Home » Language IDEs » C / C++ IDE (CDT) » Using Xcode compiler in CDT
Using Xcode compiler in CDT [message #203914] Wed, 31 October 2007 04:04 Go to next message
Originally posted by: none.domain.invalid
i'd like to use CDT on Mac OS X 10.4, with the Xcode compiler. Is there
any tutorial on how to do that?
TIA
Re: Using Xcode compiler in CDT [message #203930 is a reply to message #203914] Wed, 31 October 2007 09:37 Go to previous message
After you install the Xcode tools your system will have everything it
needs to work with CDT. GCC for the compiler and gdb for debugging. The
easiest way to use all this is to just launch CDT and use a "Managed
Makefile" for your project. That should be all you need.
If you are talking about using the "xcode-build" tool that Xcode
includes then you will probably have some issues with that. This is
assuming you already have an Xcode project ready to go.
Hope that helps.
Mike Jackson
On 2007-10-31 04:04:48 -0400, Name <none@domain.invalid> said:
> Hello,
> TIA
Previous Topic:Linking problem when using matlab engine under gcc
Next Topic:Newbie to CDT :- On-fly syntax check
Current Time: Sun Aug 31 07:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.03824 seconds
