Re: Trinidad installation [message #475614 is a reply to message #475612] |
Thu, 20 March 2008 17:31 |
Mario wrote:
> I think it is easy. New JSF libraries, adding trinidad-api-1.2.7.jar and
> trinidad-impl-1.2.7.jar and choosing a new library in a new web dynamic
> project. Which taglibs I need to add to my jsp file? And what next I need to
> do? Where to find tutorial to start up with trinidad components (datatable
> for example)?
If the project has the Trinidad libraries correctly set up, content
assist in the taglib directive's URI attribute in the JSP editor
should help you fill in the values. Your best bet, though, is to
start at http://myfaces.apache.org/trinidad/ .
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Trinidad installation [message #475752 is a reply to message #475618] |
Thu, 03 April 2008 08:14 |
Originally posted by: emrandle.yahoo.com
On 2008-03-20 10:54:43 -0700, cameron.bateman@oracle.com (Cameron
Bateman) said:
> If the tag library is on the classpath and you using the visual Web
> Page Editor, then the tags will appear in the Palette. In 3.0, there
> will also be a new Tag Registry that enumerates all of the known tags
> that are the class path visually and provides additional, JSF-specific
> information about them such as what component the are associated with.
> --Cam
Which classpath? I can't get Eclipse to see any jars thru the JSF
Libraries setup. I can add jars, close the window, go back in and they
are are [missing]. How do I fix this?
mike
Re: Trinidad installation [message #617508 is a reply to message #475612] |
> for example)?
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
Re: Trinidad installation [message #617681 is a reply to message #475618] |
> --Cam
mike
FUDForum. Page generated in 0.05118 seconds
