Home » Modeling » M2T (model-to-text transformation) » How to invoke Xpand template into a Java-code????(M2T Xpand)
How to invoke Xpand template into a Java-code???? [message #637685] Mon, 08 November 2010 05:55 Go to next message
I created a plug-in (I work with the Yakindu Workbench).
This Plug-in should generate Java code for state machine diagram (statemachine-File).
So i have a custom action (ActionGenerateJavaCode.java) that should invoke the Xpand template.
When I run the action, then I get the following error message:
EvaluationException : No Definition templates::Statechart::Root for statemachine::Statechart could be found!
Internal error: element was null
the custom action looks like this:
import org.eclipse.core.resources.IFile;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.xpand2.XpandExecutionContextImpl;
import org.eclipse.xpand2.XpandFacade;
import org.eclipse.xpand2.output.Outlet;
import org.eclipse.xpand2.output.Output;
import org.eclipse.xpand2.output.OutputImpl;
import org.eclipse.xtend.typesystem.emf.EmfMetaModel;
import statemachine.impl.StatechartImpl;
public class ActionGenerateJavaCode implements IObjectActionDelegate{
private ISelection selection;
public void run(IAction action) {
try{
IFile file = getFile();
URI fileURI = null;
java.net.URI uri = file.getLocationURI();
fileURI = URI.createURI(uri.toString(), true);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(
statemachine.StatemachinePackage.eINSTANCE.getNsURI(),
statemachine.StatemachinePackage.eINSTANCE);
Resource resource = resourceSet.createResource(fileURI);
try {
resource.load(null);
catch (Exception e) {
e.printStackTrace();
resourceSet.getResources().add(resource);
StatechartImpl statechart = (StatechartImpl) resource.getContents().get(0);
//Xpand
Output out = new OutputImpl();
out.addOutlet(new Outlet("src-gen"));
XpandExecutionContextImpl executionContext = new XpandExecutionContextImpl(out, null);
//Configure the metamodels
EmfMetaModel emfMetaModel = new EmfMetaModel();
emfMetaModel.setMetaModelPackage(statemachine.StatemachinePa ckage.class.getName());
emfMetaModel.setMetaModelPackage(statechartexpressions.State chartexpressionsPackage.class.getName());
executionContext.registerMetaModel(emfMetaModel);
XpandFacade xpandFacade = XpandFacade.create(executionContext);
Object [] params =null;
xpandFacade.evaluate("templates::Statechart::Root", statechart, params);
System.out.println("End generate code");
public void selectionChanged(IAction action, ISelection selection) {
this.selection = selection;
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
public IFile getFile(){
return (IFile)((IStructuredSelection)selection).getFirstElement();
Re: How to invoke Xpand template into a Java-code???? [message #638169 is a reply to message #637685] Wed, 10 November 2010 04:50 Go to previous messageGo to next message
Hello IdaEss,
the code look good. Please check if the Templatefile Statechart containing the Define Root is accessible by your code. Do you run the code from within a plugin? Is the template accessible within the plugin?
IdaEss wrote on Mon, 08 November 2010 11:55
Darius
icon9.gif  Re: How to invoke Xpand template into a Java-code???? [message #638246 is a reply to message #638169] Wed, 10 November 2010 11:12 Go to previous message
How to know that the templateFile is accessible by the code
My template file looks like this:
«IMPORT statemachine»
«IMPORT statechartexpressions»
«EXTENSION com::yakindu::statechart::codegenerator::java::extensions::E xtensions»
«IMPORT com::yakindu::statechart::codegenerator::java::templates::ge neric»
«DEFINE Root FOR Statechart»
«FILE getImplPackagePath(this) + getStatechartImplClassName(this) + "TestCase.java"»
«REM» »package «getImplPackage(this)»;«ENDREM»
«EXPAND Imports»
«EXPAND BasicImports»
«EXPAND MessinaImports»
«EXPAND ExceptionsImports»
public class «getStatechartImplClassName(this)»TestCase extends AllSignals
«getStatechartImplClassName(this)» statechart;
public int run() throws IOException, TestFailedException,
InterruptedException {
«ENDDEFINE»
When i execute my Plug-in (Right click on the project -> Run As -> Eclipse Application) then a second Yakindu Workbench (Yakindu instance) starts.
I created a new Java project in this second workbench and ein added a state machine diagramm (MyStatemachine). The context menu of the statemachine file (MyStatemachine.statemachine) contains a the entry "Generate Java-code". If i click on this entry then the java-code of the statemachine should be created but it doesn't work Sad . Instead of i get the error message on the first workbench Embarrassed
error message:
Best regards
Ida
Previous Topic:(Acceleo) Acceleo Evaluation Exception
Next Topic:[Xpand] Using Xpand programmatically
Current Time: Mon Jul 21 14:02:01 EDT 2025
Powered by FUDForum. Page generated in 0.04479 seconds
