Re: JET2 editor plugin ? [message #22032 is a reply to message #21858] |
Tue, 12 June 2007 11:53 |
Originally posted by: jcheuoua.ilog.com
Hello guys,
Sorry for the late answer, I'm currently on business trip.
The code completion should work on the java elements (scriplets,
declarations, expression) and for the basic tags, although there are some
usability improvements to be done on the tags code completion.
However I haven't seen the JET-Editor plugin in the I200706071346 build zip.
I'm not sure what went on there and I guess I'm going to follow that issue
with Paul.
Gary, Tex could you confirm as to where you did get the editor plugin ? is
it the EMFT one ?
Joel.
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:16b5dd7d7bfde4fd526bbc3b002188a3$1@www.eclipse.org...
> Hello,
> now I copied manually the editor plugin to my eclipse folder and I have
> the syntax coloration. Cool. I don't have code copletition either.
> Tex.
Re: JET2 editor plugin ? [message #22077 is a reply to message #21988] |
Tue, 12 June 2007 12:00 |
Hello Tex,
To add a bit more confusion ;) ... I's start by saying that JET1 is not in
EMFT ...
Actually the first version of the JET technology was (and still is I think)
used by EMF in the codegen plugin.
That is what could be called JET1, and It's only in EMF.
JET2 is an initiative to make the JET technology involved, and it started as
a project in EMFT.
The JET Editor was a separate plugin at that time, that was also in EMFT,
but was working only with JET1.
Now, in M2T, the two components (JET2 technology and JET Editor) will be
aligned and things should be hopefully clearer.
To make it short :
EMF = JET1
EMFT = JET2 + JET1 Editor
M2T = JET2/JET1 + JET2/JET1 Editor
Maybe Paul can add a bit more to this.
I hope this helps,
Joel.
news:52ed94d5d9c6b96364569c51b48eed03$1@www.eclipse.org...
> Hello,
> I'm a bit confused with the differences between JET1 (EMFT) and JET2.
> Could s.o. give me a short explenation ?
> Thanks.
FUDForum. Page generated in 0.03383 seconds
