Home » Language IDEs » Java Development Tools (JDT) » Odd behavior when attempting to extend AbstractDebugView
Odd behavior when attempting to extend AbstractDebugView [message #201912] Sun, 24 April 2005 16:41 Go to next message
I haven't logged this as a bug because I'm still not sure what is going
on and would like someone else to try and see what happens.
My setup is Eclipse M6 on Mac OS X. I verified this behavior in M5 on
Mac OS X as well. I also verified the behavior on WinXP on M6.
I have a plug-in project that has dependencies on:
org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.debug.core,
org.eclipse.debug.ui,
org.eclipse.ui.views
When trying to extend AbstractDebugView via the new class wizard or by
adding the extension after class creation I receive something like the
following:
package com.test;
import org.eclipse.debug.ui.AbstractDebugView;
import org.eclipse.jface.viewers.DoubleClickEvent;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.ui.part.IPage;
import org.eclipse.ui.part.PageBook;
import org.eclipse.ui.part.PageBookView.PageRec;
public class MyAbstractTest extends AbstractDebugView {
protected IPage createDefaultPage(PageBook book) {
// TODO Auto-generated method stub
return null;
protected PageRec doCreatePage(IWorkbenchPart part) {
return null;
protected void doDestroyPage(IWorkbenchPart part, PageRec pageRecord) {
protected IWorkbenchPart getBootstrapPart() {
return null;
protected boolean isImportant(IWorkbenchPart part) {
return false;
public void doubleClick(DoubleClickEvent event) {
These methods are not abstract and I'm not sure why they were overriden.
I then receive tasks in the task view that I need to implement:
AbstractDebugView.configureToolBar(...)
AbstractDebugView.createActions()
AbstractDebugView.createViewer(Composite)
AbstractDebugView.fillContextMenu(...)
AbstractDebugView.getHelpContextId()
If I remove the method declarations from my class and use 'quick fix' it
still attempts to implement the incorrect methods. I also receive an
error on the import for org.eclipse.ui.part.PageBookView.PageRec with
the message "The type org.eclipse.ui.part.PageBookView.PageRec is not
visible".
Anyone have any ideas on what might be going on?
Brad
Re: Odd behavior when attempting to extend AbstractDebugView [message #202088 is a reply to message #201912] Wed, 27 April 2005 12:47 Go to previous message
Please file a bug report against JDT UI
Tobias
"Brad Reynolds" <bradleyjames@gmail.com> wrote in message
news:d4h0e5$gku$1@news.eclipse.org...
>I haven't logged this as a bug because I'm still not sure what is going on
> My setup is Eclipse M6 on Mac OS X. I verified this behavior in M5 on Mac
> org.eclipse.ui,
> following:
> package com.test;
> return null;
> return null;
> return null;
> return false;
> These methods are not abstract and I'm not sure why they were overriden. I
> error on the import for org.eclipse.ui.part.PageBookView.PageRec with the
> visible".
> Brad
Previous Topic:how to share class variables across workspace
Next Topic:Nested For Looy
Current Time: Fri Sep 12 21:24:55 EDT 2025
Powered by FUDForum. Page generated in 0.03872 seconds
