Home » Eclipse Projects » Standard Widget Toolkit (SWT) » grab the mouse
grab the mouse [message #455709] |
Thu, 19 May 2005 20:31 |
Amir Bukhari Messages: 8 Registered: July 2009 |
Junior Member |
I want to grab the mouse totaly. I mean with grabing, that all low level
Mouse event should be send to my
application. in linux I can grab the pointer on X server. in windows I
should create a Hook.
is there any way to handle this in SWT?
sorry the fellowing may be more Windows specific!
I have create a small java with JNI. the JNI DLL register a hook like the
following:
thisInstance1 = LoadLibrary((LPCTSTR) "hockdll.dll");
hkMouse1 = (HOOKPROC)GetProcAddress(thisInstance1, "MouseHookProc");
printf("Hello2 world! %p %p\n", thisInstance1, hkMouse1);
g_hMouseHook = SetWindowsHookEx(WH_MOUSE_LL, hkMouse1, thisInstance1,NULL);
after running my java application I got a correct g_hMouseHook,
thisInstance1 and hkMouse1 . and also mouse stopped moving,
but my Hook function never got called. and after a few second the mouse
return to its normal execution, because windows wait.
Re: grab the mouse [message #455836 is a reply to message #455709] |
Fri, 20 May 2005 04:05 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
Amir Bukhari:
Look at Control.setCapture()
> following:
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Konstantin Scheglov,
Google, Inc.
Re: grab the mouse [message #455843 is a reply to message #455836] |
Fri, 20 May 2005 08:21 |
Junior Member |
Control.setCapture() will capture all events sends my the system to our
appliation to be forwarded to
the control capture the mouse events. what I want is a global capture, I
want to capture all mouse events from system to be send to my application
that mean no other applicaton on the desktop should receive mouse events
when I register it.
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> schrieb im Newsbeitrag
news:T9j5kEPXFHA.2692@fairy.ao.nlmk...
> Amir Bukhari:
>> following:
> SY, Konstantin.
Re: grab the mouse [message #455847 is a reply to message #455843] |
Fri, 20 May 2005 10:04 |
Amir Bukhari:
> when I register it.
Well, just one advice: don't do this. :-)
And I don't belive that you can do this using only SWT.
>>Amir Bukhari:
>>>following:
>>SY, Konstantin.
SY, Konstantin.
Google, Inc.
Current Time: Wed May 08 12:10:53 GMT 2024
Powered by FUDForum. Page generated in 0.03588 seconds
