Home » Modeling » EMF » Overidding Action in Child or Sibling Menus
Overidding Action in Child or Sibling Menus [message #389287] Tue, 16 November 2004 23:34 Go to next message
So I've figured out how to override Commands in the ItemProviders so
that I can perform further tasks when I create a child. I would like to
continue to maintain separation between the edit and edit.ui layers. How
can I override the Actions in these Child/Sibling menus so that they do
other tasks like open a wizard or file dialog prior to creating the
Child/Sibling so that I can gather input used to configure the
Child/Sibling?
-thanks,
Mark
Re: Overidding Action in Child or Sibling Menus [message #389296 is a reply to message #389287] Wed, 17 November 2004 07:43 Go to previous messageGo to next message
Mark,
The menus and actions are constructed in the generated
ActionBarContributor, so that would be the place to specialize the
behavior to do additional actions.
> to continue to maintain separation between the edit and edit.ui
> layers. How can I override the Actions in these Child/Sibling menus so
> that they do other tasks like open a wizard or file dialog prior to
> creating the Child/Sibling so that I can gather input used to
> configure the Child/Sibling?
> -thanks,
> Mark
Re: Overidding Action in Child or Sibling Menus [message #389297 is a reply to message #389296] Wed, 17 November 2004 08:00 Go to previous messageGo to next message
My more specific question is actually how to best pass information
gathered in a Wizard or dialog into the custom Command I've created for
that feature. One thought I have is to somehow override the
CommandParameter to include this information such that the Command can
pick it out and use it. Is this logical?
-Mark
Ed Merks wrote:
> Mark,
>> -thanks,
>> Mark
Re: Overidding Action in Child or Sibling Menus [message #389298 is a reply to message #389297] Wed, 17 November 2004 08:12 Go to previous messageGo to next message
Mark,
It may be possible for the wizard to use its information just to create
"regular" commands. But if you need/want to use specialized commands,
it's best to try to reuse the CommandParameter without overriding it by
encoding your additional information as part of the value or the
collection (kind of like the way the new child descriptor is passed as
the value of the command parameter). If necessary/desirable, you can
always create a new command class that's recognized directly
ItemProviderAdapter.createCommand...
> for that feature. One thought I have is to somehow override the
> -Mark
> Ed Merks wrote:
>> Mark,
>>> so that they do other tasks like open a wizard or file dialog prior
>>> to creating the Child/Sibling so that I can gather input used to
>>> -thanks,
>>> Mark
Re: Overidding Action in Child or Sibling Menus [message #389299 is a reply to message #389298] Wed, 17 November 2004 08:39 Go to previous messageGo to next message
I've started to do something like this, I have the following in my
ActionBarContributor:
> protected Collection generateCreateChildActions(Collection descriptors, ISelection selection) {
> Collection actions = new ArrayList();
> if (descriptors != null) {
> for (Iterator i = descriptors.iterator(); i.hasNext(); ) {
> CommandParameter o = (CommandParameter)i.next();
> if(o.getValue() instanceof FeatureMap.Entry && ((FeatureMap.Entry)o.getValue()).getValue() instanceof SurveyType){
> actions.add(new CreateSurveyChildAction(activeEditorPart, selection, o));
> } else if(o.getValue() instanceof FeatureMap.Entry && ((FeatureMap.Entry)o.getValue()).getValue() instanceof CensusType){
> } else {
> actions.add(new CreateChildAction(activeEditorPart, selection, o));
> return actions;
And a separate CreateSurveyChildAction class in which I will place the
wizard. In my "OutlineItemProvider" I'm overriding the createChild
method to insert a custom command like so:
> /* (non-Javadoc)
