aWwuT3BlcmF0 aW9uVXRpbC5y
dW5Bc1dyaXRlKE9wZXJhdGlvblV0aWwuamF2YTozNDcpDQogICAgYXQgY29t LmlibS54dG9v
dW5JbldyaXRlQWN0aW9uKFRyYW5zZm9ybVJ1bkhlbHBlci5qYXZhOjE2OCkN CiAgICBhdCBj
b20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5Nb2RlbFJ1bGUuZXhlY3V0 ZShNb2RlbFJ1
bGUuamF2YTo1NCkNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0u Y29yZS5UcmFu
c2Zvcm0uZXhlY3V0ZShUcmFuc2Zvcm0uamF2YTozMTApDQogICAgYXQgY29t LmlibS54dG9v
bHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3JtLmludGVybmFsRXhlY3V0ZShU cmFuc2Zvcm0u
amF2YTo2MTEpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNv cmUuVHJhbnNm
b3JtJDEucnVuKFRyYW5zZm9ybS5qYXZhOjIwNCkNCiAgICBhdCBjb20uaWJt Lnh0b29scy50
cmFuc2Zvcm0uY29yZS5pbnRlcm5hbC5lbmdpbmUuVHJhbnNmb3JtUnVuSGVs cGVyLnJ1bklu
V29ya3NwYWNlUnVubmFibGUoVHJhbnNmb3JtUnVuSGVscGVyLmphdmE6MjEy KQ0KICAgIGF0
IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLlRyYW5zZm9ybS5leGVj dXRlKFRyYW5z
Zm9ybS5qYXZhOjIwMikNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zv cm0uY29yZS5U
cmFuc2Zvcm0uZXhlY3V0ZShUcmFuc2Zvcm0uamF2YTozNTIpDQogICAgYXQg Y29tLmlibS54
dG9vbHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3JtLmludGVybmFsRXhlY3V0 ZShUcmFuc2Zv
cm0uamF2YTo2MTUpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3Jt LmNvcmUuTW9k
ZWxUcmFuc2Zvcm0uYWNjZXNzJDAoTW9kZWxUcmFuc2Zvcm0uamF2YToxKQ0K ICAgIGF0IGNv
bS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLk1vZGVsVHJhbnNmb3JtJDEu cnVuKE1vZGVs
VHJhbnNmb3JtLmphdmE6NTIpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJh bnNmb3JtLmNv
cmUuaW50ZXJuYWwuZW5naW5lLlRyYW5zZm9ybVJ1bkhlbHBlciQyLnJ1bihU cmFuc2Zvcm1S
dW5IZWxwZXIuamF2YToxMjUpDQogICAgYXQgb3JnLmVjbGlwc2UuZ21mLnJ1 bnRpbWUuZW1m
LmNvcmUuaW50ZXJuYWwuZG9tYWluLk1TTEVkaXRpbmdEb21haW4kNi5ydW4o TVNMRWRpdGlu
Z0RvbWFpbi5qYXZhOjExMTApDQogICAgYXQgb3JnLmVjbGlwc2UuZ21mLnJ1 bnRpbWUuZW1m
LmNvcmUuaW50ZXJuYWwuZG9tYWluLk1TTFRyYW5zYWN0aW9uYWxFZGl0aW5n RG9tYWluLnJ1
bkV4Y2x1c2l2ZShNU0xUcmFuc2FjdGlvbmFsRWRpdGluZ0RvbWFpbi5qYXZh OjMzOSkNCiAg
ICBhdCBvcmcuZWNsaXBzZS5nbWYucnVudGltZS5lbWYuY29yZS5pbnRlcm5h bC5kb21haW4u
TVNMRWRpdGluZ0RvbWFpbi5ydW5FeGNsdXNpdmUoTVNMRWRpdGluZ0RvbWFp bi5qYXZhOjIz
NjcpDQogICAgYXQgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUuZW1mLmNvcmUu aW50ZXJuYWwu
ZG9tYWluLk1TTEVkaXRpbmdEb21haW4ucnVuQXNSZWFkKE1TTEVkaXRpbmdE b21haW4uamF2
