Re: XSL Tools - Transformation Run Configuration [message #221137 is a reply to message #221110] |
Tue, 09 September 2008 18:49 |
Originally posted by: dcarver.starstandard.org
Matthew Hailstone wrote:
> I should have noted that the expected result is to have it work. :)
> Also, the only reason I'm including the log4j stuff is because without
> it, I still get the log4j initialization exception.
> Is the default run configuration dependent on log4j?
> Thanks for any insight into what I may be doing wrong.
> (I have used the orangevolt transform plugin, and I liked it very much,
> but I was really wanting to use the built-in Eclipse functionality.)
> Matthew
Have you tried updating to the release version of XSL Tools:
http://download.eclipse.org/webtools/downloads/drops/R0.5/R- 0.5-20080820002020/
You should be able to update through Software Updates as well to upgrade
your existing XSL Tools installation.
If you are continuing to have problems, please open a bugzilla request
with your logs, and steps to reproduce.
Dave
FUDForum. Page generated in 0.03339 seconds
