Re: "make less interesting" replaced by "remove from context"... reason? [message #26385 is a reply to message #25429] |
Thu, 06 September 2007 23:51 |
Originally posted by: beatmik.acm.org
Yup, and the other thing that we lost is the ability to reduce the
interest of a landmark to be interesting without making it uninteresting
or removed from the task context.
We made this simplification for two reasons:
1) Many users' expectation was that once something was made intersting
it would no longer be in the task context.
2) We did not have a clear enough understanding of the use cases for
wanting to make something disappear (make less interesting) while
retaining it in the task context.
Please post your thoughts on this with your use cases, since we can
explore adding finer grained control for the manual manipulation of
interest.
Mik
Pazargic Antonel Ernest wrote:
> I recently found that "make less interesting" action was replaced by "remove from context".
> IMHO I think:
> Based on developing activities a resource can have one of the following three states, regarding of current active task:
> 1. not in task context;
> 2. in task context:
> 2.1. less interesting
> 2.2. landmark
> With "mark as landmark" and "make less interesting" menu items (actions) user could control the all three states of resources.(versions prior to 2.0)
> But now with "mark as landmark" and "Remove from context" the user can control only 2 of resource states (1, 2.2)
> I wonder what the reason was for replacing the "make as less interesting" with "remove from context"?
> Frequently I used manually modify the state of the current task resources (remove, less, and landmark) before marked a task as completed.
> There is a mylyn preference to make "Make less interesting" instead of "Remove From Context"?
> Regards, jtonic.
Re: "make less interesting" replaced by "remove from context [message #29071 is a reply to message #27161] |
Tue, 18 September 2007 19:18 |
Hi Pazargic,
I agree that task context polishing is important in various scenarios,
including closing a task and sharing the context with others. However,
from the point of view of the current UI removing from context and
making less interesting have exactly the same effect. So what we need
to figure out is whether polishing ever requires the distinction between
removing and making less interesting. Have you encountered such a use case?
Mik
> 2. When U have a cohension issue;
> 3. When U simple extract as method refator;
> 4. When U do refactor when U want to comply the code with a proper design patterns.
> Frankly IMHO a detailed task context polishing is very welcomed before U close a task, and this include make less interesting (no remove from context) actions.
> Thx a lot, jtonic
FUDForum. Page generated in 0.02793 seconds
