Re: JPA dali, moving the persistence.xml [message #435554 is a reply to message #435551] |
Thu, 23 July 2009 16:55 |
Originally posted by: buchholz-news.security.de
This does not help for me. I use a Galileo installation, also with maven2
plugin. I follow your instructions, but the "JPA Content" Descriptor is
empty and after selecting an Entity Class the "JPA Details" view
shows: "Details are not available for current selection".
Did you use the stable Maven Plugin or the development release?
harpritt wrote:
> Ok..... sods law
> as soon as i post my problem on the news group... i flipping well work out
> the solution. How annoying!
> The solution was to add src/main/resources to the source (under build
> path) BEFORE i set up the JPA Facet
> ...BEFORE... AFTER.... BEFORE AFTER..... baaaaaaaa
> anyway it works now...
> hope it helps someone else.
Re: JPA dali, moving the persistence.xml [message #616670 is a reply to message #435551] |
harpritt wrote:
> Ok..... sods law
FUDForum. Page generated in 5.04794 seconds
