Home » Modeling » Papyrus » Error exporting diagram as an image file
Error exporting diagram as an image file [message #1276371] Mon, 24 March 2014 13:21
Luís de Sousa is currently offline Luís de SousaFriend
Hello everyone, this problem refers to a Kepler instance running on Ubuntu 12.04. I have a Use Case diagram I need to include in a document as an image file. I right click on the .di file, select Export All Diagrams... and then select PDF as the file format. In return I get an error window with the following:
ExportAll report
Reason:
Generation failed for some tests
In the error log an exception if filed:
Message:
error during generation of diagram NewDiagram in resource platform:/resource/EMS-iGUESS_Components/models/UseCasesNew.notation
Exception Stack Trace
java.lang.IllegalArgumentException: negative width
	at java.awt.BasicStroke.<init>(BasicStroke.java:181)
	at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.graphics.GraphicsToGraphics2DAdaptor.createStroke(GraphicsToGraphics2DAdaptor.java:1544)
	at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.graphics.GraphicsToGraphics2DAdaptor.drawPolygon(GraphicsToGraphics2DAdaptor.java:633)
	at org.eclipse.draw2d.Graphics.drawPolygon(Graphics.java:293)
	at org.eclipse.gmf.runtime.draw2d.ui.internal.graphics.ScaledGraphics.drawPolygon(ScaledGraphics.java:356)
	at org.eclipse.papyrus.uml.diagram.usecase.draw2d.StickMan.outlineShape(StickMan.java:62)
	at org.eclipse.papyrus.uml.diagram.usecase.draw2d.ShadowShape.outlineShape(ShadowShape.java:134)
	at org.eclipse.draw2d.Shape.paintOutline(Shape.java:175)
	at org.eclipse.draw2d.Shape.paintFigure(Shape.java:147)
	at org.eclipse.papyrus.uml.diagram.usecase.draw2d.ShadowShape.paint(ShadowShape.java:109)
	at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1167)
	at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1202)
	at org.eclipse.draw2d.Figure.paint(Figure.java:1117)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.paintFigure(DiagramGenerator.java:373)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.renderToGraphics(DiagramGenerator.java:226)
	at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.createSWTImageDescriptorForParts(DiagramGenerator.java:721)
	at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:376)
	at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:305)
	at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:123)
	at org.eclipse.papyrus.infra.export.ExportAllDiagrams.exportDiagram(ExportAllDiagrams.java:357)
	at org.eclipse.papyrus.infra.export.ExportAllDiagrams.access$3(ExportAllDiagrams.java:354)
	at org.eclipse.papyrus.infra.export.ExportAllDiagrams$6.run(ExportAllDiagrams.java:336)
	at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
	at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3717)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3366)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Session Data:
eclipse.buildId=4.3.2.M20140221-1700
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments:  -product org.eclipse.epp.package.standard.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.standard.product
What is wrong here? How can I export the diagram as an image file? Thanks.
Previous Topic:[solved] Understanding Validation errors
Next Topic:Adding input/output expansion nodes to Expansion Regions
Current Time: Sat Apr 27 14:51:52 GMT 2024
Powered by FUDForum. Page generated in 0.02769 seconds
