Re: Task Update [message #31274 is a reply to message #31202] |
Fri, 19 September 2008 13:27 |
Alex Panchenko Messages: 342 Registered: July 2009 |
Hi Gunter,
Could you please write the size of the files you are editing?
I have just tried to edit the large file with 5k lines (~270kb) and it
looks really slow - we will try to optimize it on Monday. I will post
the results of our optimization efforts.
At the moment would you please try to close the outline view and disable
folding.
Task tags processing should not be slow, but you can disabled it in TCL
preferences if you like, unfortunately this preference is not persisted
in 0.95 - will be fixed in the next build.
Alex
Gunter Pfeiffer wrote:
> Hello,
> i am working with ganymade 3.4.0 and DLTK Build
> dltk-core-M-M200809160708-200809160708-incubation
> dltk-itcl-M-M200809160708-200809160708-incubation
> dltk-tcl-M-M200809160708-200809160708-incubation
> dltk-xotcl-M-M200809160708-200809160708-incubation
> Most, but not allways i have the problem:
> when i delete a character in the eclips tcl editor
> the system will stop for 1 or 2 secondes before the character
> will be deleded.If you want to write fast, this is very obstructively.
> On this reason i have look in the preferences, but i found nothing to
> disable
> to correkt this problem. Maybe the task function could be the reason,
> because her reaction on changes is very fast. Is there a way to decrease
> the update time for the TCL Task Tags ?
> regards gunter
Re: Task Update [message #31336 is a reply to message #31274] |
Sun, 21 September 2008 12:06 |
Gunter,
Last 0.95 build contains optimizations for large TCL files, though I
would recommend to use 1.0 integration builds - it is under active
development and have more features. The next 1.0 build will be available
on Monday.
Alex
Alex Panchenko wrote:
> Hi Gunter,
> folding.
> Alex
>> Hello,
>> disable
>> decrease the update time for the TCL Task Tags ?
>> regards gunter
FUDForum. Page generated in 0.04614 seconds
