The program 'Eclipse' received an X Window System error. [message #539642] |
Fri, 11 June 2010 14:56 |
I'm seeing Eclipse disappear on Ubuntu now. Running it in a terminal I
get this error feedback:
This probably reflects a bug in the program.
The error was 'RenderBadPicture (invalid Picture parameter)'.
(Details: serial 76652 error_code 158 request_code 151 minor_code 7)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
My platform:
Ubuntu 32 (All Effects Off)
eclipse.buildId=M20100211-1343
eclipse.vmargs=-Xms40m
-Xmx256m
java.fullversion=JRE 1.6.0 IBM J9 2.4 Linux x86-32
jvmxi3260sr7-20091214_49398 (JIT enabled, AOT enabled)
J9VM - 20091214_049398
JIT - r9_20091123_13891
GC - 20091111_AA
Any help appreciated,
Dilton
FUDForum. Page generated in 0.04240 seconds
