Re: Compiler Error [message #1813 is a reply to message #1801] |
Thu, 19 March 2009 10:49 |
Hi Madhu,
On 2009-03-18 15:50:58 +0100, madhu.samuel@in.bosch.com (Madhu Samuel) said:
> 1. org.lwgl is not found. Where can I download this from?
LWJGL has to be installed separately. I have written an install
instruction in the Wiki:
http://wiki.eclipse.org/GEF3D_Installation
> 2. The class PerformanceOrbitCameraAction not found in ActionBuilder.java
Uuups.. sorry. I fixed this one. I forgot to check in the package
containing this action. It is a simple performance test, orbiting
around the diagrams and measuring the fps. Simply update the graph
example (or remove the action from the ActionBuilder).
Cheers
Jens
Re: Compiler Error [message #561059 is a reply to message #1801] |
Hi Madhu,
Cheers
Jens
FUDForum. Page generated in 5.04919 seconds