> * @see org.eclipse.emf.edit.provider.ItemProviderAdapter#createCrea teChildCommand(org.eclipse.emf.edit.domain.EditingDomain, org.eclipse.emf.ecore.EObject, org.eclipse.emf.ecore.EStructuralFeature, java.lang.Object, int, java.util.Collection)
> protected Command createCreateChildCommand(EditingDomain domain,
> EObject owner, EStructuralFeature feature, Object value, int index,
> Collection collection) {
> if(value instanceof FeatureMap.Entry && ((FeatureMap.Entry)value).getValue() instanceof SurveyType){
> return new TestCommand(super.createCreateChildCommand(domain, owner, feature, value,index, collection));
> } else if(value instanceof FeatureMap.Entry && ((FeatureMap.Entry)value).getValue() instanceof CensusType){
> return super.createCreateChildCommand(domain, owner, feature, value,index, collection);
> class TestCommand extends CommandWrapper implements CommandActionDelegate{
> public Logger log = Logger.getLogger(TestCommand.class);
> public TestCommand(Command someOtherCommand){
> super(someOtherCommand);
> public void execute(){
> log.debug("Executing Command");
> super.execute();
> //doSomethingAfterExecution();
> public Collection getResult(){
> return super.getResult();
> /* (non-Javadoc)
> * @see org.eclipse.emf.edit.command.CommandActionDelegate#getImage( )
> public Object getImage() {
> return ((CommandActionDelegate)super.command).getImage();
> /* (non-Javadoc)
> * @see org.eclipse.emf.edit.command.CommandActionDelegate#getText()
> public String getText() {
> return ((CommandActionDelegate)super.command).getText();
> /* (non-Javadoc)
> * @see org.eclipse.emf.edit.command.CommandActionDelegate#getToolTi pText()
> public String getToolTipText() {
> return ((CommandActionDelegate)super.command).getToolTipText();
Ultimately, what I want to do in the Command is load another resource
containing all the children to be inserted at this point and copy/paste
them into model instead of just creating the new child (theres a couple
other tasks, but thats the primary activity). I'd like to maintain one
"undo" step, so that the user can remove the entire modification done by
the Wizard in one undo Command if they decide they didn't like what it did.
-Mark
Ed Merks wrote:
> Mark,
>> -Mark
>> Ed Merks wrote:
>>> Mark,
>>>> -thanks,
>>>> Mark
Re: Overidding Action in Child or Sibling Menus [message #394110 is a reply to message #389299] Tue, 05 July 2005 02:40 Go to previous messageGo to next message
hi mark,
have you succeeded with your action that opens a dialog, creates and links a resource for children?
i'd be very interested in your solution. would you mind sharing it?!
cheers
/eike
>> actions.add(new
>> actions.add(new
>> } else {
>> actions.add(new
>> return actions;
>> /* (non-Javadoc)
>> * @see
>> int index,
>> return new
>> return new
>> super.execute();
>> /* (non-Javadoc)
>> * @see
>> /* (non-Javadoc)
>> * @see
>> /* (non-Javadoc)
>> * @see
>> return
> -Mark
> Ed Merks wrote:
>> Mark,
>> create "regular" commands. But if you need/want to use specialized
>> commands, it's best to try to reuse the CommandParameter without
>> overriding it by encoding your additional information as part of the
>> value or the collection (kind of like the way the new child descriptor
>> is passed as the value of the command parameter). If
>> necessary/desirable, you can always create a new command class that's
>> recognized directly ItemProviderAdapter.createCommand...
>>> can pick it out and use it. Is this logical?
>>> -Mark
>>> Ed Merks wrote:
>>>> Mark,
>>>>> so that I can perform further tasks when I create a child. I would
>>>>> like to continue to maintain separation between the edit and
>>>>> edit.ui layers. How can I override the Actions in these
>>>>> Child/Sibling menus so that they do other tasks like open a wizard
>>>>> or file dialog prior to creating the Child/Sibling so that I can
>>>>> gather input used to configure the Child/Sibling?