YToxMTA3KQ0KICAgIGF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5j b3JlLnV0aWwu
T3BlcmF0aW9uVXRpbC5ydW5Bc1JlYWQoT3BlcmF0aW9uVXRpbC5qYXZhOjI4 NykNCiAgICBh
dCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5pbnRlcm5hbC5lbmdp bmUuVHJhbnNm
b3JtUnVuSGVscGVyLnJ1bkluUmVhZEFjdGlvbihUcmFuc2Zvcm1SdW5IZWxw ZXIuamF2YTox
MjEpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuTW9k ZWxUcmFuc2Zv
cm0uaW50ZXJuYWxFeGVjdXRlKE1vZGVsVHJhbnNmb3JtLmphdmE6NDgpDQog ICAgYXQgY29t
LmlibS54dG9vbHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3JtJDEucnVuKFRy YW5zZm9ybS5q
YXZhOjIwNCkNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29y ZS5pbnRlcm5h
bC5lbmdpbmUuVHJhbnNmb3JtUnVuSGVscGVyLnJ1bkluV29ya3NwYWNlUnVu bmFibGUoVHJh
bnNmb3JtUnVuSGVscGVyLmphdmE6MjEyKQ0KICAgIGF0IGNvbS5pYm0ueHRv b2xzLnRyYW5z
Zm9ybS5jb3JlLlRyYW5zZm9ybS5leGVjdXRlKFRyYW5zZm9ybS5qYXZhOjIw MikNCiAgICBh
dCBjb20uaWJtLnh0b29scy51bWwudHJhbnNmb3JtLmNvcmUuVU1MS2luZFRy YW5zZm9ybS5l
eGVjdXRlKFVNTEtpbmRUcmFuc2Zvcm0uamF2YToxNDYpDQogICAgYXQgY29t LmlibS54dG9v
bHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3JtLmV4ZWN1dGUoVHJhbnNmb3Jt LmphdmE6MjY0
KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5jb3JlLlRyYW5z Zm9ybS5pbnRl
cm5hbEV4ZWN1dGUoVHJhbnNmb3JtLmphdmE6NjEzKQ0KICAgIGF0IGNvbS5p Ym0ueHRvb2xz
LnRyYW5zZm9ybS5jb3JlLlRyYW5zZm9ybSQxLnJ1bihUcmFuc2Zvcm0uamF2 YToyMDQpDQog
YW5zZm9ybVJ1bkhlbHBlci5ydW5JbldvcmtzcGFjZVJ1bm5hYmxlKFRyYW5z Zm9ybVJ1bkhl
bHBlci5qYXZhOjIxMikNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zv cm0uY29yZS5U
cmFuc2Zvcm0uZXhlY3V0ZShUcmFuc2Zvcm0uamF2YToyMDIpDQogICAgYXQg Y29tLmlibS54
dG9vbHMudHJhbnNmb3JtLmNvcmUuVHJhbnNmb3JtQ29udHJvbGxlci5leGVj dXRlRWxlbWVu
dChUcmFuc2Zvcm1Db250cm9sbGVyLmphdmE6MjEzKQ0KICAgIGF0IGNvbS5p Ym0ueHRvb2xz
LnRyYW5zZm9ybS5jb3JlLlRyYW5zZm9ybUNvbnRyb2xsZXIuZG9FeGVjdXRl KFRyYW5zZm9y
bUNvbnRyb2xsZXIuamF2YToxOTUpDQogICAgYXQgY29tLmlibS54dG9vbHMu dHJhbnNmb3Jt
LmNvcmUuVHJhbnNmb3JtQ29udHJvbGxlci5hY2Nlc3MkMChUcmFuc2Zvcm1D b250cm9sbGVy
LmphdmE6MTkxKQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS5j b3JlLlRyYW5z
Zm9ybUNvbnRyb2xsZXIkMS5ydW4oVHJhbnNmb3JtQ29udHJvbGxlci5qYXZh OjE3MSkNCiAg
ICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZS5pbnRlcm5hbC5l bmdpbmUuVHJh
bnNmb3JtUnVuSGVscGVyJDEucnVuKFRyYW5zZm9ybVJ1bkhlbHBlci5qYXZh OjgwKQ0KICAg
IGF0IG9yZy5lY2xpcHNlLmdtZi5ydW50aW1lLmVtZi5jb3JlLmludGVybmFs LmRvbWFpbi5N
