Home » Archived » M2M (model-to-model transformation) » Problem LLaunching Families2Persons Tutorial Project(java.lang.NullPointerException)
Problem LLaunching Families2Persons Tutorial Project [message #630173] Thu, 30 September 2010 17:30 Go to next message
I keep getting this strange error when I try to run the atl project from the tutorial:
http://wiki.eclipse.org/ATL/Tutorials_-_Create_a_simple_ATL_ transformation
An internal error occurred during: "Launching Families2Persons".
at org.eclipse.debug.internal.core.LaunchConfiguration.getLaunchManager(LaunchConfiguration.java:461)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:863)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
this is the eclipse version information:
eclipse.buildId=I20100608-0911
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments:  -product org.eclipse.epp.package.modeling.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.modeling.product
Does anyone have any idea what could be wrong?
Thanx for some hints.
Cheers Björn
Now the error changed:
at org.eclipse.m2m.atl.debug.core.AtlDebugTarget.start(AtlDebugTarget.java:181)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:290)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
This is the Families.ecore:
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Families">
  <eClassifiers xsi:type="ecore:EClass" name="Family">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" lowerBound="1"
        eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="father" lowerBound="1"
        eType="#//Member" containment="true" eOpposite="#//Member/familyFather"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="mother" lowerBound="1"
        eType="#//Member" containment="true" eOpposite="#//Member/familyMother"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="sons" upperBound="-1" eType="#//Member"
        containment="true" eOpposite="#//Member/familySon"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="daughters" upperBound="-1"
        eType="#//Member" containment="true" eOpposite="#//Member/familyDaughter"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Member">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" lowerBound="1"
    <eStructuralFeatures xsi:type="ecore:EReference" name="familyFather" eType="#//Family"
        eOpposite="#//Family/father"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="familyMother" eType="#//Family"
        eOpposite="#//Family/mother"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="familySon" eType="#//Family"
        eOpposite="#//Family/sons"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="familyDaughter" eType="#//Family"
        eOpposite="#//Family/daughters"/>
  </eClassifiers>
</ecore:EPackage>
this is the Persons.ecore:
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Persons">
  <eClassifiers xsi:type="ecore:EClass" name="Person" abstract="true">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="fullName" lowerBound="1"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Male" eSuperTypes="#//Person"/>
  <eClassifiers xsi:type="ecore:EClass" name="Female" eSuperTypes="#//Person"/>
</ecore:EPackage>
This is the Families2Persons.atl file:
module Families2Persons;
-- @path Families=/Families2Persons/Families.ecore
-- @path Persons=/Families2Persons/Persons.ecore
create OUT: Persons from IN: Families;
helper context Families!Member def: isFemale(): Boolean =
    if not self.familyMother.oclIsUndefined() then
        true
    else
        if not self.familyDaughter.oclIsUndefined() then
            true
        else
            false
        endif
    endif;
helper context Families!Member def: familyName: String =
    if not self.familyFather.oclIsUndefined() then
        self.familyFather.lastName
    else
            self.familyMother.lastName
        else
            if not self.familySon.oclIsUndefined() then
                self.familySon.lastName
            else
                self.familyDaughter.lastName
            endif
        endif
    endif;
rule Member2Male {
    from
        s: Families!Member (not s.isFemale())
    to
        t: Persons!Male (
            fullName <- s.firstName + ' ' + s.familyName
rule Member2Female {
    from
        s: Families!Member (s.isFemale())
    to
        t: Persons!Female (
and this is the sample-Families.xmi file:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="Families">
    <Family lastName="March">
        <father firstName="Jim"/>
        <mother firstName="Cindy"/>
        <sons firstName="Brandon"/>
        <daughters firstName="Brenda"/>
    </Family>
    <Family lastName="Sailor">
        <father firstName="Peter"/>
        <mother firstName="Jackie"/>
        <sons firstName="David"/>
        <sons firstName="Dylan"/>
        <daughters firstName="Kelly"/>
    </Family>
</xmi:XMI>
when trying to open the xmi file with the default-editor I keep getting this error:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'Families' not found. (platform:/resource/Families2Persons/sample-Families.xmi, 3, 27)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
    at org.eclipse.emf.ecore.presentation.EcoreEditor.createModelGen(EcoreEditor.java:1062)
    at org.eclipse.emf.ecore.presentation.EcoreEditor.createModel(EcoreEditor.java:1082)
    at org.eclipse.emf.ecore.presentation.EcoreEditor.createPages(EcoreEditor.java:1147)
    at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
    at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
    at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
    at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
    at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
    at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
    at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
    at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
    at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
    at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
    at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
    at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
    at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
    at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
    at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
    at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
    at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
    at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
    at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
    at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
    at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
    at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
    at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
    at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:331)
    at org.eclipse.ui.actions.OpenWithMenu$4.handleEvent(OpenWithMenu.java:360)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3552)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3171)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at java.lang.reflect.Method.invoke(Method.java:616)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'Families' not found. (platform:/resource/Families2Persons/sample-Families.xmi, 3, 27)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2591)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2422)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1299)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1468)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1019)
    at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
    at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
    at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:504)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1340)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2732)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:625)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:488)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:812)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:741)
    at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1208)
    at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:525)
    at javax.xml.parsers.SAXParser.parse(SAXParser.java:392)
    at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
    at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
    at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
    at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
    ... 60 more
[Updated on: Thu, 30 September 2010 17:43] by Moderator
Re: Problem LLaunching Families2Persons Tutorial Project [message #630233 is a reply to message #630173] Fri, 01 October 2010 05:34 Go to previous message
ok here are the solutions:
1)
I changed the "sample-Families.xmi" to look like this:
<Families:Family xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:Families="Families" lastName="asdf">
  <father firstName="qwer"/>
  <mother firstName="tzui"/>
  <sons firstName="ghjk"/>
  <daughters firstName="yxcv"/>
</Families:Family>
2)
then I had to register the two ecore metamodels: "Families.ecore" and "Persons.ecore" doing so with rightclick on the ecore file in the workspace and then selecting Register Metamodel.
3)
in the Personclass I forgot to set the type of "fullName" to EString.
The output I got was:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:Persons="Persons">
  <Persons:Male fullName="qwer asdf"/>
  <Persons:Male fullName="ghjk asdf"/>
  <Persons:Female fullName="tzui asdf"/>
  <Persons:Female fullName="yxcv asdf"/>
</xmi:XMI>
[Updated on: Fri, 01 October 2010 05:38] by Moderator
Previous Topic:[ATL] Transformation of References with same name
Next Topic:[QVTo] generate XML
Current Time: Sun Jul 27 02:02:04 EDT 2025
Powered by FUDForum. Page generated in 0.26506 seconds
