Re: Odd Behaviour Specifying Source Folder [message #233570] |
Mon, 13 July 2009 14:11 |
Originally posted by: eclipse-news.rizzoweb.com
Davide Cicuta wrote:
> Thanks for your help, but that's exactly what I was trying to do.
> Unfortunately it didn't work, no matter what I excluded, always the same
> stuff went into the jar.
> FORTUNATELY I found the problem in org.eclipse.wst.common.component:
> there it was specified explicitly to include the src folder, together
> with other folders which didn't even exist! I don't know why that stuff
> was there, but after cleaning that file by hand (I had no evidence of
> these settings in any IDE window/dialog) everything seems to be working
> fine.
> Rest assured I'll let you know if it's not so! ;)
Davide,
I strongly suggest you explain what you were seeing and what you found
on the eclipse.webtools newsgroup (I've copied that group to this
message). You should never have to edit those kinds of files by hand and
it is likely that the WTP (web tools) has things that way for a reason
and provides a better mechanism for configuring it.
Eric
FUDForum. Page generated in 0.02782 seconds