U0xFZGl0aW5nRG9tYWluLnJ1bkluVW5kb0ludGVydmFsKE1TTEVkaXRpbmdE b21haW4uamF2
YTo5NjApDQogICAgYXQgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUuZW1mLmNv cmUuaW50ZXJu
YWwuZG9tYWluLk1TTEVkaXRpbmdEb21haW4ucnVuSW5VbmRvSW50ZXJ2YWwo TVNMRWRpdGlu
Z0RvbWFpbi5qYXZhOjk0MSkNCiAgICBhdCBvcmcuZWNsaXBzZS5nbWYucnVu dGltZS5lbWYu
Y29yZS51dGlsLk9wZXJhdGlvblV0aWwucnVuSW5VbmRvSW50ZXJ2YWwoT3Bl cmF0aW9uVXRp
bC5qYXZhOjE0NikNCiAgICBhdCBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0u Y29yZS5pbnRl
cm5hbC5lbmdpbmUuVHJhbnNmb3JtUnVuSGVscGVyLnJ1bkluVW5kb0ludGVy dmFsKFRyYW5z
Zm9ybVJ1bkhlbHBlci5qYXZhOjc2KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xz LnRyYW5zZm9y
bS5jb3JlLmludGVybmFsLmVuZ2luZS5UcmFuc2Zvcm1SdW5IZWxwZXIkNC5y dW4oVHJhbnNm
b3JtUnVuSGVscGVyLmphdmE6MjI3KQ0KICAgIGF0IG9yZy5lY2xpcHNlLmNv cmUuaW50ZXJu
YWwucmVzb3VyY2VzLldvcmtzcGFjZS5ydW4oV29ya3NwYWNlLmphdmE6MTcz NykNCiAgICBh
dCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlc291cmNlcy5Xb3Jrc3Bh Y2UucnVuKFdv
cmtzcGFjZS5qYXZhOjE3MTkpDQogICAgYXQgY29tLmlibS54dG9vbHMudHJh bnNmb3JtLmNv
cmUuaW50ZXJuYWwuZW5naW5lLlRyYW5zZm9ybVJ1bkhlbHBlci5ydW5Jbldv cmtzcGFjZVJ1
bm5hYmxlKFRyYW5zZm9ybVJ1bkhlbHBlci5qYXZhOjIyNCkNCiAgICBhdCBj b20uaWJtLnh0
b29scy50cmFuc2Zvcm0uY29yZS5UcmFuc2Zvcm1Db250cm9sbGVyLmV4ZWN1 dGUoVHJhbnNm
b3JtQ29udHJvbGxlci5qYXZhOjE2OSkNCiAgICBhdCBjb20uaWJtLnh0b29s cy50cmFuc2Zv
cm0uY29yZS5UcmFuc2Zvcm1Db250cm9sbGVyLmV4ZWN1dGUoVHJhbnNmb3Jt Q29udHJvbGxl
ci5qYXZhOjk0KQ0KICAgIGF0IGNvbS5pYm0ueHRvb2xzLnRyYW5zZm9ybS51 aS5pbnRlcm5h
bC5hY3Rpb25zLlJ1bkZvcndhcmRBY3Rpb24kMS5ydW4oUnVuRm9yd2FyZEFj dGlvbi5qYXZh
OjgxKQ0KICAgIGF0IG9yZy5lY2xpcHNlLmpmYWNlLm9wZXJhdGlvbi5Nb2Rh bENvbnRleHQk
TW9kYWxDb250ZXh0VGhyZWFkLnJ1bihNb2RhbENvbnRleHQuamF2YToxMTMp DQohU1VCRU5U
UlkgMiBjb20uaWJtLnh0b29scy50cmFuc2Zvcm0uY29yZSA0IDEyIDIwMDgt MDUtMTkgMDk6
MzM6MzkuNTk4DQohTUVTU0FHRSBUcmFuc2Zvcm0gRml4IFJvc2UgSW1wb3J0 OiAgRWxlbWVu
dCAiU2V0dGluZyB1cCBtb2RlbCIgd2FzIGV4ZWN1dGluZyBzb3VyY2UgIm9y Zy5lY2xpcHNl
LnVtbDIudW1sLmludGVybmFsLmltcGwuTW9kZWxJbXBsQDYwN2M2MDdjIChu YW1lOiBFYmNU
ZXN0MDQsIHZpc2liaWxpdHk6IDx1bnNldD4pICh2aXNpYmlsaXR5OiBwdWJs aWMpICh2aWV3
cG9pbnQ6IDx1bnNldD4pIg0KIVNVQkVOVFJZIDIgY29tLmlibS54dG9vbHMu dHJhbnNmb3Jt
LmNvcmUgNCAxMiAyMDA4LTA1LTE5IDA5OjMzOjM5LjU5OA0KIU1FU1NBR0Ug VHJhbnNmb3Jt
IEZpeCBSb3NlIEltcG9ydDogIEVsZW1lbnQgImNvbS5lbXBsb3llci5jb2Rl dHJhbnNsYXRv