>>>>> -thanks,
>>>>> Mark
Re: Overidding Action in Child or Sibling Menus [message #394123 is a reply to message #394110] Tue, 05 July 2005 08:52 Go to previous messageGo to next message
--------------010800020307040101010102
Eike,
I imagine it would involve overriding ResourceItemProvider something
like this:
public Collection getNewChildDescriptors(Object object,
EditingDomain editingDomain, Object sibling)
Collection newChildDescriptors = new ArrayList();
collectNewChildDescriptors(newChildDescriptors, object);
return newChildDescriptors;
protected void collectNewChildDescriptors(Collection
newChildDescriptors, Object object)
//super.collectNewChildDescriptors(newChildDescriptors, object);
newChildDescriptors.add
(createChildParameter
(new Integer(Resource.RESOURCE__CONTENTS),
EcoreFactory.eINSTANCE.createEObject()));
If there are change we should make in the framework to make this easier,
let us know.
Eike Stepper wrote:
> hi mark,
> cheers
> /eike
>>> actions.add(new
>>> actions.add(new
>>> } else {
>>> actions.add(new
>>> return actions;
>> the wizard. In my "OutlineItemProvider" I'm overriding the
>> createChild method to insert a custom command like so:
>>> /* (non-Javadoc)
>>> * @see
>>> int index,
>>> return new
>>> return new
>>> super.execute();
>>> /* (non-Javadoc)
>>> * @see
>>> return
>>> /* (non-Javadoc)
>>> * @see
>>> return
>>> /* (non-Javadoc)
>>> * @see
>>> return
>> copy/paste them into model instead of just creating the new child
>> (theres a couple other tasks, but thats the primary activity). I'd
>> like to maintain one "undo" step, so that the user can remove the
>> entire modification done by the Wizard in one undo Command if they
>> -Mark
>> Ed Merks wrote:
>>> Mark,
>>> descriptor is passed as the value of the command parameter). If
>>> that's recognized directly ItemProviderAdapter.createCommand...
>>>> -Mark
>>>> Ed Merks wrote:
>>>>> Mark,
>>>>>> would like to continue to maintain separation between the edit
>>>>>> and edit.ui layers. How can I override the Actions in these
>>>>>> wizard or file dialog prior to creating the Child/Sibling so that
>>>>>> I can gather input used to configure the Child/Sibling?
>>>>>> -thanks,
>>>>>> Mark
<html>
<head>
</head>
Eike,<br>
<br>
like this:<br>
<blockquote>&nbsp; public Collection getNewChildDescriptors(Object object,
EditingDomain editingDomain, Object sibling)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; Collection newChildDescriptors = new ArrayList();<br>
&nbsp;&nbsp;&nbsp; collectNewChildDescriptors(newChildDescriptors, object);<br>
&nbsp;&nbsp;&nbsp; return newChildDescriptors;<br>
&nbsp; }<br>
<br>
&nbsp; protected void collectNewChildDescriptors(Collection
newChildDescriptors, Object object)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; //super.collectNewChildDescriptors(newChildDescriptors, object);<br>
&nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; newChildDescriptors.add<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; (createChildParameter<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; (new Integer(Resource.RESOURCE__CONTENTS),<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; EcoreFactory.eINSTANCE.createEObject()));<br>
&nbsp; }<br>
</blockquote>
easier, let us know.<br>
<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid42CA2B43.8050600@sympedia.de" type="cite">hi mark,
<br>
<br>
<br>
<br>
<br>
cheers
<br>
/eike
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">I've started to do something like this, I
have the following in my ActionBarContributor:
<br>
<br>
<blockquote type="cite">&nbsp;&nbsp;&nbsp; protected Collection
selection) {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Collection actions = new ArrayList();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (descriptors != null) {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for (Iterator i = descriptors.iterator(); i.hasNext(); ) {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; CommandParameter o = (CommandParameter)i.next();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if(o.getValue() instanceof
FeatureMap.Entry &amp;&amp; ((FeatureMap.Entry)o.getValue()).getValue()
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; actions.add(new
CreateSurveyChildAction(activeEditorPart, selection, o));&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; } else if(o.getValue() instanceof FeatureMap.Entry
&amp;&amp; ((FeatureMap.Entry)o.getValue()).getValue() instanceof
CensusType){
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; } else {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; actions.add(new CreateChildAction(activeEditorPart,
