Include paths and Kepler (on Windows) [message #1227124] |
Fri, 03 January 2014 16:05 |
Juha Aaltonen Messages: 3 Registered: January 2014 Location: Nokia, Finland |
Junior Member |
Any idea why the compiler often complains about definitions/declarations not found?
when going to the complaining location in the C file, selecting the complained-about thing and right-clikcing and selecting "find definition" finds it.
Also the path is in the include directory list.
Sometimes getting to the definition fixes the problem, sometimes not, and sometimes the definition is not found even if the file is in the include-path and definitions in the other files in that same path do not generate complaints.
Sometimes cleaning the project and building all removes the problem, sometimes not.
What could affect that? Eclipse-version? Using 64-bit Windows 7? gnu atm toolchain?
That has happened with 3 projects 2 of which have been downloaded "test projects".
[edit]
I forgot: also the the parameters for objdump, objcopy and size are "messed up".
Like the first parameter for objcopy is input file, flags, input file again and output file. The first input file and the flags seem to be in the same variable, but I'm not sure which. Is there a way to see what's in the variables? It's annoying having to remove the parameters from the command lines one at a time and then "build all" and wait for the console output and see what changed.
Are there some issues that could cause that in 64-bit windows 7 or maybe my installation is seriously corrupt?
[edit2]
The messed up parameters:
Command line options (from the project properties):
${COMMAND} ${INPUTS} ${FLAGS}
From console output:
arm-none-eabi-size "..\\USB_CDC_koe.elf" --format=berkeley USB_CDC_koe.elf
${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
arm-none-eabi-objdump USB_CDC_koe.elf --source --all-headers --demangle --line-numbers --wide > USB_CDC_koe.lst "..\\USB_CDC_koe.elf"
Command line options (added the '-v'):
${COMMAND} -v ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
arm-none-eabi-objcopy -v USB_CDC_koe.elf -O ihex USB_CDC_koe.hex "..\\USB_CDC_koe.elf"
The path without ".." is the right one.
[edit3]
The command line parameters and console outputs are copied from 32-bit Vista installation, but the stuff is the same as with 64-bit Windows 7 installation.
So it doesn't seem to be a 32/64 bit issue, nor Windows 7 issue.
[Updated on: Sun, 05 January 2014 13:24] Report message to a moderator
FUDForum. Page generated in 0.03520 seconds
