Placing the same object twice in an EList? [message #430209] |
Wed, 13 May 2009 09:23  |
Hi everyone, I'm rahter new at EMF/ECORE and I wonder if its possible,
to have the same object more than one times in an ELIST. I've set UNIQUE
to False and ORDERED to true, but when trying to place an object a
second time in the EList, an Illegal Argument Exception is thrown:
java.lang.IllegalArgumentException: The 'no duplicates' constraint is
violated
As I could find this should just happen if unique is true, but it isn't.
Is there any way around this problem? This list is used to represent a
Function and thus the single terms may occur more than once.
Thank you in advance,
Daniel
Re: Placing the same object twice in an EList? [message #430214 is a reply to message #430209] |
Wed, 13 May 2009 09:52   |
--------------030103080803040300040501
Daniel,
Comments below.
> UNIQUE to False and ORDERED to true, but when trying to place an
> object a second time in the EList, an Illegal Argument Exception is
> thrown:
> violated
Unfortunately long ago there was a basic assumption that all EObject
lists had to be unique:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325
The only workaround right now is to specialize the list implementation
that's created to override isUnique to return true. And I don't
guarantee the rest of the framework will be entirely happy.
The above only works for non-containment non-bidirectional lists. For
all other cases, it makes no sense...
> Daniel
<html>
<head>
http-equiv="Content-Type">
</head>
Daniel,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:guehk9$4hj$1@build.eclipse.org" type="cite">Hi
everyone, I'm rahter new at EMF/ECORE and I wonder if its possible, to
<br>
<br>
violated
<br>
<br>
isn't.
<br>
</blockquote>
lists had to be unique:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325">https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325</a><br>
</blockquote>
Re: Placing the same object twice in an EList? [message #430216 is a reply to message #430214] |
Wed, 13 May 2009 10:48  |
Thank you for the quick reply!
The List is non-Containing and only uni-directional (as the Elements the
function may consist of, are derived from other diragrams and stored in
an containment List under the root node.) As I see the bug is out there
for a long time now. I'll see if there is a less invasive method for my
model to cope with this.
Ed Merks schrieb:
> Daniel,
> Comments below.
>> thrown:
>> violated
>> Daniel
FUDForum. Page generated in 0.44757 seconds
