Re: Trying to get P2 to work [message #336951 is a reply to message #336945] |
Wed, 15 July 2009 17:27 |
Originally posted by: fakemail.xyz.de
instead of using exported features / update site ...
use the repository build when exporting the product as update site.
it seems like you can only update features not part of the product by
themselve (easiest by exporting them from the features page and a
category.xml file not with an update site project)
Christian
Phill_Perryman@Mitel.COM schrieb:
> I am trying (with a lot of difficulty) to get my existing 3.3
> application upgraded to using P2 auto updates.
> I have migrated to 3.5 and rebuilt the application with all plugins and
> features at 2.2.0. Used the export wizard to create the application and
> set the p2.inf location to point to the local update site. I also
> included all the p2 and ecf plugins to that the standard install and
> update menu items appear.
> I then update one of the features and plugin to 2.2.1 and build the
> update site (build all). The update software menu says there is nothing
> to update which I suspect is because of the problem below which gets
> reported when I try an install new software.
> It lets me know it is already installed at 2.2.0 so it will do an update
> instead (great) but then it fails with this cryptic error message. In
> 3.3 it was fine to have a 2.2.0 and a 2.2.1 version of a feature
> installed and eclipse would just load the latest version. Why is this
> complaining.
> Also if anyone knows of a step by step guide to making P2 updating work
> it would be appreciated. All the articles so far read say do something
> but without telling you exactly what than means.
> Your original request has been modified.
> "Proposal Generator Custom Editor" is already installed, so an update
> will be performed instead.
> Cannot complete the install because of a conflicting dependency.
> Software being installed: Proposal Generator Custom Editor 2.2.1
> (com.mitel.mpg.editor.feature.feature.group 2.2.1)
> Software currently installed: com.mitel.swb.Application 2.2.0
> Only one of the following can be installed at once:
> Proposal Generator Custom Editor 2.2.0
> (com.mitel.mpg.editor.feature.feature.jar 2.2.0)
> (com.mitel.mpg.editor.feature.feature.jar 2.2.1)
> Cannot satisfy dependency:
> From: Proposal Generator Custom Editor 2.2.0
> (com.mitel.mpg.editor.feature.feature.group 2.2.0)
> To: com.mitel.mpg.editor.feature.feature.jar [2.2.0]
> From: Proposal Generator Custom Editor 2.2.1
> To: com.mitel.mpg.editor.feature.feature.jar [2.2.1]
> From: com.mitel.swb.Application 2.2.0
> To: com.mitel.mpg.editor.feature.feature.group [2.2.0]
FUDForum. Page generated in 0.03054 seconds
