Home » Modeling » TMF (Xtext) » Disable validation of imported metamodel
Disable validation of imported metamodel [message #1172003] Tue, 05 November 2013 11:31 Go to next message
I would like to know if it is possible to disable the validation for a subset of modelelements which are specified in the metamodel.
The problem is that I'm getting some validation-errors from the Xtexteditor while writting my dsl-file. So my idea is to disable the validation for exactly this modelelement.
I try to build a real simple textual notation and want to serialize the (valid) model while saving the file. The saved model is modified during the saving process, so it is
valid at the end.
Alex
Re: Disable validation of imported metamodel [message #1173347 is a reply to message #1172003] Wed, 06 November 2013 08:03 Go to previous messageGo to next message
is it maybe possible to override the default-errors (which are caused from the imported metamodel in the grammarfile) by extending the AbstractMyDslValidator?
~Alex
Re: Disable validation of imported metamodel [message #1173668 is a reply to message #1173347] Wed, 06 November 2013 12:28 Go to previous messageGo to next message
Think there is an option to postpone some validation until the save.
IIRC there is a .normal attribute for the standard behaviour.
I tried to google it, but got no meaningful hint
Re: Disable validation of imported metamodel [message #1174803 is a reply to message #1173668] Thu, 07 November 2013 05:16 Go to previous messageGo to next message
Thanks for the hint.
Re: Disable validation of imported metamodel [message #1174867 is a reply to message #1173668] Thu, 07 November 2013 06:09 Go to previous message
Found an example in the book from Markus Völter (dslbook.org)
DSL Engineering
Designing, Implementing and Using
Domain-Specific Languages
on page 242:
•CheckType.NORMAL: run when the file is saved.
•CheckType.FAST: run after each model change (more or less after each keypress).
•CheckType.EXPENSIVE: run only if requested explicitly via the context menu.
@Check(CheckType.NORMAL)
publicvoidcheckOrphanEndState( CustomState ctx ) {
CoolingProgram coopro = Utils.ancestor(ctx, CoolingProgram.class);
TreeIterator<EObject> all = coopro.eAllContents();
while( all.hasNext() ) {
EObject s = all.next();
if(sinstanceofChangeStateStatement ) {
ChangeStateStatement css = (ChangeStateStatement) s;
if( css.getTargetState() == ctx )return;
error("no transition ever leads into this state",
CoolingLanguagePackage.eINSTANCE.getState_Name());
[Updated on: Thu, 07 November 2013 06:18] by Moderator
Previous Topic:Generic DSL based on POJO
Next Topic:Generate Eclipse Application
Current Time: Tue Jul 15 23:32:47 EDT 2025
Powered by FUDForum. Page generated in 0.07246 seconds