ci50cmFuc2Zvcm1zLkZpeFJvc2VJbXBvcnRUcmFuc2Zvcm0ucm9vdC5saXN0 IiB3YXMgZXhl
Y3V0aW5nIHNvdXJjZSAiW29yZy5lY2xpcHNlLnVtbDIudW1sLmludGVybmFs LmltcGwuTW9k
ZWxJbXBsQDYwN2M2MDdjIChuYW1lOiBFYmNUZXN0MDQsIHZpc2liaWxpdHk6 IDx1bnNldD4p
ICh2aXNpYmlsaXR5OiBwdWJsaWMpICh2aWV3cG9pbnQ6IDx1bnNldD4pXSIN CiA=
--------------070109060301020507010303--
Re: Programmatically moving Packages within an UML model [message #477405 is a reply to message #477404] |
Tue, 20 May 2008 14:55 |
I would say so and it would be the same as removing it from the
collection of children of the existing parent and adding it to the new one.
You just need to make sure you don't make changes to a collection of
objects while you are iterating it. One possible way to do that is to
collect the changes to perform during the traversal, but not actually do
then, and perform them right after the traversal finishes. There might
be better ways though.
Rafael
> Joakim
>> Joakim,
>> Rafael
>> Ed Merks wrote:
>>> Joakim,
>>> I've added to the "to" list of the reply. Likely showing your stack
>>> trace will be helpful for folks trying to understand what you've done.
>>> Joakim Back wrote:
>>>> Hello,
>>>> the clones.
>>>> content (say Packages A and B, where the Association is within A to
>>>> a class in B) a ConcurrentModificationException arises.
>>>> issue.
>>>> altogether?
>>>> Best regards,
>>>> Joakim
Re: Programmatically moving Packages within an UML model [message #626585 is a reply to message #477400] |
Joakim,
Rafael
Ed Merks wrote:
> Joakim,
> Joakim Back wrote:
>> Hello,
>> the clones.
>> issue.
>> Best regards,
>> Joakim
Re: Programmatically moving Packages within an UML model [message #626586 is a reply to message #477403] |
Joakim
> Joakim,
> Rafael
> Ed Merks wrote:
>> Joakim,
>> Joakim Back wrote:
>>> Hello,
>>> the clones.
>>> issue.
>>> altogether?
>>> Best regards,
>>> Joakim
name="trace.txt"
Re: Programmatically moving Packages within an UML model [message #626587 is a reply to message #477404] |
Rafael
> Joakim
>> Joakim,
>> Rafael
>> Ed Merks wrote:
>>> Joakim,
>>> Joakim Back wrote:
>>>> Hello,
>>>> the clones.
>>>> issue.
>>>> altogether?
>>>> Best regards,
>>>> Joakim
Current Time: Sat Apr 27 00:12:44 GMT 2024
Powered by FUDForum. Page generated in 0.06427 seconds
