Re: [Acceleo] How to register other metamodels? [message #509066 is a reply to message #508176] |
Thu, 21 January 2010 05:34 |
--------------040701040009050805040506
Hi Anderson,
Sorry for the delay, I let your question slip trough. You can use
metamodels not only through their NsURI, but also by using their path
relative to the workspace in the module signature.
For example if your metamodel is in projet "myproject", in the folder
"model" within your workspace, you can define an Acceleo module such as
[module('/myproject/model/mymetamodel.ecore')/]
Laurent Goubet
Obeo
Anderson Ledo wrote:
> With the MOFScript tool you can specify a path for the metamodels you
> want to use or you can add your ecore metamodels directly inside the
> plugin directory. It would be nice if an equivalent solution were
> available.
> Regards...
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040701040009050805040506--
Re: [Acceleo] How to register other metamodels? [message #510650 is a reply to message #509634] |
Thu, 28 January 2010 08:53 |
--------------010508000204050207070707
Hi Anderson,
Version 0.8.1 didn't have what's needed to resolve metamodels as
workspace-relative pathes. You have to follow Andre's step-by-step to
get your metamodel to be resolved with its NsURI only.
Laurent Goubet
Obeo
Andre wrote:
> HI anderson.
> i'm not an expert on Acceleo, but have you tried the steps below?
> 1) generate the genmodel of the Ecore file
> 2) generate all files from genmodel
> 3) run a new Eclipse application
> 4) on the new workspace, create the Acceleo Project (you already did this)
> 5) create a New Acceleo Module File; on Metamodel URI, click on
> 'Browse...', then 'Runtime Version'.. your metamodel should appear now..
> i hope it will work..
--------------010508000204050207070707--
FUDForum. Page generated in 0.04537 seconds
