Re: Unique Id and Validation [message #380504 is a reply to message #380000] |
Tue, 17 April 2007 11:32 |
Ed Merks Messages: 33147 Registered: July 2009 |
Jens,
The unique attribute only has meaning if the upper bound of the typed
element is greater than one and in that case it implies that the same
value may not occur more than once among the values of that one
feature. You'd use EAttribute.isID to specify that the value represents
an ID that must be unique within the containing resource; this will also
cause that feature's value to be used as the ID for references to the
object carrying that ID.
Cross posting to EMF's newsgroup rather than the general Modeling
newsgroup would be better in the future.
Jens Krause wrote:
> Hi there,
> i have a GMF diagram and want to use the EMFT Validation in there.
> I thougth if i set the attribute "unique" of an EClass attribute to
> true in my ecore file, the validation automatically checks if this id
> is really unique. But it seems that isn't so.
> For better understanding here a short view of my structure:
> EClass Field
> +- EAttribute id, Type "ID <java.lang.String>"
> +- Unique "true"
> But if i now set the same id for 2 Fields, no error is shown. Do i
> have to increase the priority for the validation provider. It's now
> set to "medium". Or do i have to add an extra Audit Rule for that?
> Sorry for the crossposting, but i thought this could match both
> newsgroups.
> reagards
> Jens K.
> ** f'up set to eclipse.modeling **
Ed Merks
Re: Unique Id and Validation [message #592338 is a reply to message #380000] |
Jens,
Jens Krause wrote:
> Hi there,
> EClass Field
> +- Unique "true"
> newsgroups.
> reagards
> Jens K.
Ed Merks
FUDForum. Page generated in 0.04104 seconds
