Exception on 4.2.0 preference spell check preference page [message #317510] |
Thu, 05 July 2007 15:01 |
Originally posted by: kkoster.solengocapital.com
Since I didn't see a newsgroup to possible problems with the Eclipse
platform (I don't have a bugzilla logon), I decided to post this exception
here. I received this exception when saving global workbench preferences
after de-selecting spell checking. No other preference page modifications
where made and the spell check page was never altered prior to the
de-selection of spell checking. Stack trace follows:
!ENTRY org.eclipse.ui.workbench 4 2 2007-07-05 10:55:37.297
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
at org.eclipse.jface.text.DefaultTextHover.<init>(DefaultTextHover.java:38)
org.eclipse.ui.editors.text.TextSourceViewerConfiguration$Te xtHover. <init>(TextSourceViewerConfiguration.java:462)
org.eclipse.ui.editors.text.TextSourceViewerConfiguration.ge tTextHover(TextSourceViewerConfiguration.java:159)
org.eclipse.wst.sse.ui.StructuredTextEditor.updateHoverBehav ior(StructuredTextEditor.java:3262)
org.eclipse.wst.sse.ui.StructuredTextEditor.handlePreference StoreChanged(StructuredTextEditor.java:2505)
org.eclipse.ui.texteditor.AbstractTextEditor$PropertyChangeL istener.propertyChange(AbstractTextEditor.java:658)
org.eclipse.ui.texteditor.ChainedPreferenceStore.firePropert yChangeEvent(ChainedPreferenceStore.java:164)
org.eclipse.ui.texteditor.ChainedPreferenceStore.handlePrope rtyChangeEvent(ChainedPreferenceStore.java:431)
org.eclipse.ui.texteditor.ChainedPreferenceStore.access$0(Ch ainedPreferenceStore.java:408)
org.eclipse.ui.texteditor.ChainedPreferenceStore$PropertyCha ngeListener.propertyChange(ChainedPreferenceStore.java:69)
org.eclipse.ui.preferences.ScopedPreferenceStore$3.run(Scope dPreferenceStore.java:371)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.preferences.ScopedPreferenceStore.firePropert yChangeEvent(ScopedPreferenceStore.java:368)
org.eclipse.ui.preferences.ScopedPreferenceStore$2.preferenc eChange(ScopedPreferenceStore.java:192)
org.eclipse.core.internal.preferences.EclipsePreferences$2.r un(EclipsePreferences.java:746)
org.eclipse.core.internal.preferences.EclipsePreferences.fir ePreferenceEvent(EclipsePreferences.java:749)
org.eclipse.core.internal.preferences.EclipsePreferences.put (EclipsePreferences.java:762)
org.eclipse.ui.preferences.ScopedPreferenceStore.setValue(Sc opedPreferenceStore.java:782)
org.eclipse.wst.sse.ui.internal.preferences.OverlayPreferenc eStore.propagateProperty(OverlayPreferenceStore.java:350)
org.eclipse.wst.sse.ui.internal.preferences.OverlayPreferenc eStore.propagate(OverlayPreferenceStore.java:298)
org.eclipse.wst.sse.ui.internal.preferences.ui.StructuredTex tEditorPreferencePage.performOk(StructuredTextEditorPreferen cePage.java:412)
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:926)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
org.eclipse.jface.preference.PreferenceDialog.okPressed(Pref erenceDialog.java:906)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okP ressed(FilteredPreferenceDialog.java:374)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.ok Pressed(WorkbenchPreferenceDialog.java:164)
org.eclipse.jface.preference.PreferenceDialog.buttonPressed( PreferenceDialog.java:233)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
FUDForum. Page generated in 0.03361 seconds
