Home » Eclipse Projects » Standard Widget Toolkit (SWT) » PDF Problem with SWT Browser on Linux/GTK SWT 3.1.1 w/ Mozilla
PDF Problem with SWT Browser on Linux/GTK SWT 3.1.1 w/ Mozilla [message #466157] |
Wed, 04 January 2006 01:29 |
Joe Mihalich Messages: 25 Registered: July 2009 |
Junior Member |
We're having a problem displaying pdf files from and SWT Browser
class in Mozilla on Suse Linux with SWT 3.1.1.
When I launch Mozilla standalone, and navigate to the page that
embeds the pdf, it works fine. A dialog popups asking me if I want
to open it with acrobat, or save the file.
When I navigate to the page inside an swt browser class,
I immediately get the file save-as dialog...it doesn't give me the
option of opening it in acrobat. If I save the file, it winds up
saving a valid pdf file which I can open in acrobat.
Am I doing something wrong, or could this be a bug
in SWT? In our case, the url I set is actually to a normal html page.
then if you
click on a button on the page, it hits our server, which
returns a pdf response
Here is basically what I'm doing....
final Shell shell = new Shell();
shell.setText(windowTitle);
shell.setLayout(new FillLayout());
shell.setMaximized(true);
Composite comp = new Composite(shell, SWT.NONE);
comp.setLayout(new FillLayout());
Browser browser = new Browser(comp, SWT.NONE);
browser.addOpenWindowListener(new OpenWindowListener()
public void open(WindowEvent event)
Shell shell = new Shell(getMainShell().getDisplay());
shell.setText("");
Browser browserNew = new Browser(shell, SWT.NONE);
//add window open/close listeners here (removed for brevity
sake)
event.browser = browserNew;
browser.addCloseWindowListener(new CloseWindowListener()
public void close(WindowEvent event)
Browser browserNew = (Browser)event.widget;
Shell shell = browserNew.getShell();
shell.close();
browser.setUrl(url);
shell.open();
Joe
Re: PDF Problem with SWT Browser on Linux/GTK SWT 3.1.1 w/ Mozilla [message #466159 is a reply to message #466157] |
Wed, 04 January 2006 02:39 |
Haris Peco Messages: 1072 Registered: July 2009 |
Joe,
I think that you have two versions mozilla
pdf view work fine when you have pdf plugin for mozilla
- you have plugin when launch mozilla standalone, but no when call swt
browser
it is possible that you have user-based plugin for mozilla
(in .mozilla/plugins) and it isn't used when you call from swt
workaround : check pdf plugin for mozilla in MOZILLA_FIVE_HOME/plugins
peco
Joe Mihalich wrote:
> then if you
> shell.setText("");
> sake)
> shell.close();
> shell.open();
> Joe
Re: PDF Problem with SWT Browser on Linux/GTK SWT 3.1.1 w/ Mozilla [message #466277 is a reply to message #466271] |
Thu, 05 January 2006 21:01 |
Joe,
it is simple - you have to find mozilla install which eclipse use
and plugin have to exists in MOZILLA_FIVE_HOME/plugins
if you have mozilla nad firefox it is two mozilla install
(firefox is mozilla without mail, irc,news,composer etc - it is same
libraries) - you eclipse use firefox , maybe
add nppdf.so to FIREFOX_HOME/plugins, too
try make new user and start standalone mozilla and check pdf plugin
(without install plugin for this user)
you can see plugins with link about:plugins (in swt browser , too)
- check this link standalone and in swt browser and you will see different
swt browser is complete same like standalone mozilla
Joe Mihalich wrote:
> When I remove the plugin from the mozilla directory,
> standalone still works due to the mozilla plugin scanning
> feature. See here:
> http://plugindoc.mozdev.org/faqs/acroread.html#install-linux
> There is only 1 mozilla installed on this box. We also
> have firefox installed but that's in a different directory, and
> nothing points there.
> Any other ideas?
> Joe
Current Time: Fri Apr 26 20:32:47 GMT 2024
Powered by FUDForum. Page generated in 0.04018 seconds
