Home » Newcomers » Newcomers » Compare editor with "old" version on left?
Compare editor with "old" version on left? [message #178117] Thu, 02 November 2006 16:25 Go to next message
Is there a way to configure the compare editor (e.g. for compare to
HEAD) to show the "old" version on the left and the new version on the
right, like most sane GUI diff tools do?
Using Eclipse 3.2.1 with CVS as the source control.
Thx!
Re: Compare editor with "old" version on left? [message #178277 is a reply to message #178117] Fri, 03 November 2006 12:15 Go to previous messageGo to next message
> Thx!
No. But if it really bothers you, you should consider creating a bug
report requesting the feature. I strongly recommend that you avoid the
"sane" crack in the bug report (if you want it to get any traction).
Wayne
Re: Compare editor with "old" version on left? [message #178296 is a reply to message #178277] Fri, 03 November 2006 17:53 Go to previous message
Wayne Beaton wrote:
> you should consider creating a bug report requesting the feature
Sure. Will do.
> I strongly recommend that you avoid the "sane" crack in the bug report
Heh, well, ok. "Conventional", then..
Previous Topic:many problems...ve..eclipse running slow..etc...
Next Topic:Eclipse 3.2 - Want to share Workspace with others
Current Time: Sat Aug 30 20:59:04 EDT 2025
Powered by FUDForum. Page generated in 0.06540 seconds
