Home » Eclipse Projects » Remote Application Platform (RAP) » swt.widgets.Text error when append
swt.widgets.Text error when append [message #664386] Fri, 08 April 2011 11:32 Go to next message
Hi all again,
I resolved the previous issue with swt.widgets.Text in multi-line form.
Now I have redirected all the output in a handler for append the new messages:
private void redirectSystemStreams() {
OutputStream out = new OutputStream() {
public void write(final int b) throws IOException {
updateTextPane(String.valueOf((char) b));
public void write(byte[] b, int off, int len) throws IOException {
updateTextPane(new String(b, off, len));
public void write(byte[] b) throws IOException {
write(b, 0, b.length);
System.setOut(new PrintStream(out, true));
//with this method to append text to the Text
private void updateTextPane(final String text) {
Display.getDefault().syncExec(new Runnable() {
public void run() {
//receivedText is a private Text
receivedText.append(text);
Now I receive this error:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3526)
at org.eclipse.swt.SWT.error(SWT.java:3446)
at org.eclipse.swt.SWT.error(SWT.java:3417)
at org.eclipse.swt.widgets.Widget.error(Widget.java:953)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:886)
It's clear an error linked to the method UpdateText but why? I have also tried with .asyncExec but still the same error.
Give me the last help please! Sad
Peter
Re: swt.widgets.Text error when append [message #664528 is a reply to message #664386] Sun, 10 April 2011 17:12 Go to previous messageGo to next message
Hi Peter,
Invalid thread access means that you access a widget method from a thread
that is not the UIThread of this widget's display. If you call asyncExec
() on another session's display, you will also get this exception. You
should therefore replace Display.getDefault() with receivedText.getDisplay
And you should always prefer asyncExec() over syncExec() unless you have
a very good reason to use the latter.
HTH, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: swt.widgets.Text error when append [message #664530 is a reply to message #664528] Sun, 10 April 2011 18:16 Go to previous messageGo to next message
Ralf,
I'm sorry I've just read the API for Text
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/api/org/eclipse/swt/widgets/Text .html
and Text don't have getDisplay(). Which method are you talking about?
Thank you for the reply,
Peter
Re: swt.widgets.Text error when append [message #664553 is a reply to message #664530] Mon, 11 April 2011 02:52 Go to previous messageGo to next message
Peter,
read on to the "members inherited from ..." section. Text is derived
from Widget, which provides getDisplay().
HTH
Rüdiger
On 11.04.2011 00:16, Peter Boccia wrote:
> Ralf,
> Peter
Re: swt.widgets.Text error when append [message #664595 is a reply to message #664553] Mon, 11 April 2011 06:20 Go to previous messageGo to next message
Thank you Ralf!
It works but in RAP it does NOT scroll automatically at the end of the text? I just read a bug of this issue, it's dated July 2010, but no one fixed it.
How can I auto-scroll to the end?
I try putting a personal ScrollBar but it doesn't work.
Thank you.
Re: swt.widgets.Text error when append [message #664604 is a reply to message #664595] Mon, 11 April 2011 07:04 Go to previous messageGo to next message
Hi Peter,
we have this bug opened:
319227: [Text] Multi text does not auto-scroll on append, insert operation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=319227
but, it's hard (or even impossible) to fix it with current client side
implementation.
The only way (currently) to scroll to the end is to call setText with
the complete text. Of course, this will lead to performance problems
with really large texts - like in your case, append to the log and set
the complete log. Maybe a console with last events/logs on the top
(instead of the bottom) will solve your problem - no need for scrolling.
HTH,
Ivan
On 4/11/2011 1:20 PM, Peter Boccia wrote:
> Thank you Ralf!
> one fixed it.
> Thank you.
Re: swt.widgets.Text error when append [message #664904 is a reply to message #664604] Tue, 12 April 2011 09:15 Go to previous messageGo to next message
Yes Ivan,
I was talking right about that bug.
I resolved in a simple way:
//set a selection at the beginning of the text
text.setSelection(0);
//insert the text at the head +\n if is not yet in the string
text.insert(newMessage+"\n")
It's easy to understand: to make all the new messages always displayed I choose the contrariway solution: the newest message at the head of the text instead of the end.
Typically in a chat the newest message go in the end and the scrollbar go down at the end, but on RAP this is not possible.
So this might be the easiest way to do it.
I hope this time is me to had help someone.
Peter
Re: swt.widgets.Text error when append [message #671810 is a reply to message #664904] Thu, 19 May 2011 00:10 Go to previous message
This may work too. But we should call setFocus() for it to work.
text.setSelection(text.getText().length());
text.setFocus();
Previous Topic:Clustering Solutions
Next Topic:Updating the view/refreshing an image
Current Time: Mon Jul 21 16:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.24524 seconds
