Home » Language IDEs » Java Development Tools (JDT) » Compiler Needed Urgently
Compiler Needed Urgently [message #199148] Mon, 21 March 2005 12:27 Go to next message
Originally posted by: robin_drew.hotmail.com
For a project i am working on, i urgently need a compiler can take a
String containing the java file definition (package + imports + class),
and output a byte[] containing the compiled code.
I don't believe the source to javac is available to developers (or is
it?). The only other possibilities i have are to write the code to the
file system and invoke javac via a Runtime.exec() which is unacceptable.
I have investigated the Kopi compiler but this is now defunct and although
it worked for 1.4.2 it does not work for version 1.5
I have investigated eclipse but am a bit concerned at the time it may take
to navigate their core code and find the classes necessary.
______________________________________
At the top level all i need is the following method!
byte[] compile(String javaCode);
Any suggestions gladly accepted.
Re: Compiler Needed Urgently [message #199156 is a reply to message #199148] Mon, 21 March 2005 12:01 Go to previous messageGo to next message
Look at class: org.eclipse.jdt.internal.compiler.batch.Main.
It invokes the compiler and receives the byte[] in memory through requestor
API.
That should be fairly easy to adapt to meet your needs.
"Robin Drew" <robin_drew@hotmail.com> wrote in message
news:3fc84cfd0c0212215eb2b8a5785e5350$1@www.eclipse.org...
Re: Compiler Needed Urgently [message #199165 is a reply to message #199148] Mon, 21 March 2005 12:42 Go to previous message
There is Javassist from JBoss. Not sure whether it supports 1.5 yet.
John.
> although it worked for 1.4.2 it does not work for version 1.5
> take to navigate their core code and find the classes necessary.
Previous Topic:keybindings in 3.1M5: ctrl-w hardcoded?
Next Topic:Timing problem with variables view show types action.
Current Time: Fri Oct 17 21:56:34 EDT 2025
Powered by FUDForum. Page generated in 0.05392 seconds
