Home » Eclipse Projects » DSDP - Target Management » how to correctly init RSE
how to correctly init RSE [message #32205] |
Mon, 23 February 2009 10:07 |
Carmelo Messages: 224 Registered: July 2009 |
Hi all,
I'm using my own subsystem to connect to a db in an RCP application ...
The question is what is the right wait to initialize the RSE Core library?
I have tried with
try
RSECorePlugin.waitForInitCompletion();
catch (InterruptedException e)
// TODO Auto-generated catch block
e.printStackTrace();
ISystemRegistry sr = RSECorePlugin.getTheSystemRegistry();
but still I get the following error in the application log:
!MESSAGE While loading class
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner ", thread
"Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
"Thread[main,6,main]" to finish starting bundle
"update@plugins/org.eclipse.rse.ui_3.0.2.v200812041720.jar [988]". To avoid
deadlock, thread "Thread[Worker-1,5,main]" is proceeding but
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner " may not be
fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
"update@plugins/org.eclipse.rse.ui_3.0.2.v200812041720.jar" by thread
"main".
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1141)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:258)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPref erencesManager.java:510)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 15 more
Root exception:
Re: how to correctly init RSE [message #32342 is a reply to message #32205] |
Mon, 23 February 2009 14:14 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi Kar,
at the moment, the RSE UI / Non-UI separation has not yet proceeded
enough that you could initialize RSEcorePlugin only without also loading
RSEUIPlugin.
For now, please reference RSEUIPlugin in any way before waiting for init
completion.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Kar wrote:
> Hi all,
> I have tried with
> try
> thread "Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
> avoid deadlock, thread "Thread[Worker-1,5,main]" is proceeding but
> not be fully initialized.
> !STACK 0
> "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: how to correctly init RSE [message #32377 is a reply to message #32342] |
Mon, 23 February 2009 14:48 |
Thanks Martin
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:49A2AF61.4050603@windriver.com...
> Hi Kar,
> at the moment, the RSE UI / Non-UI separation has not yet proceeded enough
> RSEUIPlugin.
> completion.
> Kar wrote:
>> Hi all,
>> library?
>> I have tried with
>> try
>> !STACK 0
>> "main".
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> ... 15 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: how to correctly init RSE [message #579256 is a reply to message #32205] |
Hi Kar,
RSEUIPlugin.
completion.
Kar wrote:
> Hi all,
> I have tried with
> try
> !STACK 0
> "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: how to correctly init RSE [message #579270 is a reply to message #32342] |
Thanks Martin
> Hi Kar,
> RSEUIPlugin.
> completion.
> Kar wrote:
>> Hi all,
>> library?
>> I have tried with
>> try
>> !STACK 0
>> "main".
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> ... 15 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Current Time: Fri Apr 26 07:28:05 GMT 2024
Powered by FUDForum. Page generated in 0.05165 seconds
