Home » Newcomers » Newcomers » 3.1M4 Is it bug ?
3.1M4 Is it bug ? [message #27412] Thu, 10 February 2005 09:57 Go to next message
Originally posted by: sozonnik.mail.ru
Hello !
Sometimes in 3.1M4 "Build" or "Build automatically" option doesn't work.
Reload doesn't help.
Only changing some compilation settings and followed full rebuild can help.
Is it bug or I do something wrong ?
Build id: 200412162000
Andrew.
Re: 3.1M4 Is it bug ? [message #27452 is a reply to message #27412] Thu, 10 February 2005 17:30 Go to previous messageGo to next message
Originally posted by: jaredburns.no.spam.acm.org
If you are set to "build automatically", Eclipse should build
automatically whenever you save a compilation unit. You shouldn't have
to manually tell Eclipse to build.
- Jared
Andrew wrote:
> Hello !
> Andrew.
Re: 3.1M4 Is it bug ? [message #27478 is a reply to message #27452] Fri, 11 February 2005 03:39 Go to previous message
It is clear. But sometimes when I have "build automatically" set, and make
some change in code, for example fix error, in package wiev red cross
doesn't disappear, and project unable to start, however all errors is
fixed.
Previous Topic:Paths and Packages
Next Topic:confusion on eclipse update
Current Time: Fri Oct 17 15:14:06 EDT 2025
Powered by FUDForum. Page generated in 0.08955 seconds