selection, o));&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp ; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return actions;
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<blockquote type="cite">/* (non-Javadoc)
<br>
&nbsp;&nbsp;&nbsp;&nbsp; * @see
<br>
&nbsp;&nbsp;&nbsp;&nbsp; */
<br>
&nbsp;&nbsp;&nbsp; protected Command createCreateChildCommand(EditingDomain domain,
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; EObject owner, EStructuralFeature feature, Object value,
int index,
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Collection collection) {
<br>
&nbsp;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if(value instanceof FeatureMap.Entry &amp;&amp;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return new
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; } else if(value instanceof FeatureMap.Entry &amp;&amp;
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return super.createCreateChildCommand(domain, owner,
<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; class TestCommand extends CommandWrapper implements
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; public Logger log = Logger.getLogger(TestCommand.class);
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; public TestCommand(Command someOtherCommand){
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; super(someOtherCommand);
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; public void execute(){
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; log.debug("Executing Command");
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; super.execute();
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; //doSomethingAfterExecution();
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; public Collection getResult(){
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return super.getResult();
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; /* (non-Javadoc)
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; * @see
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; */
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; public Object getImage() {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; public String getText() {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; public String getToolTipText() {
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp; };
<br>
</blockquote>
<br>
<br>
by the Wizard in one undo Command if they decide they didn't like what
it did.
<br>
<br>
-Mark
<br>
<br>
Ed Merks wrote:
<br>
<br>
<blockquote type="cite">Mark,
<br>
<br>
"regular" commands.&nbsp; But if you need/want to use specialized commands,
the value of the command parameter).&nbsp; If necessary/desirable, you can
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
<blockquote type="cite">My more specific question is actually how
to best pass information gathered in a Wizard or dialog into the custom
Command I've created for that feature. One thought I have is to somehow
override the CommandParameter to include this information such that the
Command can pick it out and use it. Is this logical?
<br>
<br>
-Mark
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
<blockquote type="cite">So I've figured out how to override
Commands in the ItemProviders so that I can perform further tasks when
I create a child. I would like to continue to maintain separation
between the edit and edit.ui layers. How can I override the Actions in
these Child/Sibling menus so that they do other tasks like open a
wizard or file dialog prior to creating the Child/Sibling so that I can
<br>
<br>
-thanks,
<br>
Mark
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010800020307040101010102--
Re: Overidding Action in Child or Sibling Menus [message #394141 is a reply to message #394123] Tue, 05 July 2005 11:39 Go to previous message
Ed Merks schrieb:
> Eike,
> like this:
> let us know.
Thanks Ed. I'll try it tomorrow and come back with comments ;-)
/Eike
> Eike Stepper wrote:
>> hi mark,
>> cheers
>> /eike
>>>> actions.add(new
>>>> actions.add(new
>>>> } else {
>>>> actions.add(new
>>>> return actions;
>>>> /* (non-Javadoc)
>>>> * @see
>>>> int index,
>>>> return new
>>>> return new
>>>> super.execute();
>>>> /* (non-Javadoc)
>>>> * @see
>>>> return
>>>> /* (non-Javadoc)
>>>> * @see
>>>> return
>>>> /* (non-Javadoc)
>>>> * @see
>>>> return
>>> -Mark
>>> Ed Merks wrote:
>>>> Mark,
>>>>> -Mark
>>>>> Ed Merks wrote:
>>>>>> Mark,
>>>>>>> -thanks,
>>>>>>> Mark
Previous Topic:[newbie] what is the use of uml2 providers?
Next Topic:XSDEcoreBuilder: metaObjectID == -1 for non XML-namespace typedefinitions
Current Time: Wed Jul 16 00:23:52 EDT 2025
Powered by FUDForum. Page generated in 0.28991 seconds
