Home » Language IDEs » ServerTools (WTP) » Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal'
Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal' [message #229088] Tue, 17 March 2009 09:21
hi,
i am not sure this problem is related to JBoss 5, but one never knows.
I guess it is a problem with Eclipse IDE 3.4 (Ganymede) maybe one of you
has had this problem before and knows a way to solve it.
Using Eclipse Ganymede 3.4,
i am trying to start JBoss 5, without any project in it.
I get an error message stating that Server Jboss was unable to start
within 999 seconds.
I checked the log file in eclipse .metadate\.log\.log and i get the
following messages :
# !ENTRY org.eclipse.ui 2 0 2009-03-17 07:33:34.877
# !MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
# !SUBENTRY 1 org.eclipse.ui 2 0 2009-03-17 07:33:34.877
# !MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
# !ENTRY org.eclipse.wst.server.core 4 0 2009-03-17 07:51:35.883
# !MESSAGE Server JBoss v5.0 CR1 was unable to start within 999 seconds.
If the server requires more time, try increasing the timeout in the server
editor.
Does anyone know where the problem comes from ? It worked before, and I do
not think i have done anything wrong with my eclipse configuration.
I found a similar problem here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237425
but there is no obvious solution.
Thanks for helping.
Previous Topic:JBoss startup error - Cound not start server in 50 seconds
Next Topic:Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal'
Current Time: Thu Jul 17 15:27:14 EDT 2025
Powered by FUDForum. Page generated in 0.10228 seconds
