how to use ant to generate genmodel [message #400771] |
Fri, 05 May 2006 08:49  |
hello, i want to generate a *.genmodel from a given ecore file using the
ant, how could i just run the ant file and can generate the genmodel and
finally get the gnerated code, is that possible to do it in this way? i
can't find some useful information, does anyone have some simple exanples
of this ant file, i will be grateful for some useful examples, thanks
larry
Re: how to use ant to generate genmodel [message #400872 is a reply to message #400771] |
Fri, 05 May 2006 11:07   |
--------------090608090208040801060106
Larry,
We have an Ant task for XSD -> GenModel but not one for Ecore ->
GenModel so the best I can do is point you to that as an example.
http://download.eclipse.org/tools/emf/xsd/2.2.0/javadoc/org/ eclipse/xsd/ecore/importer/taskdefs/XSDGeneratorTask.html
If someone works on Ecore -> GenModel, that would be a nice contribution
to the project...
> the ant, how could i just run the ant file and can generate the
> genmodel and finally get the gnerated code, is that possible to do it
> in this way? i can't find some useful information, does anyone have
> some simple exanples of this ant file, i will be grateful for some
> useful examples, thanks larry
<html>
<head>
http-equiv="Content-Type">
</head>
Larry,<br>
<br>
GenModel so the best I can do is point you to that as an example.<br>
<blockquote><a
href=" http://download.eclipse.org/tools/emf/xsd/2.2.0/javadoc/org/ eclipse/xsd/ecore/importer/taskdefs/XSDGeneratorTask.html"> http://download.eclipse.org/tools/emf/xsd/2.2.0/javadoc/org/ eclipse/xsd/ecore/importer/taskdefs/XSDGeneratorTask.html</a><br>
</blockquote>
contribution to the project...<br>
<br>
<br>
larry wrote:
<blockquote cite="mid4cce63b3f17ffc604ca888c99b63dc46$1@www.eclipse.org"
type="cite">
Re: how to use ant to generate genmodel [message #400954 is a reply to message #400950] |
Wed, 10 May 2006 07:20   |
Larry,
Marcelo is looking into providing an Ant task for this. Maybe it will
be ready for tomorrow's build. In the mean time, all I can do is point
you at source code. Such as the support for -ecore2GenModel in the
org.eclipse.emf.codegen.ecore.Generator.
larry wrote:
> hi:
> i have checked this xsd2genmodel package, it seems useful, but i
> can't use it, i didn't find any related information of this
> ecore2genmodel in ant build. i think the better way to do that is to
> use ant taskdef to define the task in the java code, but also i can't
> find enough information in this, if you have some information about
> how to use build a genmodel in the workspace and load ecore file in
> this genmodel, please show me an example, thank you inadvance
> regards
> larry
FUDForum. Page generated in 0.05876 seconds
