Re: Absolute paths for URL access in 2.3.2 [message #367328 is a reply to message #367308] |
Wed, 04 March 2009 20:48 |
Pinny,
It appears that the web.xml has been changed. Look in the WEB-INF
directory and find the web.xml.
Change the following setting
<!-- If only access the reprot resources under working folder. Default
is true -->
<context-param>
<param-name>WORKING_FOLDER_ACCESS_ONLY</param-name>
<param-value>true</param-value>
</context-param>
to
is true -->
<context-param>
<param-value>false</param-value>
</context-param>
Jason
Pinny Markowitz wrote:
> I have been using absolute paths as a URL parameter (in Windows as
> '__report=C:/foo/bar.rptdesign') to reference the rptdesign files, and
> it has worked fine through v2.3.1. When testing in v2.3.2 however, I am
> getting an error: 'There is no report design object available.' Using a
> relative path on the same report fixed the error, but I really would
> like to use an absolute path as the in the past. Anyone else
> experiencing this, or know a way around this problem?
FUDForum. Page generated in 0.03168 seconds
